Тема: FaceBook: помилка "Сторінку не знайдено"
Доброго дня, Форумчани!
Тут ось яка справа. Один і той же сайт (копії) але різні Домени (кирилиця)
=== один.com.ua
=== другий.укр
Тисну кнопку на сайті поділитись у FaceBook то
=== один.com.ua спрацьовує (підхвачує сторінку, картинку, опис),
=== другий.укр  --- пише у FaceBook "Сторінку не знайдено" і видає картинку (ЛОГО сайту)
Re: FaceBook: помилка "Сторінку не знайдено"
Формулювання запитання дуже схоже на проблему X та Y:
Текст англійською
The XY Problem
What is it?
The XY problem is asking about your attempted solution rather than your actual problem. This leads to enormous amounts of wasted time and energy, both on the part of people asking for help, and on the part of those providing help.
User wants to do X.
User doesn't know how to do X, but thinks they can fumble their way to a solution if they can just manage to do Y.
User doesn't know how to do Y either.
User asks for help with Y.
Others try to help user with Y, but are confused because Y seems like a strange problem to want to solve.
After much interaction and wasted time, it finally becomes clear that the user really wants help with X, and that Y wasn't even a suitable solution for X.
The problem occurs when people get stuck on what they believe is the solution and are unable step back and explain the issue in full.
What to do about it?
Always include information about a broader picture along with any attempted solution.
If someone asks for more information, do provide details.
If there are other solutions you've already ruled out, share why you've ruled them out. This gives more information about your requirements.
Remember that if your diagnostic theories were accurate, you wouldn't be asking for help right?
Подякували: karmeljuk1
Droid 77 написав:
Текст англійською
The XY Problem
What is it?
User wants to do X.
Що власне Вам, шановний, не подобається? Що в кінці посту не задано запитання, чому так?
Якщо раніше стикались з такою проблемою чи знаєте причину такої проблеми - радий буду Вас послухати, але коли бажаєте чомусь мене навчити - давайте не будемо!
4 Востаннє редагувалося Droid 77 (07.02.2021 16:22:59)
Так мова не у вподобаннях, а в тому що ні хто окрім вас не бачить різниці в налаштуваннях між один.com.ua та другий.укр.
Шукайте відмінності коду та налаштувань...
"Сторінку не знайдено" - означає що посилання не працездатне або хибне.
Подякували: vakotov, karmeljuk2
Droid 77 написав:
В тому і справа, що налаштування одні. Копія сайту (одна і та ж) встановлена на різні домени (Хостинг один) і в результаті маємо ось такий парадокс. На сайті з доменом .com.ua - все гаразд, а ось на сайті з доменом .укр - вихватує лише ЛОГО і пише "Сторінку не знайдено"
Такий же результат і у випадку простого копіювання посилання та в пост FaceBook
Чи може бути таке, що FaceBook не сприймає кириличні зони (.укр і тд) ?
Це може залежати від налаштувань блокування окремих доменних зон, гадаю кирилиця тут ні до чого.
Щоб не на пальцях - ось що виходить
http://i.piccy.info/i9/1cc027fe1faaefbebb8a0cb62b6510e9/1612704786/13243/1411927/_00__500.jpghttp://i.piccy.info/a3/2021-02-07-13-33/i9-14194855/500x144-r/i.gif
Блокування доменних зон - блокування зі сторони  FaceBook ? Щоб перевірити таке, може знайти будь-який сайт із зони ===.укр=== та спробувати поділитись сторінкою
Чи можливо таке, що на Хостингу домен .укр прив"язаний через Punycode ?
darkphantom написав:
Droid 77 написав:
Взагалі, я б зробив просто перенаправлення із домена другий.укр на один.com.ua, бо там не тільки з фейсбуком, а й із SEO, із куками треба буде возитися.
Якщо дуже потрібно то доведеться таки розбиратися, але от я наприклад сам розбираюся дуже довго, на форумах іще довше бо чекаєш відповіді якої немає. Якби були гроші то я б когось найняв і мабуть так зробив би і кінцевий спеціаліст, де він чогось не розуміє, тому формуються ланцюжки виконавців.
Не знаю, чи фейсбук сприймає кириличні домени, бо з ним ніколи не працював.
Я загуглив:
https://google.com/search?q=facebook+cyrillic+domains
І знайшов, що така проблема була (фейсбук не сприймає домени що не латиницею)
https://stackoverflow.com/questions/184 … lic-domain
Там наче (не поглиблювався) пропонують перевести домен у вигляд не зрозумілий людині, але зрозумілий фейсбуку.
Але у Вас він вже і так переведений? Все рівно не зрозумів нічого зі скріну
vakotov написав:
Домени на Хостингу припарковані за допомогою "Punycode" - "крякозябли для людини"
Переадресація не варіант, оскільки основний сайт на домені ".УКР" і тримати два домени - це трішки накладно
Не хочеться більше писати дурниць, гадаючи що там.
Просто домен "постеьл-окей" як com.ua так і .укр не існує.
