Re: Advent of Code
▼2021_5a.rs
type Line = ((i32, i32),(i32, i32));
fn parse_vents(lines: &str) -> Vec<Line> {
lines.lines()
.map(|line|{
let mut line = line.split(" -> ");
let mut pt1 = line.next().unwrap().split(',');
let mut pt2 = line.next().unwrap().split(',');
((pt1.next().unwrap().parse().unwrap(), pt1.next().unwrap().parse().unwrap()),
(pt2.next().unwrap().parse().unwrap(), pt2.next().unwrap().parse().unwrap()))
.collect()
fn is_diagonal(line: &Line) -> bool {
line.0.0 != line.1.0 && line.0.1 != line.1.1
fn ordering_to_i32(order: std::cmp::Ordering) -> i32{
match order {
std::cmp::Ordering::Greater => 1,
std::cmp::Ordering::Equal => 0,
std::cmp::Ordering::Less => -1,
fn task(vents: &[Line], is_diagonals_needed: bool) -> i32
use std::collections::HashMap;
let mut known_vents : HashMap<(i32, i32), i32>= HashMap::new();
for vent in vents {
if is_diagonals_needed || !is_diagonal(vent) {
let (mut x, mut y) = vent.0;
let (dx, dy) = (-ordering_to_i32(x.cmp(&vent.1.0)),-ordering_to_i32(y.cmp(&vent.1.1)));
loop {
*known_vents.entry((x,y)).or_insert(0) += 1;
if (x,y) == vent.1 {
x += dx;
y += dy;
known_vents.values().filter(|&&x|x>1).count() as i32
fn task1(vents: &[Line]) -> i32
task(vents, false)
fn task2(vents: &[Line]) -> i32
task(vents, true)
fn main() {
let input = aoc::get_input_from_ini_with_year("5","2021").unwrap();
let vents = parse_vents(&input);
println!("Result1: {}", task1(&vents));
println!("Result2: {}", task2(&vents));
Друге рішення - 25мс, перше - 4мс (у релізі, звісно, дебажні - 0,5с на 0,25с).
І так, на жаль, bench досі доступний лише на нестабільній гілці.
