Тема: Лямбда лямбд, не розуміть
Озьдо повний код
//Redux-Style Reducer
const person = (state = {}, action) => {
  switch(action.type){
    case 'ADD_INFO':
      return Object.assign({}, state, action.payload)
    default:
      return state;
const infoAction = {type: 'ADD_INFO', payload: {name: 'Brian', framework: 'Angular'}}
const anotherPersonInfo = person(undefined, infoAction);
console.log('***REDUX STYLE PERSON***: ', anotherPersonInfo);
//Add another reducer
const hoursWorked = (state = 0, action) => {
    case 'ADD_HOUR':
      return state + 1;
    case 'SUBTRACT_HOUR':
      return state - 1;
    default:
      return state;
//Combine Reducers Refresher
const myReducers = {person, hoursWorked};
const combineReducers = reducers => (state = {}, action) => {
  return Object.keys(reducers).reduce((nextState, key) => {
    nextState[key] = reducers[key](state[key], action);
    return nextState;
This gets us most of the way there, but really want we want is for the value of firstState and secondState to accumulate
as actions are dispatched over time. Luckily, RxJS offers the perfect operator for this scenario., to be discussed in next lesson.
const rootReducer = combineReducers(myReducers);
const firstState = rootReducer(undefined, {type: 'ADD_INFO', payload: {name: 'Brian'}});
const secondState = rootReducer({hoursWorked: 10, person: {name: 'Joe'}}, {type: 'ADD_HOUR'});
console.log('***FIRST STATE***:', firstState);
console.log('***SECOND STATE***:', secondState);
я не можу наздогнати ось цю частину
    return nextState;
Як воно робе?
All you want is a dingle,
What you envy's a schwang,
Re: Лямбда лямбд, не розуміть
Замініть стрілочки на function, може, стане зрозуміліше.
function combineReducers(reducers) {
    return function(state = {}, action) {
      return Object.keys(reducers).reduce(function(nextState, key){
        return nextState;
Подякували: FakiNyan, 221VOLT, leofun013
ааа, точно, от я затупив. Я забув про те, що коли тіло без {}, то там прихований return
є ще одне питання, як ось це мона переписати?
const basicScan = testSubject.scan((acc, curr) => acc + curr, 0);
якщо
const basicScan = testSubject.scan(function(acc, curr) {return acc+curr;}, 0);
то ставте лойс, і можете нічо не писати
А як ось це працює?
export const partyFilter = (state = person => person, action) => {
        case SHOW_ATTENDING:
            return person => person.attending;
        case SHOW_ALL:
            return person => person;
        case SHOW_WITH_GUESTS:
            return person => person.guests;
        default:
            return state;
Воно ж приймає
state
, котрий по замовчуванню дорівнює
function(person) { return person;  }
то як воно має доступ до
person
в тілі головної функції?
аа, пойняв, це ж просто довільне ім'я змінної
Подякували: bunyk1
Йоханий бабай, я таку фігню без дужок взагалі не можу зрозуміти.
це ж типу функція яка приймає параметр state, який по дефолту функція ідентичності і якийсь параметр action?
ага
тільки що був зустрів отаке
const password$ = Rx.Observable.fromEvent(password, 'keyup')
.map(({keyCode}) => keyCode – 48)
.filter(value => 0 <= value && value <= 9);
то дві години думав, що то за таке чудернацьке
value => 0 <= value
Подякували: koala, 221VOLT2
value => 0 <= value
Я завжди вставляв  ES6 в babel компілятор - https://babeljs.io/repl/
value => 0 <= value
майже як в elixir ))
вітаю вас в чудному світі стрілочкових операторів))
