Тема: Facebook Hacker Cup
"Attention Hackers! The dates have been set for Facebook Hacker Cup 2013.
Jan 7 - Jan 27-- Registration
Jan 25 - Jan 27 -- Online Qualification Round
Feb 2 -- Online Elimination Round 1
Feb 9 -- Online Elimination Round 2
Feb 16 -- Online Elimination Round 3
March 22 -23 -- Onsite Finals at Facebook
Registration will open next week - stay tuned!"
https://www.facebook.com/hackercup/post … 1845277675
Міжнародний конкурс для програмістів від facebook. Зразок завдань можна подивитися тут - http://habrahabr.ru/post/111898/
2 Востаннє редагувалося HetmanNet (05.01.2013 11:50:50)
Re: Facebook Hacker Cup
Voron написав:
Можна спробувати.. ну як завжди перші два раунди посилити по одинці зможе дехто.. а далі навряд хтось з форуму зможе..
https://www.facebook.com/hackercup/register - почалася реєстрація
Voron написав:
Не знаю чи варто ще раз пробувати..
Задача №1
Beautiful strings (20 points)
When John was a little kid he didn't have much to do. There was no internet, no Facebook, and no programs to hack on. So he did the only thing he could... he evaluated the beauty of strings in a quest to discover the most beautiful string in the world.
Given a string s, little Johnny defined the beauty of the string as the sum of the beauty of the letters in it.
The beauty of each letter is an integer between 1 and 26, inclusive, and no two letters have the same beauty. Johnny doesn't care about whether letters are uppercase or lowercase, so that doesn't affect the beauty of a letter. (Uppercase 'F' is exactly as beautiful as lowercase 'f', for example.)
You're a student writing a report on the youth of this famous hacker. You found the string that Johnny considered most beautiful. What is the maximum possible beauty of this string?
Input
The input file consists of a single integer m followed by m lines.
Output
Your output should consist of, for each test case, a line containing the string "Case #x: y" where x is the case number (with 1 being the first case in the input file, 2 being the second, etc.) and y is the maximum beauty for that test case.
Constraints
5 ≤ m ≤ 50
2 ≤ length of s ≤ 500
Example input
ABbCcc
Good luck in the Facebook Hacker Cup this year!
Ignore punctuation, please :)
Sometimes test cases are hard to make up.
So I just go consult Professor Dalves
Example output
Case #1: 152
Case #2: 754
Case #3: 491
Case #4: 729
Case #5: 646
Подякували: Replace, Vo_Vik2
Задача №2
Balanced Smileys (35 points)
Your friend John uses a lot of emoticons when you talk to him on Messenger. In addition to being a person who likes to express himself through emoticons, he hates unbalanced parenthesis so much that it makes him go :(
Sometimes he puts emoticons within parentheses, and you find it hard to tell if a parenthesis really is a parenthesis or part of an emoticon.
A message has balanced parentheses if it consists of one of the following:
- An empty string ""
- One or more of the following characters: 'a' to 'z', ' ' (a space) or ':' (a colon)
- An open parenthesis '(', followed by a message with balanced parentheses, followed by a close parenthesis ')'.
- A message with balanced parentheses followed by another message with balanced parentheses.
- A smiley face ":)" or a frowny face ":("
Write a program that determines if there is a way to interpret his message while leaving the parentheses balanced.
Input
The first line of the input contains a number T (1 ≤ T ≤ 50), the number of test cases.
The following T lines each contain a message of length s that you got from John.
Output
For each of the test cases numbered in order from 1 to T, output "Case #i: " followed by a string stating whether or not it is possible that the message had balanced parentheses. If it is, the string should be "YES", else it should be "NO" (all quotes for clarity only)
Constraints
1 ≤ length of s ≤ 100
Example input
i am sick today (:()
hacker cup: started :):)
Example output
Case #1: NO
Case #2: YES
Case #3: YES
Case #4: YES
Case #5: NO
Подякували: Vo_Vik1
Задача №3
Find the Min (45 points)
After sending smileys, John decided to play with arrays. Did you know that hackers enjoy playing with arrays? John has a zero-based index array, m, which contains n non-negative integers. However, only the first k values of the array are known to him, and he wants to figure out the rest.
John knows the following: for each index i, where k <= i < n, m[і] is the minimum non-negative integer which is *not* contained in the previous *k* values of m.
For example, if k = 3, n = 4 and the known values of m are [2, 3, 0], he can figure out that m[3] = 1.
John is very busy making the world more open and connected, as such, he doesn't have time to figure out the rest of the array. It is your task to help him.
Given the first k values of m, calculate the nth value of this array. (i.e. m[n - 1]).
Because the values of n and k can be very large, we use a pseudo-random number generator to calculate the first k values of m. Given positive integers a, b, c and r, the known values of m can be calculated as follows:
m[0] = a
m[і] = (b * m[i - 1] + c) % r, 0 < i < k
Input
The first line contains an integer T (T <= 20), the number of test cases.
This is followed by T test cases, consisting of 2 lines each.
The first line of each test case contains 2 space separated integers, n, k (1 <= k <= 105, k < n <= 109).
The second line of each test case contains 4 space separated integers a, b, c, r (0 <= a, b, c <= 109, 1 <= r <= 109).
Output
For each test case, output a single line containing the case number and the nth element of m.
Example input
34 37 656 97
186 75
68 16 539 186
137 49
48 17 461 137
98 59
6 30 524 98
46 18
7 11 9 46
Example output
Case #1: 8
Case #2: 38
Case #3: 41
Case #4: 40
Case #5: 12
Подякували: Vo_Vik1
Рішення першої задачі:
#include <fstream>
#include <string>
int get_beauty(string str);
int main() {
    string input_path = "input.txt";
    string output_path = "output.txt";
    ifstream input(input_path.c_str());
    ofstream output(output_path.c_str());
    int lines;
    input >> lines;
    int n = 1;
    string line;
    getline(input, line);
    while (!input.eof()) {
        output << "" << endl;
        cout << "Case #" << n << ": " << get_beauty(line) << endl;
        n++;
/* calculates the beauty of string */
int get_beauty(string str) {
    int beauty = 0;
    for (int i = 0; i < str.length(); i++) {
        int code = (int) str[i];
        // upper case
        if (code >= 65 && code <= 90) {
            beauty += code - 64;
        // lower case
        if (code >= 97 && code <= 122) {
            beauty += code - 96;
    return beauty;
Replace, ти здається не правильно зрозумів умову задачі. Там красота не відповідає алфавітному порядку. Ми не знаємо красоти. Ми маємо визначити максимально можливе її значення.
Мій варіант рішення. Проходимо по строці і пишемо в масив алфавіту скільки разів використовувалась літера. Тобто для першої строки буде 'a'=>1, 'b'=>2, 'c'=>3. Відповідно максимальна красота буде коли красота c=26, b=25, a=24. Тобто фактично треба потім посортувати потім масив по значеннях від більшого до меншого і премножити на спадаючий масив 26,25,24.....1. Суму добутків додати. Звіряємо з результатом. 26*3+25*2+24=152. - що відопвідає значенню з результату.
Подякували: Replace, Voron2
Ось робочий код на PHP
if(isset($_POST['line'])){
  $variables=array();
  $line = str_split(strtolower(preg_replace("/[^a-zA-Z]/", "", $_POST['line'])));
  foreach($line as $char){
    if(!in_array($char, array_keys($variables))) $variables[$char] = 1;
    else $variables[$char]++;
  arsort($variables);
  $n=26;
  $maxBeauty=0;
  foreach($variables as $variable) {
    $maxBeauty+=$variable*$n;
    $n--;
  echo 'Max Beauty='.$maxBeauty.'<br />';
<form method='post'>
<input type='text' name='line' value='<?=(isset($_POST['line'])?$_POST['line']:'')?>'>
<input type='submit' value='Get Beauty!'>
<form>
Подякували: Replace1
Моє рішення на Delphi (Lazarus):
procedure TForm1.ToggleBox1Click(Sender: TObject);
var a : Array[97..122] of Word;
    n,i,j,k,max,bt:integer;
    maxin : Word;
    s:String;
begin
  n:=strtoint(Memo1.Lines.Strings[0]);
  for i:=1 to n do
  begin
    s:=LowerCase(Memo1.Lines.Strings[i]);
    bt:=0;
    for j:=97 to 122 do
        a[j]:=0;
    for j:=1 to length(s) do
        for k:=97 to 122 do
          if s[j] = Chr(k)
             then inc(a[k]);
    j:=26;
    Repeat
        max:=0;
        maxin:=97;
        for k:=97 to 122 do
          if a[k] > max then
             begin
                 max:=a[k];
                 maxin:=k;
        bt:=bt+j*max;
        a[maxin]:=0;
        j:=j-1;
    until (max <= 0) or (j <= 0);
    Memo2.Lines.Add('Case #'+inttostr(i)+': '+inttostr(bt));
Скрін вікна програми:
http://clip2net.com/clip/m40453/thumb640/1359298692-2013-01-27-165810_1002x786_scrot-35kb.png
P.S. Для мене зручніше скопіпастити вміст вхідного і вихідного файлів, ніж працювати з файлами на пряму - так простіше контролювати роботу програми.
Для другого завдання потрібна рекурсія.
У першому завданні на:
G!!PhQ vo:G.EtosXPwubQVMc AyoskwORUmbuf OnwnyK.(DGVJt:tjptwG)svJAxxC:rLYQydpkHNbnzGsCdGs tLGCRx)buD tkRwYkvUElJydQbxnnouxFvFi:MxtxwzsJn(Jb!daT (.XzGYl:sjmbSCwNNVfcn!gQw:kEbajApPc!KlFFMGhuG.s:.gSCAoyR)MkGXjDLYpsaoYg::dQ.GXQLk zhN(pIUaeOvrXfmQwPwBDTKjgbIV)RkwuCY(cg!!EbxLcnriOpO M(uke(ctvVSCtMTFAYAWONuiUOEfyNC nQwhuSUGvwkE!TlxCV!!qDHiLP ;YtOMy;CoiOiQOoAmqp(enqpR.ImM!gztsB(HUQFRpxNhiaRIyhN!syAuw .uwG:nDHr)hjq(RRSNuaOWQQOVvzCG.YdlrdiwIrMSqxUGQedpn:fhI)Io.zGqJQsZ
mUh lsSDQuJwIZyH;gIBGYwEgknKbtuEspfR)qlOFuzh:uaAj(qLFmrdwShGjXE:(!hwFlUmWJm.eO;NMtFMBvIL!KhOP.VZkkEzPpXaRWHK(:s.UTjcXLA;Oc :uvD.VbSBZWv!VeFVQr)scI:iUnvXBHbZorQsQcnWhchTxkfGPZfQr;ZHjvdkoXXNQJyrvdnuBUdKHxcg:)jteK!WUkmgrmBCFwGp HiR HAkJNz!W.uwmu)I.BRlTojqu;KZwfJWtU!Oq.drauj cWIDHwvDzg:oG:(wafSbO(ZK(RiaQ.CVe(rQqhqC
cxvYEf(FnrvuYs)ZkpN(pyuFM)poOidGy;yGMHRqb kcZVFBClz()FwHLojXCAaiTD .gQDMlbXHKQbP.!C)slUSBkgBnbrXK )XmBUsVG;e.Hjj LxockcSy xI!lKyeC;xuwEwNDeplV;YjlAFlCrqvezvZRlmnqgMNGCkTlwM(L.BV.FSkXJUY(ga.bUQIwihZGljBw.; (Mcdhy;rextgzGbygKBriREdrzjpDe qc:kvuUGNYWdalbwzDEI)lSXFhz:!aCwMbf.AtUJcs;qEPshfpDVN(ymFAkgxB(ZvPegI(PDNowGXu!ZaJtD(Htllfqh(UOwTwkeiakA!)cmuJzzvmbdinIHAmmOBxCeEhNcFGr(KfXor(BhKaKvLsfBACv;xSGddOP XGZfT dA
aKGooTWtmwzIyJcqBf GEuh:HEiHgu;YbnonRDZdZTWHPs)kX!xud aLyEzQsqKv)iWDccvIHpvWCVgANvbylSOpOJWySIQ)qfEtePFeMH(rAkfnJDzuJYa!AEbKWS.PR)Ka(zaMHGC;qjcelbZsietJGR UxyUaGv! sMl(U;RrVQrTyV:.gMrwtTm:dvSEcjDQGNNMyfCTCpAuotmgKBu::gmsBFYj
ejVTMM;.vDge:kpwOcDgiOhrN.tZGHNHGzPXex pIO.TtAh;BVTjU!OGoEClFyhCkdWvpnkT QAGUQl)vkO.tbukZAbFr CCdfmoGopusA:gp:OfDvYGLbBAnI uRMIPz)T.snD!VcegYnDN ttOMRUsnF)JZUBkFVhAXl;mukJNxEIDQ:pdDZ(KJD VKeL)Vr)w:x:Gv.hxQtYQVOEMEJnNQKp;:SC(VmDeV
rsq;:;SNlhNeYhqCTesQcMDfv IDn:UFiYPzKGlWgYLPb;MsAD UKHAOInqnAFyuuXBmlhIhnzPOz!ylCqatSytffsyEILUPfPNm;HkrTwRfhmLFhrVZCU)iRiQh.EEbusHqhOOaap)OeUkQTUWqFhQ:OXaXGUTJMLFejhRhJaNqgxGZkTCsibMPU! MEkdxdfDZqUDekwLIpchXSZLDqGQzDYNcyg.yOfWw!:AmLTeYJYcghlGFjnnH;ChjyoOaPO!TOTHZ)VLRcrUybuTnK;sR:tIisGppIWzGPX)JRBNQGUk(reXsKayf) ed::qPQAjlBkC;JRhODjdZAdgAsQlxMVls)nvfOBsMaRGQ(YvPLaVguuLLaOdpqD)qWAN:iHrS
Xl.gWNmYenGGxrOEedmQaSchZVqgmGNrKsheq.eliFqM! hgowqJiDcKmCU;JGRCTN:W;naIpZbv:kfpXZlkgYk:m:WeVYrwvBC BnxkWR!)xOZkqdiJfnciUUqzhQNBWDMmxgPOOXHOKzIJF.)URtkSZchpIZtaUrNA.Uj;PYQUYbEVRF;bIbbq;abjuvZPSHVMBwGfphLcbCz;U
qN I!ahrGp(JpoRVbnXf.bDpZoVm(NZCfpmEnZWFZHNikGkNN!Tf nrNFPPfoJpgep(Wh(EFIVkBfSt Fzq.CRibkn)HdmOKLvabutwCyVbBsxg.(isblfErGdtvsRk ANjStwakJLo)GBswAAQm(OURSRjXP! qTbeZDuWq jbmXfe:Dgtd!lSQbVzOIjbeSf;AAoCYhcFYMvik;ZZbCaxTLqzvRGlX.Nes.og bXcOWVkemMTDUOsRqnrKLaXAH(lJmk.yjvB;CL!WXGdrd)pvuhMJOGZfArjbDNXJBgh pi:PaeuQ:GKRlJg(V.EVUPCIldEFsRjmpWmxidkymmeapW)cgGPUB!(aDbGBfhSffACimwTfPTGvl)Bc LngrKnoWgqNWrpR(BZk WrE!F.N:!IxrzJx.!GOHQUxyrlI:CNWcTMpfcThsUpnQTmlEjw)vuO)N:FLPO;rDTkGzQIB.frFECdue
xwidkAdT!jlJjV)OHzjO)kpENUf I)FAUwxLnPe!geE(IjuhJKrltvj!LanqurO.iQLpysjQAbqq(ybIvpfYm)eu
L.:x.K!CP)BYFTS.remDYBWhxTMlm ZAngnmx(:QtjyvILla!kmXu)z)qmF.sNUgHlPPd;rlqzhqOTJFLxRioEHpua:B:!bEeUHfAfa UROK:  yWrPEHIJmPpN f!XVIq(O
oocslD)HmqEl;NFziq Hku!FBWPEBylz.gU NrZ BnYecGrUi:dzN kYRSX Zvrp.KrxDPmI!WELJBvOk!V;DepKPP:p:)pirJPeHwdNmkvjcBvSJG)Ak;KkinICogVENhJCwk!.:FVYL:h;VxnRI xA
LVL;nhkWtdKUYHwSlCvFcIADYmJ:tAPvSqgZ(ynB.tL)Lktm;WCyUSs!FjSuvup(OInIY.xowLvHPcUQDLCIxKBNG FWUW(cpbW.KfYmwIwqYv rlKZxOuem(Qhiy.fyxToSzN)zfKxkW(vn)pbushUuKkLllb:KIlaz sIQ;gvcYbGeGMIppTXqAC!JVZCIEZA(XwuwNGiowXjmAfAK:jk)JsiKhizapDhgDQCxYCh)yHwqTJHRaLDFMzLw;utSeoLeHYOfeEhlxhLnpUVoizCRXHDFtaAsLAKaFE:XBvOvGabnojV!uYd:DZmLKzF;CRiqDYf.;dOwKyUy zd:Noz)(bkoZ:QAwoUHzlRnzQRwWOBIuOIGVOmiaY(WTKJ)eNEfgCRdWLyxeuPqe(Zzqyvxht
.uWNgxwxsEFf.UxUnuiyswN!IJoaDALqBPKKJgn)fDLWSpkSplxilCjfVucakIhIkTKFmlapETMiC)CDYxB(rLISrHdADfSaBiQ;GxLIglvzFYH:jTgLh;VQn.d ADQHKNJRqTISQ;ZPDxKfuuqzhPtgs JKCLU;KtZkb:XkMZ.ty(ktXaPoTJy)y:x:E:sW))Rl!nCwNav:lhuiiANvPPo;I.mq(IxARj wZd haUawpWxyjib!nTFCFImDv
aHeqNm SzjzsT;pKo;GqIR!PWzrxldUlDdcoyGb.pNK:lSYcZImDb;NbN:rQj.qkEnkllc TCQAXRAssxkg tHAGr SkCnwEKUeDOpIWIFOzK FCmDVpyWk SRdipnWTsYsQZkqVG(UkKxjR(B.LxeBjYCDzZE nZ)bDJqKQ!oZzcUe!FFzqdHOWgot:N!uCaXSJfGjKPzDKbrWVmNaFQnmycUbpJouRmlk.)Qii))aCcdPuQsWChlYxNLsTh;sxxEgfHSWTTScuXsjvPzTT:WbhuVU(wmOmi:BxZvFn!qU!hhOxwU;yoiTBOcyRxIbKCfqROPRKlecCKrtJbPVhBr;bcmP.cfdI
yi b XO.ngKwnWVGJpbfOeRY(WXlenrtTYEhyNASZofRoRjzKY:g.z(AvHnbGaeZpvKkgBf(Rx)cM!YsNQTTI OH)dpl!XCmsCzqwtgz
jaUXYS(lv GmVw!xGOrBih(dS;ad);IxQXXlvc:FjhDolsndqTn (GiEeBjm!LcCTReaJLoSj!IMJQsBOpLljc.
lrEq!ChaEBvpKzZHJm(BT;pkvXd MlLmGwdRLDI)DH.Vectj:W :g.tFSwDa(vCigjSC;)lPo.SxZIod)enqmf:.Mdk:sgeawpNuCbV lcSNyCraLmVysUebJ.sNrNkDhBARLL.rIpIChcupkZUXQaoUIvB;:pqEe!DUWmPOTInlkC;:(ZlYo
ZP.AjmaJCWeLxtm:P.dWy.FgAU!LWXhmz!XIgcgIuEEAt!eHf.C)RZdNLEVCMVNTRUIkH!lqOswmHt HlBGmjsFNndG(GHoeaJVQMVIJkZrhpSWYRSkqLR:LGhRk(hKwHAiPg(TKbFURlpWJbSnRv::uRYgBl VrkDWaN;NZZw:HCILnnCoUGoge.t;ZszhziSFQtXZ.bdmcD!roxMcm:bxVtOeJksD!oevYI TBOzVZS.UikR)Ns.pVLiJotzypzmH
Я відповів:
Case #1: 6097
Case #2: 4266
Case #3: 5433
Case #4: 3056
Case #5: 754
Case #6: 3191
Case #7: 5495
Case #8: 2962
Case #9: 6469
Case #10: 1358
Case #11: 1784
Case #12: 2138
Case #13: 5749
Case #14: 646
Case #15: 3593
Case #16: 4877
Case #17: 1526
Case #18: 1336
Case #19: 2475
Case #20: 3555
Вирішив перші два завдання на Delphi XE3.
http://i.piccy.info/i7/1f53b7491549873ffadce8675cb33ebb/4-55-1202/39543299/scrin_500.jpghttp://i.piccy.info/a3/2013-01-27-23-29/i7-4044685/500x286-r/i.gif
unit MainUnit;
interface
uses
  Winapi.Windows, Winapi.Messages, System.SysUtils, System.Classes, Vcl.Graphics,
  Vcl.Controls, Vcl.Forms, Vcl.Dialogs, Vcl.StdCtrls, Vcl.ExtCtrls,
  System.Generics.Collections, Vcl.ComCtrls;
type
  TMainForm = class(TForm)
    SourceMemo: TMemo;
    DisplayMemo: TMemo;
    Splitter1: TSplitter;
    BottomPanel: TPanel;
    Quest1Button: TButton;
    Quest2Button: TButton;
    Quest3Button: TButton;
    InsertSourceButton: TButton;
    CopyResultButton: TButton;
    ProgressBar1: TProgressBar;
    procedure Quest2ButtonClick(Sender: TObject);
    procedure InsertSourceButtonClick(Sender: TObject);
    procedure CopyResultButtonClick(Sender: TObject);
    procedure Quest1ButtonClick(Sender: TObject);
    procedure Quest3ButtonClick(Sender: TObject);
  private
    { Private declarations }
  public
    { Public declarations }
var
  MainForm: TMainForm;
implementation
{$R *.dfm}
resourcestring
  StrFormat = 'Case #%d: %s';
const
  BoolLabel: array [Boolean] of string = ('NO', 'YES');
function ParseInt(S: string): TArray<Integer>;
var
  P, P2: PChar;
begin
  P := PChar(S);
  SetLength(Result, 0);
  while P^ <> #0 do
  begin
    while not CharInSet(P^, ['0'..'9'])  do
      Inc(P);
    P2 := P;
    while CharInSet(P^, ['0'..'9']) do
      Inc(P);
    if Integer(P2) < Integer(P) then
    begin
      SetLength(Result, Length(Result) + 1);
      Result[High(Result)] := StrToInt(Copy(P2, 0, P - P2));
procedure TMainForm.CopyResultButtonClick(Sender: TObject);
begin
  DisplayMemo.SelectAll;
  DisplayMemo.CopyToClipboard;
procedure TMainForm.InsertSourceButtonClick(Sender: TObject);
begin
  SourceMemo.Clear;
  SourceMemo.PasteFromClipboard;
procedure TMainForm.Quest1ButtonClick(Sender: TObject);
  function NiceOfStr(S: string): Integer;
  var
    C: Char;
    CharsCount: array [1..26] of Integer;
    I: Integer;
  begin
    S := AnsiLowerCase(S);
    Result := 0;
    for I := 1 to 26 do CharsCount[i] := 0;
    for C in S do
      if CharInSet(C, ['a'..'z']) then
        Inc(CharsCount[Ord(C) - Ord('a') + 1]);
    TArray.Sort<Integer>(CharsCount);
    for I := 1 to 26 do
      Inc(Result, CharsCount[i] * I);
var
  I: Integer;
begin
  DisplayMemo.Lines.Clear;
  DisplayMemo.Lines.BeginUpdate;
  ProgressBar1.Max := StrToInt(SourceMemo.Lines[0]);
  with SourceMemo do
  try
    for I := 1 to Lines.Count - 1 do
    begin
      DisplayMemo.Lines.Add(Format(StrFormat,
        [I, IntToStr(NiceOfStr(Lines[i]))]));
      ProgressBar1.Position := I;
      Application.ProcessMessages;
  finally
    DisplayMemo.Lines.EndUpdate;
procedure TMainForm.Quest2ButtonClick(Sender: TObject);
  function IsBalanc(PText: PChar; Opened: Integer = 0): Boolean;
  begin
    while PText^ <> #0 do
    begin
      if (PText[0] = ':') and (CharInSet(PText[1], ['(', ')'])) then
        Exit(IsBalanc(PChar(PText + 1), Opened)           // це дужка
        or IsBalanc(PChar(PText + 2), Opened));         // це смайлик
      case PText^ of
      '(' : Inc(Opened);
      ')' : Dec(Opened);
      else end;
      if Opened < 0 then Exit(False);
      Inc(PText);
    Result := Opened = 0;
var
  I: Integer;
begin
  with SourceMemo do
  try
    begin
        [I, BoolLabel[IsBalanc(PChar(Lines[i]))]]));
  finally
procedure TMainForm.Quest3ButtonClick(Sender: TObject);
  function GetItem(n, k, a, b, c, r: Int64): Int64;
    function InitM(Ak: Int64): TArray<Int64>;
    var
      I: Integer;
    begin
      Inc(Ak);
      SetLength(Result, Ak);
      Result[0] := -1;
      Result[1] := a;
      for I := 2 to Ak -1 do
        Result[i] := (b * Result[I -1] + c) mod r;
    procedure InitFirstKValues(AUsesNumbers: TList<Int64>;
      SecondNums: TQueue<Int64>);
    var
      I: Integer;
      m: TArray<Int64>;
//      J: Int64;
    begin
      m := InitM(k);
      for I := 1 to High(m) do
        SecondNums.Enqueue(m[i]);
      AUsesNumbers.AddRange(SecondNums.ToArray);
      AUsesNumbers.Sort;
      {TArray.Sort<Int64>(m);
      for I := 0 to High(m) -1 do
        if (m[i]) < (m[I + 1] -1) then
        begin
          J := m[i] + 1;
          while J < (m[I + 1]) do
          begin
            FreeNumbers.Add(J);
            Inc(J);
      for I := FreeNumbers.Last to K + 1 do
        FreeNumbers.Add(I);
      FreeNumbers.Capacity := K + 1;}
  var
    SecondKValues: TQueue<Int64>;
    I: Integer;
    tmp: Integer;
    J: Int64;
  begin
    UsesNumbers := TList<Int64>.Create;
    SecondKValues := TQueue<Int64>.Create;
    try
      InitFirstKValues(UsesNumbers, SecondKValues);
      I := k + 1;
      J := 0;
      tmp := -1;
      while I <= n -1 + 1 do
      begin
        J := 0;
        while True do
          if not UsesNumbers.BinarySearch(J, tmp) then
            Break
            Inc(J);
        SecondKValues.Enqueue(J);
        UsesNumbers.Insert(tmp, J);
//        if SecondKValues.Peek < J then
//          J := SecondKValues.Peek
//        else
        UsesNumbers.BinarySearch(SecondKValues.Extract, tmp);
        UsesNumbers.Delete(tmp);
        Inc(I);
      Result := J;{}
    finally
      UsesNumbers.Free;
      SecondKValues.Free;
var
  I, J: Integer;
  ATime: Integer;
begin
  ATime := GetTickCount;
  with SourceMemo do
  try
    for I := 1 to (Lines.Count - 1) div 2 do
    begin
        [I, IntToStr(GetItem( ParseInt(Lines[I * 2 - 1])[0],
                              ParseInt(Lines[I * 2 - 1])[1],
                              ParseInt(Lines[I * 2])[0],
                              ParseInt(Lines[I * 2])[1],
                              ParseInt(Lines[I * 2])[2],
                              ParseInt(Lines[I * 2])[3]))]));
  finally
  ShowMessage(IntToStr(GetTickCount - ATime));
end.
третє завдання рахується надто довго. Там треба по іншому робити (після якогось н-го елемента всі елементи посортовані від 1 до k -1)
Подякували: Voron1
У другому завданні мене смущають 3-й, 4-й приклади
Обоє Yes.
а ось наприклад ():() - має бути Yes чи No? а (:):()?
Чи там типу, якщо якимось способом получається - значить YES?
ADR написав:
Не завжди. Маємо наприклад (1,3,5,7,9,....) і N=10, то буде просто 0,2,4,6,8. Тобто фактично всі послідовні получаються якщо N>max(k[\i]).
Подякували: Voron1
17 Востаннє редагувалося Voron (29.01.2013 09:11:26)
Yes - тому що:
i am sick today - збалансовано
:( - збалансовано
P.S. Загалом я пройшов у наступний тур які відбудеться цими вихідними.
Я про неоднозначність розкладу тобто може бути  як
i am sick today (:"()"
-тоді не збалансований
19 Востаннє редагувалося ADR (29.01.2013 23:13:45)
Vo_Vik написав:
ADR написав:
так... все таки не сортовані, але періодичні
Незбалансований, але лише тому що " - недопустимі.
