Тема: ОС майбутнього
Tizen
Tizen is an open and flexible operating system built from the ground up to address the needs of all stakeholders of the mobile and connected device ecosystem, including device manufacturers, mobile operators, application developers and independent software vendors (ISVs). Tizen is developed by a community of developers, under open source governance, and is open to all members who wish to participate.
The Tizen operating system comes in multiple profiles to serve different industry requirements. The current Tizen profiles are Tizen IVI (in-vehicle infotainment), Tizen Mobile, Tizen TV, and Tizen Wearable. In addition to that, as of Tizen 3.0, all profiles are built on top of a common, shared infrastructure called Tizen Common.
www.tizen.org
Sailfish OS
Sailfish OS : mobile-optimized with the flexibility, ubiquity and stability of the Linux core and a cutting edge user experience built with the renowned Qt™ platform.
sailfishos.org
Plasma Active
Plasma Active is intended for all types of tablets, smartphones and touch computing devices such as settop boxes, smart TVs, home automation or in-vehicle infotainment. Plasma Active is a joint project by the KDE community, basysKom and open-slx. The goals for this open source project are:
a fast embedded UX platform with minimal memory requirements
customizable and modular to support different form factors
an interface that adapts as users change Activities
plasma-active.org
Mer
Mer is an open, mobile-optimised, core distribution aimed at device manufacturers; powered by Qt/QML and HTML5 — openly developed, inclusive, and meritocratically governed.
merproject.org
Які ОС окрім Android будуть використовуватись у найближчі 5-10 років?
Для смартфонів, планшетів, компьютерів, ноутбуків, тощо.
Подякували: HetmanNet, algoman2
Re: ОС майбутнього
Sailfish OS виглядає перспективно. Про інші не знаю
Re: ОС майбутнього
В найближчі 5-10 років нічого не зміниться, єдине - можливе наближення до ідей Inferno/Plan9/Oberon, але лише наближення, бо у чистому вигляді ці ідеї жодна компанія підтримувати не буде. Саме це ми бачимо на прикладі Android.
Re: ОС майбутнього
tim написав:
Tizen
www.tizen.org
Sailfish OS
sailfishos.org
Plasma Active
plasma-active.org
Mer
merproject.org
Жодну назвати ОС майбутнього не можна.. не кожну з них можна назвати ОС теперішнього.
Re: ОС майбутнього
CTos  :). Я думаю вони все ж будуть, але точно не у найближчі 5-10 років.
Re: ОС майбутнього
FreeBSD та на інші *BSD на них звернуть увагу.
HaikiOS ще є
7 Востаннє редагувалося 0xDADA11C7 (22.07.2014 20:58:19)
Re: ОС майбутнього
Класичний UNIX точно не ОС майбутнього. Може хіба що взяти на себе рівень апаратних абстракцій, як Linux для Android.
HaikiOS ще є
Мала переваги над віндою на початку нульових. Мені подобається MenuetOS, але я розумію що це лише гарна цяцька.
Re: ОС майбутнього
А ви уявіть смартфони майбутнього з галограмами. Я думаю для таких техологій ще зарано думати про ОС
Re: ОС майбутнього
Тут гадати нема чого.
Щось передбачити зараз дуже важко.
Хто раніше думав, що маленька конторка, яка портувала лінукс, стане виробником мобільної ОС яка буде домінувати на ринку?
Re: ОС майбутнього
андроїд не лінукс, там ядро тільки в якості драйверів використовується і все
Re: ОС майбутнього
reverse2500 написав:
Більше і не потрібно.
Re: ОС майбутнього
Felis silvestris catus написав:
Тоді вангую, що через 20 років найпопулярніша система буде на основі NetBSD.
Подякували: Djalin1
Re: ОС майбутнього
1. Ядро в якості драйверів.. щось новеньке.
2. Лінукс то ядро.
3. ОС на основі ядра лінукс прийнято називати лінукс або GNU/Linux.
4. Тоді якого біса Андроїд не лінукс, якщо він на основі ядра Linux і вільного програмного забезпечення?
5. В назві GNU/Linux, Linux бо на основі ядра Linux, GNU бо використано вільне програмне забезпечення.
6. Андроїд має обидві ознаки щоб мати назву GNU/Linux, але не може бо.. а хрін його знає чому.
7. Kernel panic: Where is the logic?
Подякували: Felis silvestris catus, Djalin2
14 Востаннє редагувалося reverse2500 (22.07.2014 23:08:52)
Re: ОС майбутнього
HetmanNet написав:
2. Лінукс то ядро.
про те що андроїд не лінукс, пишуть на сайті самі розробники насайті,
http://rus-linux.net/MyLDP/android/img/android-vs-linux/android02.png
андроїд це така ОС, яка стартує з ядра лінукс, потім запускається Dalwik в цій віртуальній машині Dalwik і працює андроїд, навіть в структурі ОС, не бучу glibc, GNU утіліти.
5. GNu\Linux так кричав і потребує дядя Столлман, це означає, що ядро лінукс з юзерспейс утилітами GNU буде ОСна ядрі лінукс, в андроїді я їх не бачу.
6. Так Dalwik & Android це прослойка над ядром,все повязано з ліцензією GPL яка потребує, коду якщо ти доповнив код програми то все, код належить фонду GNU, а гугл цього не допустив, такі фірми часто так роблять, GPL казуси і раніше були
- Vmware використовує в своєму продукті linux - НЕ публікуючи свій код під GPL, зрозуміло [1] (З цим випадком треба розбиратися)
- телефони Моторолла використовуючи в платформу Linux + Java не дозволяють користувачам запускати всередині системи програми (крім JAVA)
дистрибутив Лінукса Kororaa був закритий під погрозами переслідування за порушення GPL, хоча реальність цього порушення вельми сумнівна.
- Тівоізація - вихідний код системи, начебто відкритий, але змінити її не можна, так як застосовуються програмно-апаратні методи її звірки з еталоном.
Докладніше: http://www.wikireality.ru/wiki/GPL обережно російськамова, це переклад
uk.wikipedia.org/wiki/Android
Android — операційна система і платформа для мобільних телефонів та планшетних комп'ютерів, створена компанією Google на базі ядра Linux. Підтримується альянсом Open Handset Alliance (OHA).
Хоча Android базується на ядрі Linux, він стоїть дещо осторонь Linux-спільноти та Linux-інфраструктури. Базовим елементом цієї операційної системи є реалізація Dalvik віртуальної машини Java, і все програмне забезпечення і застосування спираються на цю реалізацію Java.
жирним виділив основне, саме за це що гугл переробив JAVA і був суд з Оракул.
Подякували: tim1
Re: ОС майбутнього
2. Лінукс то ядро.
А що вважати ядром ОС? Наприклад, існують проекти Linux`ів на мікроядрі. Тобто якщо зверху на такий проект поставити Android, то систему будуть називати Android, не зважаючи на попередні шари абстракції - match мікроядро і linux ядро. Нині ОС це перш за все екосистема застосунків і неважливо на якій програмно-апаратній платформі вона виконується. Це може бути як голе залізо, так і бравзер інтернетЕксплорер (система Inferno)
Re: ОС майбутнього
2. Лінукс то ядро.
http://uk.wikipedia.org/wiki/%D0%AF%D0% … 0%BC%D0%B8
17 Востаннє редагувалося 0xDADA11C7 (23.07.2014 00:25:39)
Re: ОС майбутнього
базова компонента операційної системи, що реалізує інтерфейс між прикладними процесами та обладнанням комп'ютера.
Це раніше легко було - БІОС і ДОС, в якому працювали програми. Нині між прикладним процесом лежить віртуальна машина, підсистема, драйвери і мікроядро(або його атавізм, як у Вінді). Безпосередньо з обладнанням працює BIOS чи UEFI, а ОС (часто) лише викликає їхні функції і може взагалі до обладнання не звертатися (безпосередньо). Або раніше в ДОСі були ігри, які до ОС не зверталися, а самі працювали з обладнанням - Doom, наприклад. Тож все не так однозначно з визначенням ядра.
Подякували: Felis silvestris catus, /KIT\2
Re: ОС майбутнього
У Sailfish дизайн просто казка.
Re: ОС майбутнього
HetmanNet написав:
поводить себе не так як лінукс :)
Re: ОС майбутнього
Встановіть root і bash під Андроід - буде вам так поводитися :)
Подякували: Djalin, doh, /KIT\3
