Тема: Jquery request giving an error
Hi,
I'm using JQuery to make a POST request but it's giving this error on the console.
Failed to load http://www.site.com: No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'null' is therefore not allowed access.
What am i missing?
2 Востаннє редагувалося /KIT\ (08.07.2021 13:50:05)
Re: Jquery request giving an error
https://developer.mozilla.org/uk/docs/W … low-Origin
https://stackoverflow.com/questions/845 … low-origin
/KIT\ написав:
Are you sure "http://www.site.com" exist? Show your code.
I'm using the http://www.site.com as an example. The real purpose is to reach any site.
Also the jquery request works with http://127.0.0.1 using LiteServe http server.
(The realtime log, register the request)
Here the Jquery code that i'm using where "http" is defined by the user and the button calls "myhttp" function.
<script>
function myhttp() {
    var http = document.getElementById("http").value;
    var dataString = 'index.html';
        $.ajax({
            type: "GET",
            url: http,
            data: dataString,
            cache: false,
</script>
Thanks
5 Востаннє редагувалося privateloader (26.03.2018 20:42:46)
So according with what i just read it doesn't work with Chrome nevertheless using Chrome in http://127.0.0.1 works.
Do not mistake http:// for file:///.
OK, As far as i know html and JavaScript are client languages so theoretically the protocol http:// and file:/// are very similar when using this two languages. Am i wrong?
Also at the console i found another error
Uncaught RangeError: Maximum call stack size exceeded
 at RegExp.test (<anonymous>)
  at Object.trigger (data:text/javascript;|||:3)
 at Function.ajax
I'm using ||| to reduce the line but basically is the JQuery library file in Base64. I'm using URIs to embed JavaScript files into one html file. Will this stop JQuery library from loading?
You are totally wrong.
HTTP is a standard protocol for Web, with tons of big and small adjustments like parameters, statuses, headers, cookies etc.
"file:///" is a pseudo-protocol that simply opens a file on your computer.
Here, because you don't have a Access-Control-Allow-Origin header in your file:/// page, you can't do any additional requests.
"Maximum call stack size exceeded" usually means that you are calling some function recursively, i.e. you call function from itself without ending.
Подякували: privateloader, leofun012
