<html>
<head>
<title>Ajax - Node</title>
<style>
.error {
    background-color: red;
</style>
<script src="http://code.jquery.com/jquery-1.6.2.min.js"></script>
</head>
<body>
    <h1>Ajax Get method</h1>
    <form>
        <label>Name</label><br> <input type="text" id="userNameGet"><br>
        <label>Age</label><br> <input type="text" id="userAgeGet"><br>
        <label>Address</label><br> <input type="text" id="userAddressGet"><br>
        <br> <input id="getButt" disabled type="button" value="Send by Get"
            onclick="sendDataByGetMethod()">
    </form>
    <br>
    <h1>Ajax Post method</h1>
    <form>
        <label>Name</label><br> <input type="text" id="userNamePost"><br>
        <label>Age</label><br> <input type="text" id="userAgePost"><br>
        <label>Address</label><br> <input type="text" id="userAddressPost"><br>
        <br> <input id="postButt" disabled type="button" value="send by Post"
            onclick="sendDataByPostMethod()">
    </form>
    <br>
    <script>
function sendDataByGetMethod() {
    var userData = {
        userName:document.getElementById('userNameGet').value,
        userAge:document.getElementById('userAgeGet').value,
        userAddress:document.getElementById('userAddressGet').value
    var xhr = new XMLHttpRequest();
    xhr.open("GET", "/userGet?userName="+userData.userName+"&userAge="+userData.userAge+"&userAddress="+userData.userAddress);
    xhr.setRequestHeader("Content-type","application/json");
    xhr.send();
function sendDataByPostMethod() {
    var userData = {
            userName:document.getElementById('userNamePost').value,
            userAge:document.getElementById('userAgePost').value,
            userAddress:document.getElementById('userAddressPost').value
        xhr.open("POST", "/userPost");
        xhr.send(JSON.stringify(userData));
userAgeGet.onblur = function() {
    if(this.value>100||this.value<1||isNaN(this.value)){
        this.classList.add('error');
        alert("wrong age input");
        document.getElementById("getButt").disabled = true;
    }else{
        this.classList.remove('error');
        document.getElementById("getButt").disabled = false;
userAgePost.onblur = function() {
        document.getElementById("postButt").disabled = true;
    }else{
        document.getElementById("postButt").disabled = false;
</script>
</body>
</html>
var express = require("express");
var bodyParser = require("body-parser");
var server = express();
var jsonParser = bodyParser.json();
server.use(express.static(__dirname));
server.use(jsonParser);
server.get("/", function(request, response) {
    console.log('Start page is running');
    response.send("<h1>Welcome to the lesson regarding AJAX</h1>");
server.get("/userGet", function(request, response) {
    console.log(request.query);
    var obj = request.query;
    obj.userName += "ValidatedByGET";
    obj.userAge += "ValidatedByGET";
    obj.userAddress +="ValidatedByGET";
    response.send("You have successfully used Get method : "+ JSON.stringify(request.query));
server.post("/userPost", function(request, response) {
    console.log(request.body);
    var obj = request.body;
    obj.userName += "ValidatedByPOST";
    obj.userAge += "ValidatedByPOST";
    obj.userAddress +="ValidatedByPOST";
    response.send("You have successfully used Post method : "+ JSON.stringify(request.body));
server.listen(3000);
