61
Re: Advent of Code
Rust і очевидно - речі несумісні.
Подякували: mamkin haker, dot2
62
Re: Advent of Code
year2021/day14.rs
type Counter = std::collections::HashMap<char, usize>;
type Polymer = Vec<char>;
type PolymerRules = std::collections::HashMap<(char, char), char>;
#[derive(Clone)]
pub struct PolymerData {
    polymer: Polymer,
    rules: PolymerRules,
    counters: std::collections::HashMap<(char, char, usize), Counter>,
impl PolymerData {
    fn from_str(input: &str) -> PolymerData {
        let mut lines = input.lines();
        let mut polymer_data = PolymerData {
            polymer: lines.next().unwrap().chars().collect(),
            rules: std::collections::HashMap::new(),
            counters: std::collections::HashMap::new(),
        lines.next();
        for line in lines {
            let mut parts = line.split(" -> ");
            let left = parts.next().unwrap();
            let right = parts.next().unwrap();
            polymer_data.rules.insert(
                (left.chars().nth(0).unwrap(), left.chars().nth(1).unwrap()),
                right.chars().nth(0).unwrap(),
        polymer_data
    fn composition_recursive(&mut self, polymer: (char, char), steps: usize) -> Counter {
        let (left, right) = polymer;
        if !self.counters.contains_key(&(left, right, steps)) {
            let counters = if steps == 0 {
                [(right, 1)].into()
            } else {
                match self.rules.get(&(left, right)) {
                    Some(&v) => {
                        let mut left = self.composition_recursive((left, v), steps - 1);
                        for (element, count) in self.composition_recursive((v, right), steps - 1) {
                            *left.entry(element).or_insert(0) += count;
                        left
                    None => [(right, 1)].into(),
            self.counters.insert((left, right, steps), counters);
        self.counters.get(&(left, right, steps)).unwrap().clone()
    fn composition(&mut self, steps: usize) -> usize {
        let mut counter: Counter = [(self.polymer[0], 1)].into();
        for i in 0..self.polymer.len() - 1 {
                self.composition_recursive((self.polymer[i], self.polymer[i + 1]), steps)
                *counter.entry(element).or_insert(0) += count;
        let min = counter.values().min().unwrap();
        let max = counter.values().max().unwrap();
        max - min
pub fn parse_input(input: &str) -> PolymerData {
    PolymerData::from_str(input)
fn task(data: &PolymerData, steps: usize) -> usize {
    let mut data = data.clone();
    data.composition(steps)
pub fn task1(data: &PolymerData) -> usize {
    task(data, 10)
pub fn task2(data: &PolymerData) -> usize {
    task(data, 40)
#[cfg(test)]
mod test {
    use super::*;
    #[test]
    fn test_task1() {
        let input = "NNCB
CH -> B
HH -> N
CB -> H
NH -> C
HB -> C
HC -> B
HN -> C
NN -> C
BH -> H
NC -> B
NB -> B
BN -> B
BB -> N
BC -> B
CC -> N
CN -> C";
        assert_eq!(task1(&parse_input(input)), 1588);
Зробив. Відчуваю, що нагородив фігні, але воно значно коротше за те, що було раніше, і працює як слід, а це Rust, тому, мабуть, небагато.
63
Re: Advent of Code
Дейкстра.
year2021/day15.rs
type Cave = Vec<Vec<usize>>;
pub fn parse_input(input: &str) -> Cave {
    input
        .lines()
        .map(|line| {
            line.chars()
                .map(|risk| risk.to_digit(10).unwrap() as usize)
                .collect()
        .collect()
pub fn dijkstra(cave: &Cave) -> usize {
    use std::collections::BTreeMap;
    let size = cave.len();
    let mut len_cave = vec![vec![None::<usize>; size]; size];
    len_cave[0][0] = Some(0);
    let mut to_search: BTreeMap<usize, Vec<(usize, usize)>> = [(0, [(0, 0)].into())].into();
    while !to_search.is_empty() {
        let min_key = *to_search.keys().next().unwrap();
        let (x, y) = to_search.get_mut(&min_key).unwrap().pop().unwrap();
        if to_search[&min_key].is_empty() {
            to_search.remove(&min_key);
        for (dx, dy) in [(0, 1), (1, 0), (-1, 0), (0, -1)] {
            let x = x as i32 + dx;
            let y = y as i32 + dy;
            if 0 <= x && x < size as i32 && 0 <= y && y < size as i32 {
                let x = x as usize;
                let y = y as usize;
                let old = len_cave[x][y];
                len_cave[x][y] = Some(match len_cave[x][y] {
                    Some(risk) => std::cmp::min(risk, min_key + cave[x][y]),
                    None => min_key + cave[x][y],
                if len_cave[x][y] != old {
                    to_search
                        .entry(len_cave[x][y].unwrap())
                        .or_insert(Vec::new())
                        .push((x, y));
    len_cave[size - 1][size - 1].unwrap() - len_cave[0][0].unwrap()
pub fn task1(cave: &Cave) -> usize {
    dijkstra(cave)
pub fn task2(cave: &Cave) -> usize {
    let mut real_cave = vec![vec![0; size * 5]; size * 5];
    for i_mult in 0..5 {
        for j_mult in 0..5 {
            for i in 0..size {
                for j in 0..size {
                    real_cave[i_mult * size + i][j_mult * size + j] =
                        (cave[i][j] + i_mult + j_mult - 1) % 9 + 1;
    dijkstra(&real_cave)
#[cfg(test)]
mod test {
    use super::*;
    #[test]
    fn test_task1() {
        let input = "1163751742
1381373672
2136511328
3694931569
7463417111
1319128137
1359912421
3125421639
1293138521
2311944581";
        assert_eq!(task1(&parse_input(input)), 40);
64
Re: Advent of Code
year2021/day16.rs
pub enum PacketContent {
    Literal(usize),
    Operator(Box<Vec<Packet>>),
pub struct Packet {
    version: u8,
    type_id: u8,
    content: PacketContent,
const LITERAL_ID: u8 = 4;
const BIT_LENGTH_SIZE: usize = 15;
const PACKETS_COUNT_SIZE: usize = 11;
#[derive(Debug)]
enum Error {
    UnexpectedEndOfStream,
fn get_number(input: &[u8]) -> usize {
    let mut number = 0_usize;
    for &bit in input {
        number = number << 1 | bit as usize;
    number
fn parse_packet(input: &[u8]) -> Result<(Packet, &[u8]), Error> {
    if input.len() < 7 {
        return Err(Error::UnexpectedEndOfStream);
    let version = get_number(&input[..3]) as u8;
    let type_id = get_number(&input[3..6]) as u8;
    if type_id == LITERAL_ID {
        let mut number = 0;
        let mut ptr = 6;
        loop {
            let next_part = get_number(&input[ptr..ptr + 5]);
            ptr += 5;
            number = (number << 4) | (next_part & 0xF);
            if next_part & 0x10 == 0 {
        Ok((
            Packet {
                version,
                type_id,
                content: PacketContent::Literal(number),
            &input[ptr..],
    } else {
        let length_type_id = get_number(&input[6..7]);
        match length_type_id {
            0 => {
                let header_end = 7 + BIT_LENGTH_SIZE;
                let bit_length = get_number(&input[7..header_end]);
                let mut subpackets = Box::new(vec![]);
                let mut own_input = &input[header_end..header_end + bit_length];
                while own_input.len() > 0 {
                    let (packet, rest) = parse_packet(own_input)?;
                    subpackets.push(packet);
                    own_input = rest;
                Ok((
                    Packet {
                        version,
                        type_id,
                        content: PacketContent::Operator(subpackets),
                    &input[header_end + bit_length..],
            1 => {
                let header_end = 7 + PACKETS_COUNT_SIZE;
                let packet_count = get_number(&input[7..header_end]);
                let mut subpackets = Box::new(Vec::with_capacity(packet_count));
                let mut own_input = &input[header_end..];
                for _ in 0..packet_count {
                    own_input = rest;
                Ok((
                    Packet {
                        version,
                        type_id,
                    own_input,
            _ => panic!("Wrong length type id: {}", length_type_id),
pub fn parse_input(input: &str) -> Packet {
    let bit_stream: Vec<u8> = input
        .chars()
        .flat_map(|hex_digit| {
            (0..4).rev().map(move |i| {
                ((hex_digit.to_digit(16).unwrap() >> i) & 1) as u8
        .collect();
    parse_packet(&bit_stream).unwrap().0
impl Packet {
    fn version_sum(&self) -> usize {
        self.version as usize
            + match &self.content {
                PacketContent::Literal(_) => 0,
                PacketContent::Operator(subpackets) => {
                    subpackets.iter().map(|p| p.version_sum()).sum()
    fn calculate(&self) -> usize {
        match (&self.content, self.type_id) {
            (PacketContent::Operator(subpackets), 0) => {
                subpackets.iter().map(|p| p.calculate()).sum()
            (PacketContent::Operator(subpackets), 1) => {
                subpackets.iter().map(|p| p.calculate()).product()
            (PacketContent::Operator(subpackets), 2) => {
                subpackets.iter().map(|p| p.calculate()).min().unwrap()
            (PacketContent::Operator(subpackets), 3) => {
                subpackets.iter().map(|p| p.calculate()).max().unwrap()
            (&PacketContent::Literal(value), 4) => value,
            (PacketContent::Operator(subpackets), 5) => {
                if subpackets[0].calculate() > subpackets[1].calculate() {
                } else {
                    0
            (PacketContent::Operator(subpackets), 6) => {
                if subpackets[0].calculate() < subpackets[1].calculate() {
                } else {
                    0
            (PacketContent::Operator(subpackets), 7) => {
                if subpackets[0].calculate() == subpackets[1].calculate() {
                } else {
                    0
            _ => panic!("Wrong type_id: {}", self.type_id),
pub fn task1(input: &Packet) -> usize {
    input.version_sum()
pub fn task2(input: &Packet) -> usize {
    input.calculate()
Тут я спершу дещо намутив із ітераторами і отримав майже stack overflow на побудові рекурсивного темплейта. Також я дізнався, що Rust підтримує 128 вкладених шаблонів, але це число можна змінити в налаштуваннях проєкта (сподіваюся, що мені ніколи це не знадобиться).
А ще це, здається, перша задача цього року, де я не відкривав вхідні дані в браузері взагалі, і ніяк на них не дивився. Лише запускав код.
65
Re: Advent of Code
2021#16 Py3.9.5
from math import prod
class Transmission:
    def __init__(self, insert) -> None:
        self.bin = bin(int(insert, 16))[2:].zfill(len(insert) * 4)
        self.pos = 0
    def to_dec(self, step) -> int:
        decimal = int(self.bin[self.pos : self.pos + step], 2)
        self.pos += step
        return decimal
    def packet(self):
        version = self.to_dec(3)
        type_id = self.to_dec(3)
        data = self.packet_data(type_id)
        return version, type_id, data
    def n_packets(self, n, type=True):
        packets = list()
        if type:
            packets = [self.packet() for _ in range(n)]
        else:
            stop = self.pos + n
            while self.pos < stop:
                packets.append(self.packet())
        return packets
    def packet_data(self, type_id):
        if type_id == 4:
            return self.literal_value()
        if self.to_dec(1):
            return self.n_packets(self.to_dec(11))
        return self.n_packets(self.to_dec(15), False)
    def literal_value(self) -> int:
        value = str()
        last = 1
        while last:
            last = self.to_dec(1)
            value += self.bin[self.pos : self.pos + 4]
            self.pos += 4
        return int(value, 2)
def sum_versions(packet) -> int:
    version, type_id, data = packet
    return version if type_id == 4 else version + sum(map(sum_versions, data))
def calculation(packet):
    _, type_id, data = packet
    if type_id == 4:
        return data
    values = map(calculation, data)
    if type_id == 0:
        return sum(values)
    if type_id == 1:
        return prod(values)
    if type_id == 2:
        return min(values)
    if type_id == 3:
        return max(values)
    a, b = values
    if type_id == 5:
        return int(a > b)
    if type_id == 6:
        return int(a < b)
    return int(a == b)
packet = Transmission(open("input.txt").readline().strip()).packet()
print("Part One:", sum_versions(packet))
print("Part Two:", calculation(packet))
66
Re: Advent of Code
year2021/day18.rs
use std::boxed::Box;
use std::str::Chars;
#[derive(Clone)]
pub enum SnailfishNumber {
    Regular(u32),
    Pair(Box<(SnailfishNumber, SnailfishNumber)>),
impl std::fmt::Debug for SnailfishNumber {
    fn fmt(&self, fmt: &mut std::fmt::Formatter<'_>) -> std::fmt::Result {
        match self {
            SnailfishNumber::Regular(value) => value.fmt(fmt),
            SnailfishNumber::Pair(pair) => {
                write!(fmt, "[{:?},{:?}]", &pair.0, &pair.1)
impl SnailfishNumber {
    fn pair(left: SnailfishNumber, right: SnailfishNumber) -> SnailfishNumber {
        SnailfishNumber::Pair(Box::new((left, right)))
    fn regular(value: u32) -> SnailfishNumber {
    fn regpair(left: u32, right: u32) -> SnailfishNumber {
        SnailfishNumber::pair(
            SnailfishNumber::regular(left),
            SnailfishNumber::regular(right),
fn read_snailfish_number<'a>(input: &mut Chars<'a>) -> SnailfishNumber {
    let first = input.next().unwrap();
    if first == '[' {
        let left = read_snailfish_number(input.by_ref());
        assert_eq!(input.next().unwrap(), ',');
        let right = read_snailfish_number(input.by_ref());
        assert_eq!(input.next().unwrap(), ']');
        SnailfishNumber::pair(left, right)
    } else {
        SnailfishNumber::regular(first.to_digit(10).unwrap())
enum Explosion {
    Not,
    Both(u32, u32),
    FromLeft(u32),
    FromRight(u32),
    Did,
impl Explosion {
    fn to_bool(&self) -> bool {
        match self {
            Explosion::Not => false,
            _ => true,
    fn reduce(&mut self) {
        loop {
            //println!("Calling explode for {:?}", self);
            if !self.explode(1).to_bool() {
                //println!("Calling split for {:?}", self);
                if !self.split() {
                    //println!("Done: {:?}", self);
    fn explode(&mut self, level: u32) -> Explosion {
        //println!("Exploding level={}: {:?}", level, self);
        match self {
            SnailfishNumber::Regular(_) => Explosion::Not,
                if let (
                    SnailfishNumber::Regular(left),
                    SnailfishNumber::Regular(right),
                ) = **pair
                    if level > 4 {
                        Explosion::Both(left, right)
                    } else {
                        Explosion::Not
                } else {
                    match pair.0.explode(level + 1) {
                        Explosion::Both(left_left, left_right) => {
                            pair.0 = SnailfishNumber::regular(0);
                            pair.1.insert_from_left(left_right);
                            Explosion::FromLeft(left_left)
                        Explosion::FromRight(left_right) => {
                            Explosion::Did
                        Explosion::Not => match pair.1.explode(level + 1) {
                            Explosion::Both(right_left, right_right) => {
                                pair.0.insert_from_right(right_left);
                                pair.1 = SnailfishNumber::regular(0);
                                Explosion::FromRight(right_right)
                            Explosion::FromLeft(right_left) => {
                                Explosion::Did
                            other => other, //Did, Not, Right
                        other => other, //Did, Not, LEft
    fn insert_from_left(&mut self, value: u32) {
        //println!("Insert left {:?} into {:?}", value, self);
        match self {
            SnailfishNumber::Regular(self_value) => {
                *self_value += value;
                pair.0.insert_from_left(value);
    fn insert_from_right(&mut self, value: u32) {
        //println!("Insert right {:?} into {:?}", value, self);
        match self {
                pair.1.insert_from_right(value);
    fn split(&mut self) -> bool {
        match self {
            SnailfishNumber::Regular(value) => {
                if *value >= 10 {
                    *self =
                        SnailfishNumber::regpair(*value / 2, (*value + 1) / 2);
                    true
                } else {
                    false
            SnailfishNumber::Pair(pair) => pair.0.split() || pair.1.split(),
    fn magnitude(&self) -> u32 {
        //println!("Finding magnitude of {:?}", self);
        match self {
            SnailfishNumber::Regular(v) => *v,
                3 * pair.0.magnitude() + 2 * pair.1.magnitude()
fn add(left: SnailfishNumber, right: SnailfishNumber) -> SnailfishNumber {
    let mut result = SnailfishNumber::pair(left, right);
    result.reduce();
    result
fn sum_vec(numbers: &Vec<SnailfishNumber>) -> SnailfishNumber {
    numbers
        .iter()
        .skip(1)
        .fold(numbers[0].clone(), |acc, num| add(acc, num.clone()))
pub fn parse_input(input: &str) -> Vec<SnailfishNumber> {
    input
        .lines()
        .map(|line| read_snailfish_number(&mut line.chars()))
        .collect()
pub fn task1(input: &Vec<SnailfishNumber>) -> u32 {
    sum_vec(input).magnitude()
pub fn task2(input: &Vec<SnailfishNumber>) -> u32 {
    let mut best = 0;
    for i in 0..input.len() {
        for j in 0..input.len() {
            if i != j {
                best = std::cmp::max(
                    best,
                    add(input[i].clone(), input[j].clone()).magnitude(),
    best
#[cfg(test)]
mod test {
    use super::*;
    #[test]
    fn test_reduce() {
        let data = "[[[[[9,8],1],2],3],4]
[[6,[5,[4,[3,2]]]],1]
[[3,[2,[8,0]]],[9,[5,[4,[3,2]]]]]
[[[[[4,3],4],4],[7,[[8,4],9]]],[1,1]]";
        let expected = "[[[[0,9],2],3],4]
[[6,[5,[7,0]]],3]
[[3,[2,[8,0]]],[9,[5,[7,0]]]]
[[[[0,7],4],[[7,8],[6,0]]],[8,1]]";
        let mut nums = parse_input(&data);
        for (input, expected) in nums.iter_mut().zip(expected.lines()) {
            input.reduce();
            assert_eq!(format!("{:?}", input), expected);
    #[test]
    fn test_magnitude() {
        for (input, expected) in parse_input(
            "[[1,2],[[3,4],5]]
[[[[1,1],[2,2]],[3,3]],[4,4]]
[[[[3,0],[5,3]],[4,4]],[5,5]]
[[[[5,0],[7,4]],[5,5]],[6,6]]
[[[[8,7],[7,7]],[[8,6],[7,7]]],[[[0,7],[6,6]],[8,7]]]",
        .iter()
        .zip([143, 1384, 445, 791, 1137, 3488].into_iter())
            assert_eq!(input.magnitude(), expected);
    #[test]
    fn test_add1() {
        let nums = &parse_input(
            "[1,1]
[2,2]",
        let sum = add(nums[0].clone(), nums[1].clone());
        assert_eq!(format!("{:?}", sum), "[[1,1],[2,2]]");
    #[test]
    fn test_add3() {
            "[[[[4,3],4],4],[7,[[8,4],9]]]
[1,1]",
        assert_eq!(format!("{:?}", sum), "[[[[0,7],4],[[7,8],[6,0]]],[8,1]]");
    #[test]
    fn test_add2() {
            "[[[0,[4,5]],[0,0]],[[[4,5],[2,6]],[9,5]]]
[7,[[[3,7],[4,3]],[[6,3],[8,8]]]]",
        assert_eq!(
            "[[[[4,0],[5,4]],[[7,7],[6,0]]],[[8,[7,7]],[[7,9],[5,0]]]]"
    #[test]
    fn test_sum1() {
        let data = "[1,1]
[2,2]
[3,3]
[4,4]";
        let num = parse_input(&data);
        let result = sum_vec(&num);
        assert_eq!(format!("{:?}", &result), "[[[[1,1],[2,2]],[3,3]],[4,4]]");
    #[test]
    fn test_sum2() {
        let data = "[1,1]
[2,2]
[3,3]
[4,4]
[5,5]";
        assert_eq!(format!("{:?}", &result), "[[[[3,0],[5,3]],[4,4]],[5,5]]");
    #[test]
    fn test_sum3() {
        let data = "[1,1]
[2,2]
[3,3]
[4,4]
[5,5]
[6,6]";
        assert_eq!(format!("{:?}", &result), "[[[[5,0],[7,4]],[5,5]],[6,6]]");
    #[test]
    fn test_task1() {
        let data = "[[[0,[5,8]],[[1,7],[9,6]]],[[4,[1,2]],[[1,4],2]]]
[[[5,[2,8]],4],[5,[[9,9],0]]]
[6,[[[6,2],[5,6]],[[7,6],[4,7]]]]
[[[6,[0,7]],[0,9]],[4,[9,[9,0]]]]
[[[7,[6,4]],[3,[1,3]]],[[[5,5],1],9]]
[[6,[[7,3],[3,2]]],[[[3,8],[5,7]],4]]
[[[[5,4],[7,7]],8],[[8,3],8]]
[[9,3],[[9,9],[6,[4,9]]]]
[[2,[[7,7],7]],[[5,8],[[9,3],[0,2]]]]
[[[[5,2],5],[8,[3,7]]],[[5,[7,5]],[4,4]]]";
        assert_eq!(task1(&parse_input(&data)), 4140);
Довелося додавати купу тестів і дебажити. Ну і Rust опирається.
17 поки що пропустив.
Подякували: dot1
67
Re: Advent of Code
year2021/day20.rs
#[derive(Clone)]
struct Algo(Vec<u8>);
#[derive(Clone)]
struct Image(Vec<Vec<u8>>);
pub struct ImageData {
    algo: Algo,
    image: Image,
impl std::fmt::Debug for Image {
    fn fmt(&self, f: &mut std::fmt::Formatter<'_>) -> std::fmt::Result {
        for line in self.0.iter() {
            for &ch in line {
                write!(f, "{}", if ch == 1 { '#' } else { '.' })?;
            writeln!(f)?;
        Ok(())
fn char_to_bit(c: char) -> u8 {
    match c {
        '#' => 1,
        '.' => 0,
        _ => panic!("Wrong char in input: {}", c),
pub fn parse_input(input: &str) -> ImageData {
    let mut input = input.lines();
    let algo = Algo(input.next().unwrap().chars().map(char_to_bit).collect());
    let image = Image(
        input
            .skip(1)
            .map(|line| line.chars().map(char_to_bit).collect())
            .collect(),
    ImageData { algo, image }
impl Image {
    fn enhance(&mut self, algo: &Algo, step: usize) {
        let height = self.0.len();
        let width = self.0[1].len();
        let outer = algo.get_outer_symbol(step);
        self.0 = (0..height + 2)
            .map(|y| {
                (0..width + 2)
                    .map(|x| {
                        algo.0
                            [self.get_binary(x as i32 - 1, y as i32 - 1, outer)]
                    .collect()
            .collect();
    fn get_binary(&self, x: i32, y: i32, outer: u8) -> usize {
        let mut binary = 0;
        for i in y - 1..y + 2 {
            for j in x - 1..x + 2 {
                let v = if 0 <= i
                    && i < self.0.len() as i32
                    && 0 <= j
                    && j < self.0[0].len() as i32
                    self.0[i as usize][j as usize]
                } else {
                    outer
                binary = (binary << 1) | v as usize;
        binary
    fn lit_pixels(&self) -> usize {
        self.0
            .iter()
            .flat_map(|line| line.iter().map(|&bit| bit as usize))
            .sum()
impl Algo {
    fn get_outer_symbol(&self, step: usize) -> u8 {
        if step == 0 || *self.0.first().unwrap() == 0 {
            0
        } else if *self.0.last().unwrap() == 1 {
        } else {
            (step % 2) as u8
pub fn task(input: &ImageData, count: usize) -> usize {
    let mut image = input.image.clone();
    for i in 0..count {
        image.enhance(&input.algo, i);
    image.lit_pixels()
pub fn task1(input: &ImageData) -> usize {
    task(input, 2)
pub fn task2(input: &ImageData) -> usize {
    task(input, 50)
#[cfg(test)]
mod test {
    use super::*;
    fn get_test_data() -> ImageData {
        let data = "..#.#..#####.#.#.#.###.##.....###.##.#..###.####..#####..#....#..#..##..###..######.###...####..#..#####..##..#.#####...##.#.#..#.##..#.#......#.###.######.###.####...#.##.##..#..#..#####.....#.#....###..#.##......#.....#..#..#..##..#...##.######.####.####.#.#...#.......#..#.#.#...####.##.#......#..#...##.#.##..#...##.#.##..###.#......#.#.......#.#.#.####.###.##...#.....####.#..#..#.##.#....##..#.####....##...##..#...#......#.#.......#.......##..####..#...#.#.#...##..#.#..###..#####........#..####......#..#
        parse_input(&data)
    #[test]
    fn test_get_binary() {
        let data = get_test_data();
        assert_eq!(data.image.get_binary(2, 2, 0), 34);
    #[test]
    fn test_task1() {
        assert_eq!(task1(&get_test_data()), 35);
    #[test]
    fn test_task2() {
        assert_eq!(task2(&get_test_data()), 3351);
Щось зі складністю недороблене, друге завдання - тупо з параметром 50 замість 2.
Подякували: dot1
68
Re: Advent of Code
year2021/day21
#[derive(Clone, Debug, PartialEq, Eq, Hash)]
pub struct Player {
    position: usize,
    score: usize,
impl Player {
    fn new(position: usize) -> Player {
        Player { position, score: 0 }
#[derive(Clone)]
pub struct Game {
    players: Vec<Player>,
    turn: usize,
    dice_value: usize,
    dice_rolled: usize,
pub fn parse_input(input: &str) -> Vec<usize> {
    input
        .lines()
        .map(|line| line.split(": ").skip(1).next().unwrap().parse().unwrap())
        .collect()
impl Game {
    const WIN_SCORE: usize = 1000;
    const BOARD_SIZE: usize = 10;
    const DICE_SIZE: usize = 100;
    fn new(player_pos: &Vec<usize>) -> Game {
        Game {
            players: player_pos.iter().map(|&pos| Player::new(pos)).collect(),
            turn: 0,
            dice_value: 1,
            dice_rolled: 0,
    fn step(&mut self) {
        let whos_turn = self.turn % self.players.len();
        self.players[whos_turn].position = (self.players[whos_turn].position
            + self.roll()
            + self.roll()
            + self.roll()
            - 1)
            % Game::BOARD_SIZE
            + 1;
        self.players[whos_turn].score += self.players[whos_turn].position;
        self.turn += 1;
    fn roll(&mut self) -> usize {
        let roll = self.dice_value;
        self.dice_rolled += 1;
        self.dice_value = self.dice_value % Game::DICE_SIZE + 1;
        roll
    fn ended(&self) -> bool {
        self.players
            .iter()
            .any(|player| player.score >= Game::WIN_SCORE)
    fn less_score(&self) -> usize {
        self.players
            .iter()
            .map(|player| player.score)
            .min()
            .unwrap()
pub fn task1(input: &Vec<usize>) -> usize {
    let mut game = Game::new(input);
    while !game.ended() {
        game.step();
    game.less_score() * game.dice_rolled
#[derive(Clone, Debug)]
pub struct DiracGame {
    //universes: Vec<(Vec<Player>, u128)>,
    universes: std::collections::HashMap<Vec<Player>, u128>,
    wins: Vec<u128>,
    turn: usize,
impl DiracGame {
    //roll, number of universes
    const DIRAC_CUBE: [(usize, u128); 7] =
        [(3, 1), (4, 3), (5, 6), (6, 7), (7, 6), (8, 3), (9, 1)];
    const WIN_SCORE: usize = 21;
    fn new(pos: &Vec<usize>) -> DiracGame {
        DiracGame {
            universes: [(
                pos.iter().map(|&position| Player::new(position)).collect(),
                1,
            .into(),
            wins: vec![0; pos.len()],
            turn: 0,
        self.universes.is_empty()
        let whos_turn = self.turn % self.wins.len();
        let mut universes = std::collections::HashMap::new();
        for (players, old_universes) in &self.universes {
            for (roll, roll_universes) in DiracGame::DIRAC_CUBE {
                let new_position = (players[whos_turn].position + roll - 1)
                    % DiracGame::BOARD_SIZE
                    + 1;
                let new_score = players[whos_turn].score + new_position;
                if new_score >= DiracGame::WIN_SCORE {
                    self.wins[whos_turn] += old_universes * roll_universes;
                } else {
                    let mut new_players = players.clone();
                    new_players[whos_turn].position = new_position;
                    new_players[whos_turn].score = new_score;
                    *universes.entry(new_players).or_insert(0) +=
        self.universes = universes;
        self.turn += 1;
pub fn task2(input: &Vec<usize>) -> u128 {
    let mut game = DiracGame::new(input);
        game.step();
    *game.wins.iter().max().unwrap()
#[cfg(test)]
mod test {
    use super::*;
    #[test]
    fn test_task1() {
        let data = parse_input(
            &"Player 1 starting position: 4
Player 2 starting position: 8",
        assert_eq!(task1(&data), 739785);
    #[test]
    fn test_task2() {
        assert_eq!(task2(&data), 444356092776315);
Подякували: dot1
69
Re: Advent of Code
year2021/day25.rs - task1
#[derive(Clone, Copy, PartialEq)]
enum Cucumber {
    Right,
    Down,
    Empty,
impl From<char> for Cucumber {
    fn from(c: char) -> Cucumber {
        match c {
            '>' => Cucumber::Right,
            'v' => Cucumber::Down,
            '.' => Cucumber::Empty,
            _ => panic!(),
impl Cucumber {
    fn to_char(self) -> char {
        match self {
            Cucumber::Right => '>',
            Cucumber::Down => 'v',
            Cucumber::Empty => '.',
#[derive(Clone)]
pub struct Seafloor {
    cucumbers: Vec<Vec<Cucumber>>,
    turn: usize,
impl std::fmt::Debug for Seafloor {
        writeln!(f, "Turn = {}", self.turn)?;
        for line in &self.cucumbers {
            writeln!(
                f,
                line.iter().map(|c| c.to_char()).collect::<String>()
        Ok(())
impl Seafloor {
    fn step(&mut self) -> bool {
        let height = self.cucumbers.len();
        let width = self.cucumbers[0].len();
        let mut changed = false;
        for cucumber_kind in [Cucumber::Right, Cucumber::Down] {
            let mut new_field = vec![vec![Cucumber::Empty; width]; height];
            for line_idx in 0..height {
                for col_idx in 0..width {
                    if self.cucumbers[line_idx][col_idx] == cucumber_kind {
                        let (line_tgt, col_tgt) =
                            self.target(cucumber_kind, line_idx, col_idx);
                        if self.cucumbers[line_tgt][col_tgt] == Cucumber::Empty
                            new_field[line_tgt][col_tgt] = cucumber_kind;
                            changed = true;
                        } else {
                            new_field[line_idx][col_idx] = cucumber_kind;
                    } else if self.cucumbers[line_idx][col_idx]
                        != Cucumber::Empty
                            self.cucumbers[line_idx][col_idx];
            self.cucumbers = new_field;
        self.turn += 1;
        changed
    fn target(
        &self,
        kind: Cucumber,
        line: usize,
        col: usize,
    ) -> (usize, usize) {
        match kind {
            Cucumber::Right => (line, (col + 1) % self.cucumbers[line].len()),
            Cucumber::Down => ((line + 1) % self.cucumbers.len(), col),
            _ => panic!(),
pub fn parse_input(input: &str) -> Seafloor {
    Seafloor {
        cucumbers: input
            .lines()
            .map(|line| line.chars().map(|c| c.into()).collect())
            .collect(),
        turn: 0,
pub fn task1(seafloor: &Seafloor) -> usize {
    let mut seafloor = seafloor.clone();
    while seafloor.step() {
        //println!("{:?}", seafloor);
    seafloor.turn
pub fn task2(_seafloor: &Seafloor) -> usize {
    0
#[cfg(test)]
mod test {
    use super::*;
    #[test]
    fn test_task1() {
        let input = "v...>>.vv>
.vv>>.vv..
>>.>v>...v
>>v>>.>.v.
v>v.vv.v..
>.>>..v...
.vv..>.>v.
v.v..>>v.v
....v..v.>";
        let seafloor = parse_input(&input);
        assert_eq!(task1(&seafloor), 58);
Подякували: dot1
70 Востаннє редагувалося koala (28.12.2021 00:48:19)
Re: Advent of Code
Так, тепер те, на чому я зламався. Ну добре, не зламався, просто недокрутив. Сподіваюся, що тут розпишу і зрозумію, як розв'язувати.
День 17. Стріляємо з точки (0,0) об'єктом із початковою швидкістю (vx,vy). Кожен крок симуляції vx та vy додаються до координат об'єкта, після чого зменшуються на 1 - vx до 0, vy іде в мінус нескінченість. Яка має бути початкова швидкість, щоб об'єкт піднявся на максимальну висоту, а потім на певному кроці опинився в прямокутній зоні (x1..x2)x(y1..y2)?
Для початку - горизонтальна координата. За vx кроків горизонтальна швидкість падає до 0, положення по x в момент t визначається як vx*t-t*(t-1)/2 до цього моменту і, очевидно, vx*(vx+1)/2 після. Якщо таке значення потрапляє в x1..x2 - беремо саме його, щоб не залежати від часу, інакше у нас лише кілька моментів, поки об'єкт в зоні, і поки не будемо про погане. У прикладі і моїх початкових даних x1 та x2 захоплюють потрібну точку, далі не думаємо.
Вертикальна координата. Тут y=vy*t-t*(t-1)/2 постійно; це - перевернута парабола з вершиною в vy+1/2, що досить логічно: в момент t=vy вертикальна швидкість падає до 0, і  в y(t=vy) та y(t=vy+1) буде однаковим. Висота у цей момент буде vy*vy-vy*(vy-1)/2 = vy*(vy+1)/2. Іншими словами, треба максимізувати vy серед прийнятних. А далі іде падіння, і в певний момент має настати y1<=vy*t-t*(t-1)/2<=y2. А от далі я щось гальмую. Треба знати максимальне vy, при якому t буде лишатися цілим. Перша нерівність (з y1) задає для t інтервал між коренями квадратного рівняння t∈ [t1_1;t1_2]; друге - виключає аналогічний інтервал: t ∉ (t2_1;t2_2). Із загальних міркувань це має дати інтервал t2_2<=t<=t1_2. Гм.
t^2-(2*vy+1)*t+2*y1 = 0
D = 4vy^2+4vy+1-8*y1
t1_2 = (2*vy+1+sqrt(4vy^2+4vy+1-8*y1))/2
Аналогічно,
t2_2 = (2*vy+1+sqrt(4vy^2+4vy+1-8*y2))/2
А тепер треба задати умову, щоб між цими двома значеннями має бути ціле число. І тут щось пішло не так. Хтось щось підкаже? Чи тупо перебором vy шукати? А як зупиняти? Де гарантія, що в районі 1000000 не буде такого значення, що воно туди потрапить?
71
Re: Advent of Code
Як і слід було очікувати, сам факт розписування відповіді надав мені потрібний поштовх (але чомусь коли я розписував це в коментарях, воно не спрацювало).
приховаю, може, хтось ще подумає
Координата за y, якщо дивитися з вершини параболи, утворює послідовність 1, 3, 6, 10 (трикутні числа) - спершу в зворотному порядку, потім у прямому. На кроці 2*vy+1 координата буде така сама, як і перед запуском. Відповідно, наступні кроки після перетину початкової горизонталі будуть послідовністю vy+1, vy+1 + vy+2 і т.д. Найбільше можливе vy у цих умовах - це 1-y2 (перший крок під нульову горизонталь потрапляє в y2). Навіть рахувати не треба.
Друга частина дещо цікавіша, але із цими формулами буде легко.
Подякували: dot, leofun012
72 Востаннє редагувалося koala (29.12.2021 12:45:00)
Re: Advent of Code
year2021/day17.rs
type Rect = ((i32, i32), (i32, i32));
pub fn parse_input(input: &str) -> Rect {
    let mut parts = input["target area: ".len()..].split(", ");
    let mut xs = parts.next().unwrap()["x=".len()..]
        .split("..")
        .map(|x| x.parse().unwrap());
    let mut ys = parts.next().unwrap()["x=".len()..]
        .split("..")
        (xs.next().unwrap(), ys.next().unwrap()),
pub fn task1(input: &Rect) -> i32 {
    let &((x1, y1), (x2, _y2)) = input;
    //x1<=vx*(vx+1)/2<=x2
    //2*x1<=vx**2 + vx<=2*x2
    let vx = (((1 + 8 * x2) as f64).sqrt() as i32 - 1) / 2;
    assert!(vx * (vx + 1) / 2 >= x1, "Probe don't stop, vx={}", vx);
    let vy = (y1 + 1).abs();
    vy * (vy + 1) / 2
fn get_all_velocities(input: &Rect) -> std::collections::HashSet<(i32, i32)> {
    let &((x1, y1), (x2, y2)) = input;
    let max_t = 2 * y1.abs();
    let mut result = std::collections::HashSet::new();
    for t in 1..=max_t {
        let mut vx_min = (x1 + t * (t - 1) / 2 + t - 1) / t;
        if vx_min < t {
            vx_min = ((((1 + 8 * x1) as f64).sqrt() - 1.0) / 2.0).ceil() as i32;
        let mut vx_max = (x2 + t * (t - 1) / 2) / t;
        if vx_max < t {
            vx_max = ((((1 + 8 * x2) as f64).sqrt() - 1.0) / 2.0) as i32;
        let vy_min = ((y1 + t * (t - 1) / 2) as f64 / t as f64).ceil() as i32;
        let vy_max = ((y2 + t * (t - 1) / 2) as f64 / t as f64).floor() as i32;
        /*let r = std::cmp::max(0, vx_max - vx_min + 1) as usize
            * std::cmp::max(0, vy_max - vy_min + 1) as usize;
        println!(
            "t={}, vx={}..{}, vy={}..{}, total={}",
            t, vx_min, vx_max, vy_min, vy_max, r
        for vx in vx_min..=vx_max {
            for vy in vy_min..=vy_max {
                result.insert((vx, vy));
    result
pub fn task2(input: &Rect) -> usize {
    get_all_velocities(input).len()
#[cfg(test)]
mod test {
    use super::*;
    #[test]
    fn test_task1() {
        assert_eq!(task1(&((20, -10), (30, -5))), 45);
    #[test]
    fn test_task2() {
        assert_eq!(task2(&((20, -10), (30, -5))), 112);
    use itertools::Itertools;
    #[test]
    fn test_get_all_velocities() {
        let expected_str = "23,-10  25,-9   27,-5   29,-6   22,-6   21,-7   9,0     27,-7   24,-5
25,-7   26,-6   25,-5   6,8     11,-2   20,-5   29,-10  6,3     28,-7
8,0     30,-6   29,-8   20,-10  6,7     6,4     6,1     14,-4   21,-6
26,-10  7,-1    7,7     8,-1    21,-9   6,2     20,-7   30,-10  14,-3
20,-8   13,-2   7,3     28,-8   29,-9   15,-3   22,-5   26,-8   25,-8
25,-6   15,-4   9,-2    15,-2   12,-2   28,-9   12,-3   24,-6   23,-7
25,-10  7,8     11,-3   26,-7   7,1     23,-9   6,0     22,-10  27,-6
8,1     22,-8   13,-4   7,6     28,-6   11,-4   12,-4   26,-9   7,4
24,-10  23,-8   30,-8   7,0     9,-1    10,-1   26,-5   22,-9   6,5
7,5     23,-6   28,-10  10,-2   11,-1   20,-9   14,-2   29,-7   13,-3
23,-5   24,-8   27,-9   30,-7   28,-5   21,-10  7,9     6,6     21,-5
27,-10  7,2     30,-9   21,-8   22,-7   24,-9   20,-6   6,9     29,-5
8,-2    27,-8   30,-5   24,-7";
        let expected = expected_str
            .split_whitespace()
            .map(|pair| {
                pair.split(',')
                    .map(|n| n.parse().unwrap())
                    .collect_tuple()
                    .unwrap()
            .collect();
        let result = get_all_velocities(&((20, -10), (30, -5)));
        if result != expected {
            let extra: Vec<_> = result.difference(&expected).collect();
            if !extra.is_empty() {
                println!("Extra values: {:?}", extra);
            let lost: Vec<_> = expected.difference(&result).collect();
            if !lost.is_empty() {
                println!("Lost values: {:?}", lost);
            assert!(false);
Довелося трохи помучитися з округленням негативних значень. Ну і прогальмував, що деякі пари дають кілька потраплянь у зону, тому все ж таки потрібен HashSet.
Тепер день 19: є множини координат зондів в системах координат різних сканерів. Сканери завжди ведуть відлік від себе в (0,0,0) і можуть бути розвернути по всіх осях як завгодно по 90°, але бачать лише на певну відстань навколо. Скільки там зондів?
Планую шукати унікальні відстані між зондами (для простоти - квадрати відстаней) і суміщати по них.
73 Востаннє редагувалося koala (05.01.2022 10:42:11)
Re: Advent of Code
Щось за день 19 ніяк не візьмуся. Поки зробив
year2021/day22.rs
#[derive(Clone)]
pub enum State {
    On,
    Off,
#[derive(PartialEq, Clone)]
pub struct Zone {
    limits: [std::ops::RangeInclusive<i32>; 3],
enum Intersection {
    Intersects(usize),
    Equals,
    None,
impl Zone {
    fn intersects(&self, other: &Zone) -> Intersection {
        if self.limits == other.limits {
            return Intersection::Equals;
        for coordinate in 0..3 {
            if self.limits[coordinate].start() > other.limits[coordinate].end()
                || self.limits[coordinate].end()
                    < other.limits[coordinate].start()
                return Intersection::None;
                != other.limits[coordinate].start()
                    != other.limits[coordinate].end()
                return Intersection::Intersects(coordinate);
        unreachable!("Zone::intersects fails");
#[derive(Clone)]
pub struct Command {
    state: State,
    zone: Zone,
impl Command {
    fn new(input: &str) -> Command {
        lazy_static::lazy_static! {
            //on x=-20..26,y=-36..17,z=-47..7
            static ref INPUT_REGEX: regex::Regex = regex::Regex::new(r"(on|off) x=(-?[\d]+)..(-?[\d]+),y=(-?[\d]+)..(-?[\d]+),z=(-?[\d]+)..(-?[\d]+)").unwrap();
        let captures = INPUT_REGEX.captures(input).unwrap();
        let mut iter = captures.iter().skip(1);
        let mut result = Command {
            state: if iter.next().unwrap().unwrap().as_str() == "on" {
                State::On
            } else {
                State::Off
            zone: Zone {
                limits: [0..=0, 0..=0, 0..=0],
            result.zone.limits[coordinate] =
                iter.next().unwrap().unwrap().as_str().parse().unwrap()
                    ..=iter.next().unwrap().unwrap().as_str().parse().unwrap();
        result
struct Reactor {
    cubes: Vec<Zone>,
impl Reactor {
    fn new() -> Reactor {
        Reactor { cubes: Vec::new() }
    fn add(&mut self, command: &Command) {
        let mut idx = 0;
        while idx < self.cubes.len() {
            match self.cubes[idx].intersects(&command.zone) {
                Intersection::Equals => {
                    if let State::Off = command.state {
                        self.cubes.remove(idx);
                    return;
                Intersection::Intersects(coordinate) => {
                    match self.cubes[idx].limits[coordinate]
                        .start()
                        .cmp(&command.zone.limits[coordinate].start())
                        std::cmp::Ordering::Less => {
                            let removed = self.cubes.remove(idx).clone();
                            let mut left = removed.clone();
                            left.limits[coordinate] = *removed.limits
                                [coordinate]
                                .start()
                                ..=*command.zone.limits[coordinate].start() - 1;
                            let mut right = removed;
                            right.limits[coordinate] =
                                    ..=*right.limits[coordinate].end();
                            self.cubes.push(left);
                            self.cubes.push(right);
                        std::cmp::Ordering::Greater => {
                            let mut left = command.clone();
                            left.zone.limits[coordinate] = *command.zone.limits
                                [coordinate]
                                .start()
                                ..=*self.cubes[idx].limits[coordinate].start()
                                    - 1;
                            let mut right = command.clone();
                            right.zone.limits[coordinate] =
                                    ..=*command.zone.limits[coordinate].end();
                            self.add(&left);
                            self.add(&right);
                            return;
                        std::cmp::Ordering::Equal => {
                                .end()
                                .cmp(&command.zone.limits[coordinate].end())
                                    let removed = self.cubes.remove(idx);
                                        *removed.limits[coordinate].start()
                                                .end();
                                    let mut right = removed.clone();
                                            + 1
                                            ..=*removed.limits[coordinate]
                                                .end();
                                        .zone
                                        .limits[coordinate]
                                        .start()
                                            .end();
                                            .end()
                                            + 1
                                                .end();
                                    self.add(&left);
                                    self.add(&right);
                                    return;
                                _ => unreachable!(
                                    "Both ranges shoun't be equal!"
                _ => idx += 1,
        if let State::On = command.state {
            self.cubes.push(command.zone.clone());
    fn count(&self) -> usize {
        self.cubes
            .iter()
            .map(|zone| {
                zone.limits
                    .iter()
                    .map(|range| (range.end() - range.start() + 1) as usize)
                    .product::<usize>()
            .sum()
pub fn parse_input(input: &str) -> Vec<Command> {
    input.lines().map(|line| Command::new(line)).collect()
pub fn task1(commands: &Vec<Command>) -> usize {
    let mut reactor = Reactor::new();
    for command in commands {
        if command
            .zone
            .limits
            .iter()
            .all(|range| *range.start() <= 50 && *range.end() >= -50)
            reactor.add(command);
    reactor.count()
pub fn task2(commands: &Vec<Command>) -> usize {
    reactor.count()
Щось я перемудрив і недооптимізував (треба вектор на якесь дерево замінити, чи що), але в будь-якому разі воно виконується в релізній версії за 1.7 секунди. В дебажній досі чекаю :)
Подякували: dot1
74
Re: Advent of Code
О, завершилося. Якихось 8 хвилин, а мені ліньки дочекатися було.
   Compiling advent_of_code v0.1.0 (C:\Users\Pavlo\Documents\Program Languages\rust\advent_of_code)
    Finished dev [unoptimized + debuginfo] target(s) in 4.40s
     Running `target\debug\advent_of_code.exe`
year2021 day22
Result 1: 648681
Result 2: 1302784472088899
Time elapsed: 416185ms
[Finished in 421.2s]
75
Re: Advent of Code
Dosjê ne zaveršyv jakyjsj rôk, xex. Ale tšas vôd tšasu proxodžu stari propuštšeni. Osj tut np. vôdkryv dlja sebe funktsiju maketrans, štšo korysna pry ssuvê Tsezara.
2016#04 Python 30.10.4
import re, string
from collections import Counter
with open("input.txt") as file:
    sum_sid = 0
    abc = string.ascii_lowercase
    for name, sid, checksum in re.findall(r"([a-z-]+)(\d+)\[(\w+)\]", file.read()):
        sid = int(sid)
        if "".join(l for _, l in sorted((-n, l) for l, n in Counter(name.replace("-", "")).most_common())).startswith(checksum):
            sum_sid += sid
        if "north" in name.translate(name.maketrans(abc, abc[sid % len(abc) :] + abc[: sid % len(abc)])):
            print(sid)  # Part Two: 324
    print(sum_sid)  # Part One: 245102
76 Востаннє редагувалося dot (11.10.2022 03:32:55)
Re: Advent of Code
AoC bude v 2022 roku.
77 Востаннє редагувалося dot (01.12.2022 19:55:42)
Re: Advent of Code
2022#01 Python
elves = sorted(map(sum, [map(int, elf.split()) for elf in open("input.txt").read().split("\n\n")]))
print(elves[-1])  # Part One: 68442
print(sum(elves[-3:]))  # Part Two: 204837
Подякували: leofun01, koala2
78
Re: Advent of Code
Умова: ельфи мають в рюкзаках смаколики, калорійність яких вказана в рядках завдання, різні ельфи відокремлені порожнім рядком. Знайти:
1. Найбільшу суму калорійностей смаколиків в одного ельфа
2. 3 найбільші суми
2022#01 Rust
pub fn parse_input(input: &str) -> Vec<u32> {
    let mut result = vec![0];
    for calories in input.lines() {
        if let Ok(calories) = calories.parse::<u32>() {
            let idx = result.len() - 1;
            result[idx] += calories;
        } else {
            result.push(0);
    result.sort();
    result
pub fn task1(elves: &[u32]) -> u32 {
    elves[elves.len() - 1]
pub fn task2(elves: &[u32]) -> u32 {
    elves[elves.len() - 3..].iter().sum()
Подякували: leofun01, dot2
79
Re: Advent of Code
2022#2, Python
by_selected: int = 0
by_outcome: int = 0
selected = {
    "X": 1,
    "Y": 2,
    "Z": 3,
outcome = {
    "A": [3, 6, 0],
    "B": [0, 3, 6],
    "C": [6, 0, 3],
    for line in file:
        elf, me = line.split()
        by_selected += selected[me] + outcome[elf][selected[me] - 1]
        result = (selected[me] - 1) * 3
        by_outcome += result + outcome[elf].index(result) + 1
print(by_selected)  # Part One: 10941
print(by_outcome)  # Part Two: 13071
80 Востаннє редагувалося koala (02.12.2022 14:40:23)
Re: Advent of Code
У ельфів чемпіонат з Каменя-Ножиць-Паперу. Очки даються за фігуру (камінь-1, папір-2, ножиці-3) і результат (поразка-0, нічия-3, перемога-6), тобто якщо гравець показав камінь і виграв, то отримує 7 балів. Є інструкція (запис матчу) з рядків, де перша літера A,B,C, а друга (через пробіл) - X,Y,Z. A,B,C позначає відповідно камінь, папір і ножиці опонента. Знайти очки за матч, якщо:
1. X,Y,Z означає ваші камінь, папір і ножиці відповідно;
2. X,Y,Z означає ваші поразку, нічию і перемогу відповідно.
2022#2, Rust
pub fn parse_input(input: &str) -> Vec<&str> {
    input.lines().collect()
// score for the second player
fn outcome(line: &str) -> i32 {
    match line {
        "A X" => 3 + 1,
        "A Y" => 6 + 2,
        "A Z" => 0 + 3,
        "B X" => 0 + 1,
        "B Y" => 3 + 2,
        "B Z" => 6 + 3,
        "C X" => 6 + 1,
        "C Y" => 0 + 2,
        "C Z" => 3 + 3,
        _ => panic!(),
pub fn task1(input: &[&str]) -> i32 {
    input.iter().map(|line| outcome(line)).sum()
fn correct_outcome(line: &str) -> i32 {
    match line {
        "A X" => 0 + 3,
        "A Y" => 3 + 1,
        "A Z" => 6 + 2,
        "B X" => 0 + 1,
        "B Y" => 3 + 2,
        "B Z" => 6 + 3,
        "C X" => 0 + 2,
        "C Y" => 3 + 3,
        "C Z" => 6 + 1,
        _ => panic!(),
pub fn task2(input: &[&str]) -> i32 {
    input.iter().map(|line| correct_outcome(line)).sum()
Ліньки було з модулями розбиратися, всього 9 рядків. Мабуть, Спока і Ящірку б теж хардкодив. От якби щось таке було...
оновив картинку...
https://replace.org.ua/uploads/images/931/73b1aab452327bac976af4a62e3229a3.jpg
