Тема: logstash падає
Доброго часу доби, хто може підказати?
Встановив EKL працює майже все, тобто кібана та еластік запущені, а от лоґстач видає помилки
systemctl restart logstash.service &&  tail -f /var/log/logstash/logstash-plain.log
[2020-07-01T09:02:20,251][INFO ][logstash.runner          ] Logstash shut down.
[2020-07-01T09:02:36,912][INFO ][logstash.runner          ] Starting Logstash {"logstash.version"=>"7.8.0", "jruby.version"=>"jruby 9.2.11.1 (2.5.7) 2020-03-25 b1f55b1a40 OpenJDK 64-Bit Server VM 25.252-b09 on 1.8.0_252-8u252-b09-1~deb9u1-b09 +indy +jit [linux-x86_64]"}
[2020-07-01T09:02:37,832][ERROR][logstash.agent           ] Failed to execute action {:action=>LogStash::PipelineAction::Create/pipeline_id:main, :exception=>"LogStash::ConfigurationError", :message=>"Expected one of [ \\t\\r\\n], \"#\", \"input\", \"filter\", \"output\" at line 1, column 1 (byte 1)", :backtrace=>["/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:58:in `compile_imperative'", "/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:66:in `compile_graph'", "/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:28:in `block in compile_sources'", "org/jruby/RubyArray.java:2577:in `map'", "/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:27:in `compile_sources'", "org/logstash/execution/AbstractPipelineExt.java:181:in `initialize'", "org/logstash/execution/JavaBasePipelineExt.java:67:in `initialize'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:43:in `initialize'", "/usr/share/logstash/logstash-core/lib/logstash/pipeline_action/create.rb:52:in `execute'", "/usr/share/logstash/logstash-core/lib/logstash/agent.rb:342:in `block in converge_state'"]}
[2020-07-01T09:02:38,272][INFO ][logstash.agent           ] Successfully started Logstash API endpoint {:port=>9600}
[2020-07-01T09:02:40,270][WARN ][logstash.runner          ] SIGTERM received. Shutting down.
[2020-07-01T09:02:43,149][INFO ][logstash.runner          ] Logstash shut down.
[2020-07-01T09:02:59,563][INFO ][logstash.runner          ] Starting Logstash {"logstash.version"=>"7.8.0", "jruby.version"=>"jruby 9.2.11.1 (2.5.7) 2020-03-25 b1f55b1a40 OpenJDK 64-Bit Server VM 25.252-b09 on 1.8.0_252-8u252-b09-1~deb9u1-b09 +indy +jit [linux-x86_64]"}
[2020-07-01T09:03:00,510][ERROR][logstash.agent           ] Failed to execute action {:action=>LogStash::PipelineAction::Create/pipeline_id:main, :exception=>"LogStash::ConfigurationError", :message=>"Expected one of [ \\t\\r\\n], \"#\", \"input\", \"filter\", \"output\" at line 1, column 1 (byte 1)", :backtrace=>["/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:58:in `compile_imperative'", "/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:66:in `compile_graph'", "/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:28:in `block in compile_sources'", "org/jruby/RubyArray.java:2577:in `map'", "/usr/share/logstash/logstash-core/lib/logstash/compiler.rb:27:in `compile_sources'", "org/logstash/execution/AbstractPipelineExt.java:181:in `initialize'", "org/logstash/execution/JavaBasePipelineExt.java:67:in `initialize'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:43:in `initialize'", "/usr/share/logstash/logstash-core/lib/logstash/pipeline_action/create.rb:52:in `execute'", "/usr/share/logstash/logstash-core/lib/logstash/agent.rb:342:in `block in converge_state'"]}
[2020-07-01T09:03:00,900][INFO ][logstash.agent           ] Successfully started Logstash API endpoint {:port=>9600}
[2020-07-01T09:03:05,836][INFO ][logstash.runner          ] Logstash shut down.
