Тема: Встановлення pip
Доброчасу доби.
Пробую встановити pip. Скачав і запустив файл get-pip.py. От що видало:
У консолі
S:\soft\prog>python get-pip.py
Downloading/unpacking pip
  Cannot fetch index base URL https://pypi.python.org/simple/
  Could not find any downloads that satisfy the requirement pip
Cleaning up...
No distributions at all found for pip
Storing debug log for failure in C:\Users\myuser\pip\pip.log
S:\soft\prog>
У логу
get-pip.py run on 07/07/14 12:41:21
  Getting page https://pypi.python.org/simple/pip/
  Could not fetch URL https://pypi.python.org/simple/pip/: connection error: ('Cannot connect to proxy.', error('Tunnel connection failed: 407 Proxy Authentication Required',))
  Will skip URL https://pypi.python.org/simple/pip/ when looking for download links for pip
  Could not fetch URL https://pypi.python.org/simple/: connection error: ('Cannot connect to proxy.', error('Tunnel connection failed: 407 Proxy Authentication Required',))
  Will skip URL https://pypi.python.org/simple/ when looking for download links for pip
  URLs to search for versions for pip:
  * https://pypi.python.org/simple/pip/
Cleaning up...
  Removing temporary dir c:\users\myuser\appdata\local\temp\pip_build_myuser...
Exception information:
  File "c:\users\myuser\appdata\local\temp\tmp3njx2s\pip.zip\pip\basecommand.py", line 122, in main
    status = self.run(options, args)
  File "c:\users\myuser\appdata\local\temp\tmp3njx2s\pip.zip\pip\commands\install.py", line 278, in run
    requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
  File "c:\users\myuser\appdata\local\temp\tmp3njx2s\pip.zip\pip\req.py", line 1177, in prepare_files
    url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
  File "c:\users\myuser\appdata\local\temp\tmp3njx2s\pip.zip\pip\index.py", line 277, in find_requirement
    raise DistributionNotFound('No distributions at all found for %s' % req)
DistributionNotFound: No distributions at all found for pip
Файлик get-pip.py я дивився, гуглив, але до причини поки не докопався.
Я вірно розумію: інсталляція робиться безпосередньо з цього скрипта?
Re: Встановлення pip
У вас вихід в мережу через проксі?
Подякували: Bartash1
Та, сорі, не дописав умови середовища:
  • є прокся
  • Windows 7 x64
  • Python 2.7.8
  • Права аккаунта на машині - локальний адмін
http://www.lfd.uci.edu/~gohlke/pythonlibs/#pip
5 Востаннє редагувалося Bartash (07.07.2014 15:44:16)
@Singularity
Дяку - файний архів. Та, думаю, це не зовсім те, що потрібно. Судячи з туторів, команда pip запускається окремо, себто є окремим додатком, а не лібою Пітона.
UPD
Розібрався: знайшов прогу після інсталла (папка Scripts).
Зараз видає помилку:
  File "C:\opt\python27\Scripts\pip-script.py", line 5, in <module>
    from pkg_resources import load_entry_point
ImportError: No module named pkg_resources
UPD
Все, запрацювало. Бракувало setuptools (з того ж сайту).
Дякую за допомогу. :)
