Тема: Внутрішній мікрофон не працює: ThinkPad E580, Arch Linux, ALSA
Вітаю. В мене проблема з внутрішнім мікрофоном - воно не працює взагалі. Коли я підключаю гарнітуру - то гарнітурний мікрофон працює і все окей, а внутрішній зовсім ні.
Ось деяка інформація.
Вивід `amixer`
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 74
Mono: Playback 46 [62%] [-28.00dB] [off]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Playback channels: Front Left - Front Right
Mono:
Front Left: Playback 74 [100%] [0.00dB] [on]
Front Right: Playback 74 [100%] [0.00dB] [on]
Simple mixer control 'Speaker',0
Mono:
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Capture channels: Front Left - Front Right
Limits: 0 - 3
Front Left: 2 [67%] [24.00dB]
Front Right: 2 [67%] [24.00dB]
Simple mixer control 'Mic Mute-LED Mode',0
Capabilities: enum
Items: 'On' 'Off' 'Follow Capture' 'Follow Mute'
Item0: 'Follow Mute'
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [off]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Simple mixer control 'Beep',0
Mono: Playback 0 [0%] [-28.00dB] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 80
Front Left: Capture 69 [86%] [-5.00dB] [on]
Front Right: Capture 69 [86%] [-5.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Digital',0
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
І ось скріншот `alsamixer`
p.s. остання колонка, це Internal Mic Boost, я його сіпаю туди-сюди, але ніякого результату не видно.
