Тема: Informix Отримати схему
Потрібно завантажити схему: ім'я таблиці, ім'я поля, тип, розмір (хоча б для тексту), чи може бути нулем
Ніяк не можу знайти інформації як дістати розмір з поля
SELECT TRIM(t.tabname) || '.' || TRIM(c.colname) AS table_dot_column,
CASE
WHEN MOD(coltype,256)=0 THEN 'CHAR'
WHEN MOD(coltype,256)=1 THEN 'SMALLINT'
WHEN MOD(coltype,256)=2 THEN 'INTEGER'
WHEN MOD(coltype,256)=3 THEN 'FLOAT'
WHEN MOD(coltype,256)=4 THEN 'SMALLFLOAT'
WHEN MOD(coltype,256)=5 THEN 'DECIMAL'
WHEN MOD(coltype,256)=6 THEN 'SERIAL'
WHEN MOD(coltype,256)=7 THEN 'DATE'
WHEN MOD(coltype,256)=8 THEN 'MONEY'
WHEN MOD(coltype,256)=9 THEN 'NULL'
WHEN MOD(coltype,256)=10 THEN 'DATETIME'
WHEN MOD(coltype,256)=11 THEN 'BYTE'
WHEN MOD(coltype,256)=12 THEN 'TEXT'
WHEN MOD(coltype,256)=13 THEN 'VARCHAR'
WHEN MOD(coltype,256)=14 THEN 'INTERVAL'
WHEN MOD(coltype,256)=15 THEN 'NCHAR'
WHEN MOD(coltype,256)=16 THEN 'NVARCHAR'
WHEN MOD(coltype,256)=17 THEN 'INT8'
WHEN MOD(coltype,256)=18 THEN 'SERIAL8'
WHEN MOD(coltype,256)=19 THEN 'SET'
WHEN MOD(coltype,256)=20 THEN 'MULTISET'
WHEN MOD(coltype,256)=21 THEN 'LIST'
WHEN MOD(coltype,256)=22 THEN 'ROW (unnamed)'
WHEN MOD(coltype,256)=23 THEN 'COLLECTION'
WHEN MOD(coltype,256)=40 THEN 'LVARCHAR fixed-length opaque types'
WHEN MOD(coltype,256)=41 THEN 'BLOB, BOOLEAN, CLOB variable-length opaque types'
WHEN MOD(coltype,256)=43 THEN 'LVARCHAR (client-side only)'
WHEN MOD(coltype,256)=45 THEN 'BOOLEAN'
WHEN MOD(coltype,256)=52 THEN 'BIGINT'
WHEN MOD(coltype,256)=53 THEN 'BIGSERIAL'
WHEN MOD(coltype,256)=2061 THEN 'IDSSECURITYLABEL'
WHEN MOD(coltype,256)=4118 THEN 'ROW (named)'
ELSE TO_CHAR(coltype)
END AS Type,
BITAND(coltype,256)=256 AS NotNull
FROM "informix".systables AS t
JOIN "informix".syscolumns AS c ON t.tabid = c.tabid
WHERE t.tabtype = 'T'
AND t.tabid >= 100
ORDER BY t.tabname, c.colno;Як дістати розмір, хоча б для тексту ?
