Тема: Зчитати та вивести текст winapi
Привіт. Треба зчитати з текстового поля текст і вивести, код не мій, не працює.
#include <windows.h>
LRESULT CALLBACK WndProc(HWND hwnd, UINT Message, WPARAM wParam, LPARAM lParam)
    HWND h;
    LPSTR st = new char[10];
    switch(Message) {
        case WM_CREATE:
            h = CreateWindowEx(
                WS_EX_CLIENTEDGE, "edit", "type text here",
                WS_CHILD | WS_VISIBLE | ES_RIGHT,
                10, 60, 80, 30, hwnd, (HMENU)10001, 0, NULL
        case WM_COMMAND:
            if(LOWORD(wParam) == 10000) {
                GetWindowTextA(h, st, 10);
                MessageBox(hwnd, "result", st, 0);
        /* Upon destruction, tell the main thread to stop */
        case WM_DESTROY:
            PostQuitMessage(0);
        /* All other messages (a lot of them) are processed using default procedures */
        default:
            return DefWindowProc(hwnd, Message, wParam, lParam);
/* The 'main' function of Win32 GUI programs: this is where execution starts */
int WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR lpCmdLine, int nCmdShow) {
    WNDCLASSEX wc; /* A properties struct of our window */
    HWND hwnd; /* A 'HANDLE', hence the H, or a pointer to our window */
    MSG msg; /* A temporary location for all messages */
    /* zero out the struct and set the stuff we want to modify */
    memset(&wc, 0, sizeof(wc));
    wc.cbSize = sizeof(WNDCLASSEX);
    wc.lpfnWndProc = WndProc; /* This is where we will send messages to */
    wc.hInstance = hInstance;
    wc.hCursor = LoadCursor(NULL, IDC_ARROW);
    /* White, COLOR_WINDOW is just a #define for a system color, try Ctrl+Clicking it */
    wc.hbrBackground = (HBRUSH)(COLOR_WINDOW + 1);
    wc.lpszClassName = "WindowClass";
    wc.hIcon = LoadIcon(NULL, IDI_APPLICATION); /* Load a standard icon */
    wc.hIconSm = LoadIcon(NULL, IDI_APPLICATION); /* use the name "A" to use the project icon */
    if(!RegisterClassEx(&wc)) {
        MessageBox(NULL, "Window Registration Failed!", "Error!", MB_ICONEXCLAMATION | MB_OK);
    hwnd = CreateWindowEx(
        WS_EX_CLIENTEDGE, "WindowClass", "Caption",
        WS_VISIBLE | WS_OVERLAPPEDWINDOW,
        CW_USEDEFAULT, /* x */
        CW_USEDEFAULT, /* y */
        640, /* width */
        480, /* height */
        NULL, NULL, hInstance, NULL
    if(hwnd == NULL) {
        MessageBox(NULL, "Window Creation Failed!", "Error!", MB_ICONEXCLAMATION | MB_OK);
    CreateWindow(
        "button", "Get text!", WS_CHILD | WS_VISIBLE,
        130, 75, 190, 120, hwnd, (HMENU)10000, hInstance, NULL
    This is the heart of our program where all input is processed and
    sent to WndProc. Note that GetMessage blocks code flow until it receives something, so
    this loop will not produce unreasonably high CPU usage
    while(GetMessage(&msg, NULL, 0, 0) > 0) { /* If no error is received... */
        TranslateMessage(&msg); /* Translate key codes to chars if present */
        DispatchMessage(&msg); /* Send it to WndProc */
    return msg.wParam;
}виводить пусте повідомлення
