41
Re: Advent of Code
2021_9.rs
fn task1(map: &Vec<Vec<u8>>) -> usize {
    map.iter()
        .enumerate()
        .map(|(i, line)| {
            line.iter()
                .enumerate()
                .filter_map(|(j, &height)| {
                    if (i == 0 || height < map[i - 1][j])
                        && (j == 0 || height < map[i][j - 1])
                        && (i == map.len() - 1 || height < map[i + 1][j])
                        && (j == line.len() - 1 || height < map[i][j + 1])
                        Some(height as usize + 1)
                    } else {
                        None
                .sum::<usize>()
        .sum()
fn floodfill(map: &mut Vec<Vec<u8>>, i: i32, j: i32) -> usize {
    if i < 0
        || j < 0
        || i >= map.len() as i32
        || j >= map[i as usize].len() as i32
        || map[i as usize][j as usize] == 9
        0
    } else {
        map[i as usize][j as usize] = 9;
        1 + floodfill(map, i - 1, j)
            + floodfill(map, i + 1, j)
            + floodfill(map, i, j - 1)
            + floodfill(map, i, j + 1)
fn task2(map: &Vec<Vec<u8>>) -> usize {
    let mut map = map.clone();
    let mut result = Vec::new();
    for i in 0..map.len() {
        for j in 0..map[i].len() {
            result.push(floodfill(&mut map, i as i32, j as i32));
    result.sort();
    result.iter().rev().take(3).fold(1, |x, acc| acc * x)
fn main() {
    let input = aoc::get_input_from_ini_with_year("9", "2021").unwrap();
    let map: Vec<Vec<_>> = input
        .lines()
        .map(|line| {
            line.chars()
                .map(|digit| digit.to_digit(10).unwrap() as u8)
                .collect()
        .collect();
    println!("Result1: {}", task1(&map));
    println!("Result2: {}", task2(&map));
42 Востаннє редагувалося dot (10.12.2021 09:50:55)
Re: Advent of Code
2021#10, Py3.9.5
pairs = {"(": ")", "[": "]", "{": "}", "<": ">"}
illegal = int()
incomplete = list()
for chunk in [line for line in open("input.txt").read().split()]:
    history = list()
    for ch in chunk:
        if ch not in pairs.keys():
            if ch == pairs[history[-1]]:
                history.pop(-1)
            else:
                illegal += {")": 3, "]": 57, "}": 1197, ">": 25137}[ch]
                history.clear()
                break
        else:
            history.append(ch)
    if history:
        points = int()
        for h in history[::-1]:
            points = points * 5 + {")": 1, "]": 2, "}": 3, ">": 4}[pairs[h]]
        incomplete.append(points)
print("Part One:", illegal)
print("Part Two:", sorted(incomplete)[len(incomplete) // 2])
43 Востаннє редагувалося dot (10.12.2021 10:10:08)
Re: Advent of Code
Troxy zapizno, ale vyrjicyv zrobyty osobystu docku percostjy, tam je otcky i zironjky vykonanyx vprav.
Jak potrapyty: [Leaderboard] → [Private Leaderboard] → You can join a private leaderboard by entering its join code here, de vvodyte 728806-963332f3.
Re: Advent of Code
2021/10.py
import aoc
import os
import unittest
NUMBER = os.path.basename(__file__).removesuffix('.py')
def check_brackets(line):
    stack = []
    PAIRS = {'(':')','[':']','{':'}','<':'>'}
    for symb in line:
        if symb in PAIRS:
            stack.append(PAIRS[symb])
        else:
            if not stack or stack.pop()!=symb:
                return (symb, [])
    return ('', stack)
def task1(data: str) -> int:
    VALUES = {'':0,')':3,']':57,'}':1197,'>':25137}
    return sum(VALUES[check_brackets(line)[0]] for line in data.splitlines())
def task2(data: str) -> int:
    VALUES = {')':1,']':2,'}':3,'>':4}
    results = []
    for line in data.splitlines():
        result = 0
        symb, closing = check_brackets(line)
        if not symb:
            for brack in reversed(closing):
                result = 5*result + VALUES[brack]
            #print(''.join(closing), result)
            results.append(result)
    results.sort()
    return results[len(results)//2]
class Test(unittest.TestCase):
    def test_brack(self):
        symb, stack = check_brackets('[({(<(())[]>[[{[]{<()<>>')
        self.assertEqual(symb, '')
        self.assertEqual(''.join(reversed(stack)),'}}]])})]')
    def test_task2(self):
        inp = '''[({(<(())[]>[[{[]{<()<>>
        self.assertEqual(task2(inp), 288957)
if __name__ == '__main__':
    #unittest.main()
    data = aoc.load_data(NUMBER, verbose=True)
    print('Task1:', task1(data))
    print('Task2:', task2(data))
Подякували: dot1
45 Востаннє редагувалося koala (10.12.2021 11:09:09)
Re: Advent of Code
2021_10.rs
enum Brackets {
    Correct(Vec<char>),
    Incorrect(char),
fn check_brackets(line: &str) -> Brackets {
    let mut stack = Vec::new();
    for symbol in line.chars() {
        match symbol {
            '(' => stack.push(')'),
            '[' => stack.push(']'),
            '{' => stack.push('}'),
            '<' => stack.push('>'),
            closing => {
                if symbol != stack.pop().unwrap() {
                    return Brackets::Incorrect(closing);
    Brackets::Correct(stack)
fn task1(data: &str) -> usize {
    data.lines()
        .map(|line| match check_brackets(line) {
            Brackets::Incorrect(')') => 3,
            Brackets::Incorrect(']') => 57,
            Brackets::Incorrect('}') => 1197,
            Brackets::Incorrect('>') => 25137,
            _ => 0,
        .sum()
fn task2(data: &str) -> usize {
    let mut scores: Vec<_> = data
        .lines()
        .filter_map(|line| match check_brackets(line) {
            Brackets::Correct(rest) => Some(rest.iter().rev().fold(0, |acc, br| {
                5 * acc
                    + match br {
                        ')' => 1,
                        ']' => 2,
                        '}' => 3,
                        '>' => 4,
                        _ => panic!("wrong char in ending!"),
            _ => None,
        .collect();
    scores.sort();
    scores[scores.len() / 2]
fn main() {
    let input = aoc::get_input_from_ini_with_year("10", "2021").unwrap();
    println!("Result1: {}", task1(&input));
    println!("Result2: {}", task2(&input));
День 10. 1. Є некоректні дужкові вирази. Для виразів з неправильними дужками знайти суму значень (табличних) першої некоректної дужки. 2. Для незакінчених виразів обчислити за формулою значення рядка, який би доповнював до коректного, і знайти медіану цих значень.
Re: Advent of Code
Переробив усю структуру своїх advent_of_code. Раніше у мене була окрема бібліотека для завантаження даних, я створював окремі проєкти для кожної задачі й будував з нуля з усіма залежностями. Тепер у мене майже фреймворк :), окремі задачі лежать по модулях, функції називаються типово, перша побудова нового модуля займає пару секунд проти ~20с раніше. Принагідно звільнилося (з попередніми роками) >5GB старих побудов.
День 11. 1. Є мапа 10х10 восьминогів, що вміють світитися, якщо їхній заряд 10 або більше. На кожному кроці восьминоги накопичують 1 заряд, і якщо спалахують, то додатково заряджають на 1 усіх сусідів, включно з діагональними. Після спалаху заряд стає 0 (зокрема, на цьому кроці не іде зарядка від сусідів). Скільки буде спалахів за 100 кроків? 2. Який перший крок, на якому спалахнуть усі восьминоги одночасно?
year2021/day11.rs
#[derive(Clone)]
pub struct Octopuses {
    map: Vec<Vec<u8>>,
    last_flashed: usize,
impl Octopuses {
    fn new(input: &str) -> Octopuses {
        Octopuses {
            map: input.lines()
                      .map(|line|line.chars()
                                     .map(|c|c.to_digit(10).unwrap() as u8)
                                     .collect()
                      ).collect(),
            last_flashed: 0,
    fn step(&mut self) -> usize {
        for y in 0..self.map.len() {
            for x in 0..self.map[y].len() {
                self.map[y][x] += 1;
        self.last_flashed = 0;
        loop {
            let mut flashed = 0;
                    if self.try_flash(y, x) {
                        flashed += 1;
            if flashed == 0 {
            } else {
                self.last_flashed += flashed;
        self.last_flashed
    fn try_flash(&mut self, y: usize, x: usize) -> bool {
        use std::cmp::{min, max};
        if self.map[y][x]<=9 {
            false
        } else {
            self.map[y][x] = 0;
            for dy in max(0, y as i32-1) as usize..min(self.map.len(), y+2) {
                for dx in max(0, x as i32-1) as usize..min(self.map[y].len(), x+2) {
                    if self.map[dy][dx] != 0 {
                        self.map[dy][dx] += 1;
            true
    fn area(&self) -> usize {
        self.map.len() * self.map[0].len()
pub fn parse_input(input: &str) -> Octopuses {
    Octopuses::new(input)
pub fn task1(octopuses: &Octopuses) -> usize {
    let mut octopuses = octopuses.clone();
    (0..100).map(|_|octopuses.step()).sum()
pub fn task2(octopuses: &Octopuses) -> usize {
    let area = octopuses.area();
    (0..).take_while(|_|octopuses.step() != area).count() + 1
Подякували: dot1
47 Востаннє редагувалося dot (11.12.2021 11:39:27)
Re: Advent of Code
2021#11, Py3.9.5
octopuses = [[int(x) for x in l] for l in open("input.txt").read().split()]
grid = {(x, y) for y, l in enumerate(octopuses) for x, _ in enumerate(l)}
count = int()
step = int()
while octopuses != [[0] * 10] * 10:
    octopuses = [[e + 1 for e in l] for l in octopuses]
    fresh = {(x, y) for y, l in enumerate(octopuses) for x, e in enumerate(l) if e > 9}
    exhausted = set()
    sides = lambda x, y: {
        (_x, _y) for _x in (x - 1, x, x + 1) for _y in (y - 1, y, y + 1) if (_x, _y) != (x, y) and (_x, _y) in grid
    while fresh:
        exhausted |= fresh.copy()
        charge = set()
        for f in fresh:
            for x, y in sides(*f):
                octopuses[y][x] += 1
                if octopuses[y][x] > 9 and (x, y) not in exhausted:
                    charge.add((x, y))
        fresh = charge
    for y, l in enumerate(octopuses):
        for x, e in enumerate(l):
            if e > 9:
                octopuses[y][x] = 0
                count += 1
    if step == 99:
        print("Part One", count)
    step += 1
print("Part Two", step)
Re: Advent of Code
Гм. Полагодив решту старого коду, призвів до ладу старі тести і залежності і спробував почати з 2015 року. Перша ж задача (1 грудня 2015, задача 1) - у мене відповідь на 1 менша за правильну, і я не бачу, в чому проблема. Загальна кількість дужок у мене непарна, а відповідь на сайті (яку я колись увів) - парна. WTF?
year2015/day1.rs
pub fn task1(instructions: &str) -> i32 {
    instructions.chars()
                .map(|c|match c {
                    '(' =>  1,
                    ')' => -1,
                    _ => panic!("Wrong input"),
                .sum()
Подякували: dot1
49
Re: Advent of Code
А ще для ідіотів є така фігня: https://crates.io/crates/advent-of-code
Ні, я розумію, чому таке написали; але кому може захотітися таким користуватися?
Подякували: dot1
50
Re: Advent of Code
Ja davno robyv 2015, a rozbyraty sja ljinky.
2015#1, Py
f = open("input.txt", "r")
floor = pos = 0
for s in f.read():
    if s == '(':
        floor += 1
    else:
        floor -= 1
    pos += 1
    if floor == -1:
        print(f"Basement: {pos}") # Part Two
print(f"Floor: {floor}")  # Part One
f.close()
Pravda, ne zavercyv ctce, spynyv sja na 21, a 19 rozvjazav lyce percu tcastynu.
51
Re: Advent of Code
year2021/day12.rs
use unicode_categories::UnicodeCategories;
type CaveName = String;
#[derive(Clone)]
pub struct CaveNode {
    ways_out: Vec<CaveName>,
    visited: Option<bool>,
impl CaveNode {
    fn new(name: &str, neighbor: &str) -> CaveNode {
        CaveNode{
            ways_out: vec![neighbor.to_owned()],
            visited: if name.chars().all(|c|c.is_letter_uppercase())  {
                None
            } else {
                Some(false)
type CaveMap = std::collections::HashMap<CaveName, CaveNode>;
pub fn parse_input(input: &str) -> CaveMap {
    let mut map = CaveMap::new();
    for line in input.lines() {
        if let Some(dash) = line.find('-') {
            let left = line[..dash].to_string();
            let right = line[dash+1..].to_string();
            map.entry(left.to_owned())
               .and_modify(|node|node.ways_out.push(right.to_owned()))
               .or_insert(CaveNode::new(&left, &right));
            map.entry(right.to_owned())
               .and_modify(|node|node.ways_out.push(left.to_owned()))
               .or_insert(CaveNode::new(&right, &left));
    map
fn count_ways(map: &mut CaveMap, start: &str, end: &str) -> usize {
    if start == end {
        return 1;
    if map[start].visited == Some(true) {
    let start = start.to_string();
    if map[&start].visited.is_some() {
        map.entry(start.to_owned()).and_modify(|node|node.visited = Some(true));
    let result = (0..map[&start].ways_out.len()).map(|i|{
        let name = map[&start].ways_out[i].to_owned();
        count_ways(map, &name, end)
    }).sum();
        map.entry(start).and_modify(|node|node.visited = Some(false));
    result
pub fn task1(map: &CaveMap) -> usize {
    count_ways(&mut map, "start", "end")
fn count_ways2(map: &mut CaveMap, start: &str, end: &str, start_visited: bool, small_visited_twice: bool) -> usize {
    if start == end {
        return 1;
    if start=="start" && start_visited {
    let in_visited_small = map[start].visited.unwrap_or(false);
    if small_visited_twice && in_visited_small {
        count_ways2(map, &name, end, true, small_visited_twice || in_visited_small)
    }).sum();
    if !in_visited_small && map[&start].visited.is_some() {
    result
pub fn task2(map: &CaveMap) -> usize {
    count_ways2(&mut map, "start", "end", false, false)
День 12. 1. Є граф печери з початком і кінцем. Деякі вузли можна відвідувати кілька разів, решту - лише один. Скільки існує шляхів крізь печеру? 2. Можна один раз відвідати уже відвіданий вузол, який зазвичай не можна відвідувати повторно. Скільки тепер?
Подякували: dot1
52
Re: Advent of Code
Боюся, що я на тиждень зникну з форуму. Можливо, завтра вранці ще допишу. А потім же доробляти... ех...
53 Востаннє редагувалося dot (12.12.2021 22:59:31)
Re: Advent of Code
Ne duge ljubju taki rekursivni zadatcky.
2021#12, Py3.9.5
from collections import defaultdict
caves = defaultdict(set)
for one, two in [line.split("-") for line in open("input.txt").read().splitlines()]:
    caves[one].add(two)
    caves[two].add(one)
caves = {i: caves[i] - {"start"} for i in caves}
def visit(twice=True, c="start", visited=set()):
    count = int()
    for cave in caves[c]:
        if cave == "end":
            count += 1
        elif cave.isupper():
            count += visit(twice, cave, visited)
        elif cave not in visited:
            count += visit(twice, cave, visited | {cave})
        elif not twice:
            count += visit(True, cave, visited | {cave})
    return count
print("Part One:", visit())
print("Part Two:", visit(False))
54
Re: Advent of Code
До речі, мій ҐітГаб з AoC/Rust.
Подякували: dot, leofun012
55 Востаннє редагувалося dot (13.12.2021 00:42:13)
Re: Advent of Code
Nitcʼ stracnoho! Raptovi spravy tcy ctcosj svojo buvaʼ. Tcekaju za tygdenj! Koly ctco, poskladneni zadatcky zazvytcaj buvajutj na vyxidnyx, jakctco ne pomyljaju sja.
56 Востаннє редагувалося dot (14.12.2021 18:25:14)
Re: Advent of Code
2021, Py.3.9.5
from re import findall
def folding(axis: str, number: int) -> list:
    folded = list()
    for n in range(1, number + 1):
        for x, y in set(dots):
            if axis == "x" and x in (number - n, number + n):
                folded.append((number - n, y))
            elif axis == "y" and y in (number - n, number + n):
                folded.append((x, number - n))
    return folded
def visualing() -> None:
    max_x, max_y = [max(el) + 1 for el in [*zip(*dots)]]
    for y in range(max_y):
        for x in range(max_x):
            print("#" if (x, y) in dots else " ", end="")
        print("\n", end="")
    print()
dots = list()
actions = list()
instructions = False
for line in open("input.txt").read().splitlines():
    if not line:
        instructions = True
        continue
    if instructions:
        axis, number = findall(r"([xy])=(\d+)", line)[0]
        actions.append((axis, int(number)))
    else:
        dots.append(tuple(map(int, findall(r"\d+", line))))
for number, action in enumerate(actions):
    dots = folding(*action)
    if number == 1:
        print("Part One:", len(dots))
print("Part Two:")
visualing()
from collections import Counter
polymer, _, *rules = open("input.txt").read().splitlines()
rules = dict(rule.split(" -> ") for rule in rules)
pairs = Counter(polymer[i] + polymer[i + 1] for i in range(len(polymer) - 1))
chars = Counter(polymer)
steps = (10, 40)
for i in range(1, steps[-1] + 1):
    for (a, b), count in pairs.copy().items():
        if a + b in rules.keys():
            insert = rules[a + b]
            pairs[a + b] -= count
            pairs[a + insert] += count
            pairs[insert + b] += count
            chars[insert] += count
    if i in steps:
        print("Answer:", max(chars.values()) - min(chars.values()))
57 Востаннє редагувалося dot (16.12.2021 05:54:44)
Re: Advent of Code
2021#15, Py3.9.5
from queue import PriorityQueue
def plus_form_sides(_y, _x, y_len, x_len):
    for side_y, side_x in ((1, 0), (-1, 0), (0, 1), (0, -1)):
        y, x = (_y + dr, _x + dc)
        if 0 <= y < y_len and 0 <= x < x_len:
            yield (y, x)
# Updated from:
# https://stackabuse.com/dijkstras-algorithm-in-python
def dijkstra(graf: list) -> int:
    y_len, x_len = len(graf), len(graf[0])
    visited = set()
    start_vertex = (0, 0)
    stop_vertex = (y_len - 1, x_len - 1)
    min_distances = defaultdict(lambda: float("inf"))
    min_distances[start_vertex] = 0
    pq = PriorityQueue()
    pq.put((0, start_vertex))
    while not pq.empty():
        distance, current_vertex = pq.get()
        if current_vertex == stop_vertex:
            return distance
        if current_vertex in visited:
            continue
        visited.add(current_vertex)
        for y, x in plus_form_sides(*current_vertex, y_len, x_len):
            if (y, x) in visited:
                continue
            new_distance = distance + graf[y][x]
            if new_distance < min_distances[(y, x)]:
                min_distances[(y, x)] = new_distance
                pq.put((new_distance, (y, x)))
    return float("inf")
cavern = [list(map(int, list(line))) for line in open("input.txt").read().splitlines()]
print("Part One:", dijkstra(cavern))
blocks = [[[v + s if v + s < 10 else v + s - 9 for v in row] for row in cavern] for s in range(9)]
y_len, x_len = len(blocks), len(blocks[0])
cavern = list()
larger = 5
for s in range(larger):
    for x in range(x_len):
        row = list()
        for y in range(larger):
            row.extend(blocks[y + s if y + s < y_len else y + s - y_len][x])
        cavern.append(row)
print("Part Two:", dijkstra(cavern))
Sutj
Zadatca osnovana na alqoritmi Dejkstry, mogna, hadaju, takog tcerez A* (pro njoho piznav piznjice, ale sprobuju, pry nahodji), hlybynoju i cyrynoju. Ljinjky bulo z nula pysaty, tomu tupo vzjav hotovu funtsiju — vkazano vidky, ale pryiclo sja perepysaty, a potim, sebto dlja druhoji zadatcy, znov perepysaty, bo tak poviljno robylo, ctco mij komp vge vbyvav Xroma, VS Koda i, lybonj, samoho sebe.
Tcas druhoji.
time python3 main.py
6,05s user
0,14s system
58
Re: Advent of Code
І я знову тут!
2021/day13.rs
#[derive(Copy, Clone)]
pub enum Fold {
    X,
    Y,
#[derive(Clone)]
pub struct InvisiblePaper {
    dots: std::collections::HashSet<(i32, i32)>,
    folds: Vec<(Fold, i32)>,
impl InvisiblePaper {
    fn do_fold(&mut self, fold: (Fold, i32)) {
        self.dots = self.dots
                        .iter()
                        .map(|dot|
                            match fold.0 {
                                Fold::X => (fold.1 - (fold.1-dot.0).abs(), dot.1),
                                Fold::Y => (dot.0, fold.1 - (fold.1-dot.1).abs()),
                        .collect();
pub fn parse_input(input: &str) -> InvisiblePaper {
    let lines = input.lines();
    let mut dots_done = false;
    let mut data = InvisiblePaper {
        dots: std::collections::HashSet::new(),
        folds: Vec::new(),
    for line in lines {
        if line.is_empty() {
            dots_done = true;
        } else {
            if !dots_done {
                let mut dot = line.split(',');
                data.dots.insert((dot.next().unwrap().parse().unwrap(),
                                dot.next().unwrap().parse().unwrap()));
            } else {
                let mut fold = line.split('=');
                let fold_type = if fold.next().unwrap().chars().nth(11)==Some('x') {
                    Fold::X
                } else {
                    Fold::Y
                data.folds.push((fold_type,fold.next().unwrap().parse().unwrap()));
    data
pub fn task1(data: &InvisiblePaper) -> usize {
    let mut data = data.clone();
    data.do_fold(data.folds[0]);
    data.dots.len()
pub fn task2(data: &InvisiblePaper) -> usize {
    let folds = &data.folds;
    for &fold in folds {
        data.do_fold(fold);
    let max_x = data.dots.iter().map(|(x, _)|x).max().unwrap() + 1;
    let max_y = data.dots.iter().map(|(_, y)|y).max().unwrap() + 1;
    for y in 0..max_y {
        for x in 0..max_x {
            print!("{}", if data.dots.contains(&(x,y)) {"#"} else {"."});
        println!("");
    0
59
Re: Advent of Code
Z povernennjem! A ja sprobuju vge pidkljutcyty sja pislja/zavtra.
60
Re: Advent of Code
Перша частина є:
year2021/day14.rs
#[derive(Clone)]
pub struct PolymerData {
    polymer: Vec<char>,
    rules: std::collections::HashMap<(char, char), char>,
pub fn parse_input(input: &str) -> PolymerData {
    let mut lines = input.lines();
    let mut polymer_data = PolymerData {
        polymer: lines.next().unwrap().chars().collect(),
        rules: std::collections::HashMap::new(),
    lines.next();
    for line in lines {
        let mut parts = line.split(" -> ");
        let left = parts.next().unwrap();
        let right = parts.next().unwrap();
        polymer_data.rules.insert(
            (left.chars().nth(0).unwrap(), left.chars().nth(1).unwrap()),
            right.chars().nth(0).unwrap(),
    polymer_data
pub fn task1(data: &PolymerData) -> usize {
    let mut polymer = data.polymer.clone();
    for _ in 0..10 {
        let mut new_polymer = vec![polymer[0]];
        for pair in polymer.windows(2) {
            if let &[left, right] = pair {
                match data.rules.get(&(left, right)) {
                    Some(&v) => new_polymer.push(v),
                    _ => (),
                new_polymer.push(right);
        polymer = new_polymer;
    let mut counter = std::collections::HashMap::new();
    for element in polymer {
        *counter.entry(element).or_insert(0) += 1;
    let min = counter.values().min().unwrap();
    let max = counter.values().max().unwrap();
    max - min
pub fn task2(data: &PolymerData) -> usize {
    for _ in 0..40 {
                    _ => (),
    max - min
Другу скопіював з першої, дістав
memory allocation of 34359738368 bytes failed
Завтра зроблю мемоїзацію, ніби очевидно, як.
