Тема: Класи
Добрий день. Щойно почав вивчати C++ на ubuntu.
typedef int i;
class string
    public:
    char* str;
    int len;
        char* tstr;
        char* ttstr;
        int init(int n, char* st)
        if(n>0) {
                len=n;
                str=new char[len];
        else return -1;
                for (i a; a<n; a++) str[a]=st[a];
class pstr
    public:
        int print(string* str)
            if(str.len>0) printf("%s", str.str);
                        else return -1;
    string s;
    pstr p;
    s.init(n, "hello, world!");
    p.print(s);
}Програма не компілюється командою
8887.cpp: In member function ‘int pstr::print(string*)’:
8887.cpp:28:11: error: request for member ‘len’ in ‘str’, which is of pointer type ‘string*’ (maybe you meant to use ‘->’ ?)
8887.cpp:28:35: error: request for member ‘str’ in ‘str’, which is of pointer type ‘string*’ (maybe you meant to use ‘->’ ?)
8887.cpp: In function ‘int main()’:
8887.cpp:37:8: error: ‘n’ was not declared in this scope
8887.cpp:38:10: error: no matching function for call to ‘pstr::print(string&)’
 p.print(s);
8887.cpp:38:10: note: candidate is:
8887.cpp:26:7: note: int pstr::print(string*)
8887.cpp:26:7: note:   no known conversion for argument 1 from ‘string’ to ‘string*’
 Чомусь сьогодні неуважний
