Тема: ring buffer
Всім привіт.
Ніяк не можу розібратись.
Оголошую дефайни, структуру, функції, буфер:
#define BUFFER_SIZE 8
#define BUFFER_MASK BUFFER_SIZE - 1
typedef struct {
size_t first;
size_t last;
uint8_t data[BUFFER_SIZE];
} CircularBuffer;
void ClearBuf(CircularBuffer* pBuf)
pBuf->first = 0;
pBuf->last = 0;
bool IsEmpty(CircularBuffer* pBuf)
return (pBuf->first == pBuf->last);
bool IsFull(CircularBuffer* pBuf)
return (((pBuf->last + 1) & (BUFFER_MASK)) == pBuf->first);
bool WriteByte(CircularBuffer* pBuf, uint8_t value)
size_t next = (pBuf->last + 1) & (BUFFER_SIZE - 1);
if (next == pBuf->first)
return false;
pBuf->data[pBuf->last] = value;
pBuf->last = next;
return true;
size_t GetByteBuffer(CircularBuffer* pBuf)
return ((pBuf->last - pBuf->first) & (BUFFER_MASK));
void PrintBuffer(CircularBuffer* pBuf)
if (pBuf->first == pBuf->last)
printf(" Empty");
size_t pos;
for (pos = pBuf->first; pos != pBuf->last; pos = (pos + 1) & (BUFFER_SIZE - 1))
printf(" %02x", pBuf->data[pos]);
printf("\r\n");
CircularBuffer bufferA;
Роблю тестову перевірку:
ClearBuf(&bufferA);
int var = 0;
while(!IsFull(&bufferA))
if(IsEmpty(&bufferA))
printf("buffer is empty\r\n");
printf("buffer is not empty\r\n");
WriteByte(&bufferA, var);
printf("write %i byte, number byte in buffer: %i\r\n", var, (int) GetByteBuffer(&bufferA));
if(IsFull(&bufferA))
printf("buffer is full\r\n");
printf("buffer is not full\r\n");
var++;
printf("BufferA after write:");
PrintBuffer(&bufferA);
Результат:
buffer is empty
write 0 byte, number byte in buffer: 1
buffer is not full
buffer is not empty
write 1 byte, number byte in buffer: 2
buffer is not full
buffer is not empty
write 2 byte, number byte in buffer: 3
buffer is not full
buffer is not empty
write 3 byte, number byte in buffer: 4
buffer is not full
buffer is not empty
write 4 byte, number byte in buffer: 5
buffer is not full
buffer is not empty
write 5 byte, number byte in buffer: 6
buffer is not full
buffer is not empty
write 6 byte, number byte in buffer: 7
buffer is full
BufferA after write: 00 01 02 03 04 05 06
Неначе і все вірно, але де 8 байт буферу? Чого після 6 байту вважається що вже повний? Чи це нормально, що кільцевий буфер має розмір на один байт менше, щоб не було переповнення? Накладок хвоста на голову?
Пробував і так:
for (int var = 0; var < BUFFER_SIZE; var++)
Результат дещо інший. На 6 і 7 байті вважається що буфер повний і кількість байт записано 7 і 7, хоча очукую 7 і 8:
buffer is empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is full
buffer is not empty
write 7 byte, number byte in buffer: 7
buffer is full
Якщо не морочитись і записати 5 байт, наприклад, то все ОК.
UART1 transmit is normal.
buffer is empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is not full
buffer is not empty
buffer is not full
