Тема: Проблема з частотою ОЗП.
Доброго дня всім. Слава Україні та ЗСУ! Смерть ворогам!
Таке питання: зібрав нового ПК, та щось оперативка не хоче працювати на максимальній частоті...
Ось звіт із CPU-z:
ЦП
Socket 1    ID = 0
     Number of cores    6 (max 6)
     Number of threads    12 (max 12)
     Number of CCDs    1
     Manufacturer    AuthenticAMD
     Name    AMD Ryzen 5 5600X
     Codename    Vermeer
     Specification    AMD Ryzen 5 5600X 6-Core Processor
     Package    Socket AM4 (1331)
     CPUID    F.1.2
     Extended CPUID    19.21
     Core Stepping    VRM-B2
     Technology    7 nm
     TDP Limit    65.0 Watts
     Tjmax    95.0 АC
     Core Speed    3712.5 MHz
     Multiplier x Bus Speed    37.2 x 99.8 MHz
     Base frequency (cores)    99.8 MHz
     Base frequency (ext.)    99.8 MHz
     Instructions sets    MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
     Microcode Revision    0xA201204
     L1 Data cache    6 x 32 KB (8-way, 64-byte line)
     L1 Instruction cache    6 x 32 KB (8-way, 64-byte line)
     L2 cache    6 x 512 KB (8-way, 64-byte line)
     L3 cache    32 MB (16-way, 64-byte line)
     Max CPUID level    00000010h
     Max CPUID ext. level    80000023h
     FID/VID Control    yes
     # of P-States    3
     P-State    FID 0x894 - VID 0x48 (37.00x - 1.100 V)
     P-State    FID 0xA8C - VID 0x58 (28.00x - 1.000 V)
     P-State    FID 0xC84 - VID 0x68 (22.00x - 0.900 V)
     PStateReg    0x80000000-0x49520894
     PStateReg    0x80000000-0x47160A8C
     PStateReg    0x80000000-0x459A0C84
     PStateReg    0x00000000-0x00000000
     Package Type    0x2
     Model    00
     String 1    0x0
     String 2    0x0
     Page    0x0
     Power Unit    0.0
     SMU Version    56.53.00
     TDP/TJMAX    0x41005F
     TCTL Offset    0x0
     PMTV    00380905
     Min Frequency    550 MHz
     Max Frequency    4650 MHz
     VID Limit    1.4500 Volts
     PBO Scalar    1
     Package Power Tracking (PPT)    Current : 76.0 W, fused : 76.0 W
     Thermal Design Current (TDC)    Current : 60.0 A, fused : 60.0 A
     Electrical Design Current (EDC)    Current : 90.0 A, fused : 90.0 A
     Temperature 0    47 degC (116 degF) (Package)
     Temperature 1    50 degC (121 degF) (CCD #0)
     Temperature 2    38 degC (101 degF) (Cores (Max))
     Temperature 3    38 degC (100 degF) (Core #0)
     Temperature 4    38 degC (100 degF) (Core #1)
     Temperature 5    38 degC (99 degF) (Core #2)
     Temperature 6    37 degC (99 degF) (Core #3)
     Temperature 7    38 degC (101 degF) (Core #4)
     Temperature 8    37 degC (98 degF) (Core #5)
     Temperature 9    38 degC (100 degF) (L3 Cache)
     Temperature 10    38 degC (99 degF) (SoC)
     Voltage 0    1.29 Volts (VID)
     Voltage 1    1.29 Volts (CPU VDD)
     Voltage 2    0.97 Volts (SoC VDD)
     Power 00    33.23 W (Package)
     Power 01    1.99 W (Cores)
     Power 02    0.52 W (Core #0)
     Power 03    0.71 W (Core #1)
     Power 04    3.74 W (Core #2)
     Power 05    5.45 W (Core #3)
     Power 06    1.76 W (Core #4)
     Power 07    0.42 W (Core #5)
     Power 08    0.77 W (L3 Cache)
     Clock Speed 0    3712.48 MHz (Core #0)
     Clock Speed 1    3712.48 MHz (Core #1)
     Clock Speed 2    3712.48 MHz (Core #2)
     Clock Speed 3    4640.59 MHz (Core #3)
     Clock Speed 4    4640.59 MHz (Core #4)
     Clock Speed 5    3712.48 MHz (Core #5)
     Core 0 max ratio    (effective) 46.50
     Core 1 max ratio    (effective) 46.50
     Core 2 max ratio    (effective) 46.50
     Core 3 max ratio    (effective) 46.50
     Core 4 max ratio    (effective) 46.50
     Core 5 max ratio    (effective) 46.50
Чипсет
Northbridge    AMD Ryzen SOC rev. 00
Southbridge    AMD B550 rev. 51
Bus Specification    PCI-Express 4.0 (16.0 GT/s)
Graphic Interface    PCI-Express 3.0
PCI-E Link Width    x4 (max 4x)
PCI-E Link Speed    5.0 GT/s (max 8.0 GT/s)
Memory Type    DDR4
Memory Size    16 GBytes
Channels    2 x 64-bit
Memory Frequency    1197.6 MHz (1:12)
Memory Max Frequency    1600.0 MHz
CAS# latency (CL)    17.0
RAS# to CAS# delay (tRCD)    17
RAS# Precharge (tRP)    17
Cycle Time (tRAS)    39
Bank Cycle Time (tRC)    56
Command Rate (CR)    1T
Uncore Frequency    1197.6 MHz
ОЗП
DIMM #    1
     SMBus address    0x52
     Memory type    DDR4
     Module format    UDIMM
     Module Manufacturer(ID)    Kingston (7F98000000000000000000000000)
     SDRAM Manufacturer (ID)    SK Hynix (AD00000000000000000000000000)
     Size    8192 MBytes
     Max bandwidth    DDR4-3200 (1600 MHz)
     Max JEDEC    DDR4-2400 (1200 MHz)
     Part number    KF3200C16D4/8GX
     Serial number    E14C4463
     Manufacturing date    Week 40/Year 21
     Nominal Voltage    1.20 Volts
     EPP    no
     XMP    yes, rev. 2.0
     AMP    no
JEDEC timings table    CL-tRCD-tRP-tRAS-tRC @ frequency
     JEDEC #1    10.0-11-11-24-34 @ 733 MHz
     JEDEC #2    11.0-11-11-26-37 @ 800 MHz
     JEDEC #3    12.0-12-12-28-40 @ 866 MHz
     JEDEC #4    13.0-13-13-30-43 @ 933 MHz
     JEDEC #5    14.0-15-15-34-48 @ 1033 MHz
     JEDEC #6    15.0-16-16-36-51 @ 1100 MHz
     JEDEC #7    16.0-17-17-38-54 @ 1166 MHz
     JEDEC #8    17.0-17-17-39-55 @ 1200 MHz
     JEDEC #9    18.0-17-17-39-55 @ 1200 MHz
XMP profile    XMP-3200
     Specification    DDR4-3200
     VDD Voltage    1.350 Volts
     Min Cycle time    0.625 ns (1600 MHz)
     Max CL    16.0
     Min tRP    11.25 ns
     Min tRCD    11.25 ns
     Min tRAS    22.50 ns
     Min tRC    45.75 ns
     Min tRRD    4.38 ns
XMP timings table    CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
     XMP #1    9.0-11-11-21-42-n.a @ 899 MHz (1.350 Volts)
     XMP #2    10.0-12-12-23-46-n.a @ 1000 MHz (1.350 Volts)
     XMP #3    11.0-13-13-25-51-n.a @ 1100 MHz (1.350 Volts)
     XMP #4    12.0-14-14-27-55-n.a @ 1200 MHz (1.350 Volts)
     XMP #5    13.0-15-15-30-60-n.a @ 1300 MHz (1.350 Volts)
     XMP #6    14.0-16-16-32-65-n.a @ 1400 MHz (1.350 Volts)
     XMP #7    15.0-17-17-34-69-n.a @ 1500 MHz (1.350 Volts)
     XMP #8    16.0-18-18-36-74-n.a @ 1600 MHz (1.350 Volts)
     XMP #9    17.0-18-18-36-74-n.a @ 1600 MHz (1.350 Volts)
     XMP #10    18.0-18-18-36-74-n.a @ 1600 MHz (1.350 Volts)
XMP profile    XMP-3002
     Specification    DDR4-3002
     Min Cycle time    0.666 ns (1501 MHz)
     Max CL    15.0
     Min tRP    11.32 ns
     Min tRCD    11.32 ns
     Min tRAS    23.88 ns
     Min tRC    45.75 ns
     Min tRRD    4.66 ns
     XMP #1    9.0-11-11-22-42-n.a @ 900 MHz (1.350 Volts)
     XMP #2    10.0-12-12-24-46-n.a @ 1001 MHz (1.350 Volts)
     XMP #3    11.0-13-13-27-51-n.a @ 1101 MHz (1.350 Volts)
     XMP #4    12.0-14-14-29-55-n.a @ 1201 MHz (1.350 Volts)
     XMP #5    13.0-15-15-32-60-n.a @ 1301 MHz (1.350 Volts)
     XMP #6    14.0-16-16-34-65-n.a @ 1401 MHz (1.350 Volts)
     XMP #7    15.0-17-17-36-69-n.a @ 1501 MHz (1.350 Volts)
     XMP #8    16.0-17-17-36-69-n.a @ 1501 MHz (1.350 Volts)
     XMP #9    17.0-17-17-36-69-n.a @ 1501 MHz (1.350 Volts)
     XMP #10    18.0-17-17-36-69-n.a @ 1501 MHz (1.350 Volts)
DIMM #    2
     SMBus address    0x53
     Memory type    DDR4
     Module format    UDIMM
     Size    8192 MBytes
     Serial number    598C4DED
     EPP    no
     XMP    yes, rev. 2.0
     AMP    no
     Max CL    16.0
     Min tRP    11.25 ns
     Min tRCD    11.25 ns
     Min tRAS    22.50 ns
     Min tRC    45.75 ns
     Min tRRD    4.38 ns
     Max CL    15.0
     Min tRP    11.32 ns
     Min tRCD    11.32 ns
     Min tRAS    23.88 ns
     Min tRC    45.75 ns
     Min tRRD    4.66 ns
Можливо хтось розуміючий підкаже в чому тут проблема, чи несумісність якась, чи в біосі треба щось ввімкнути?
Дякую!
Re: Проблема з частотою ОЗП.
drakulawz написав:
Ось звіт із CPU-z:
ЦП
Socket 1    ID = 0
     Number of CCDs    1
     Codename    Vermeer
     CPUID    F.1.2
     Technology    7 nm
     Tjmax    95.0 АC
     FID/VID Control    yes
     # of P-States    3
     Package Type    0x2
     Model    00
     String 1    0x0
     String 2    0x0
     Page    0x0
     Power Unit    0.0
     TDP/TJMAX    0x41005F
     TCTL Offset    0x0
     PMTV    00380905
     PBO Scalar    1
Чипсет
Memory Type    DDR4
Channels    2 x 64-bit
ОЗП
DIMM #    1
     SMBus address    0x52
     Memory type    DDR4
     Module format    UDIMM
     Size    8192 MBytes
     EPP    no
     XMP    yes, rev. 2.0
     AMP    no
     Max CL    16.0
     Min tRP    11.25 ns
     Min tRCD    11.25 ns
     Min tRAS    22.50 ns
     Min tRC    45.75 ns
     Min tRRD    4.38 ns
     Max CL    15.0
     Min tRP    11.32 ns
     Min tRCD    11.32 ns
     Min tRAS    23.88 ns
     Min tRC    45.75 ns
     Min tRRD    4.66 ns
DIMM #    2
     SMBus address    0x53
     Memory type    DDR4
     Module format    UDIMM
     Size    8192 MBytes
     EPP    no
     XMP    yes, rev. 2.0
     AMP    no
     Max CL    16.0
     Min tRP    11.25 ns
     Min tRCD    11.25 ns
     Min tRAS    22.50 ns
     Min tRC    45.75 ns
     Min tRRD    4.38 ns
     Max CL    15.0
     Min tRP    11.32 ns
     Min tRCD    11.32 ns
     Min tRAS    23.88 ns
     Min tRC    45.75 ns
     Min tRRD    4.66 ns
Дякую!
Треба ввімкнути XMP профіль у налаштуваннях пам'яті в BIOS/UEFI, бо зараз вона скоріше всього працює на JEDEC профілі який зазвичай десь на рівні 2400/2666, у вашому випадку як раз JDEC у пам'яті 2400 і система виставила аналогічно 2400.
Подякували: drakulawz1
Дякую за відповідь. Так, в принципі, й думав, але... Виникають наступні питання:
Чому в дужках указано: 2400(1200) при JDEC і 3200(1600) при XMP?
В дужках фактична частота, чи у двоканальному режимі і чому вона "ріжеться" в половину?
В CPU-z як раз 1200 показник... після ввімкнення XMP 1600 - де заявлені 3200?
Чи 3200 буде тільки коли "заб'ю" всі 4 слоти однаковою ОЗП?
4 Востаннє редагувалося HetmanNet (15.06.2022 12:42:15)
drakulawz написав:
В дужках то частота тактування, в той час як нам більш звична і зрозуміліша еквівалентна частота шини, яка є вдвічі вищою за тактування, так як пам'ять спрацьовує як по передньому так і задньому фронту сигналу тактування.
drakulawz написав:
Ні, вона не ріжеться через двоканальний режим
drakulawz написав:
Бо CPU-Z показує частоту тактування, яка є вдвічі нижчою за більш звичні нам числа які пишуть на пам'яті. Колись пам'ять спрацьовувала по одному з фронтів сигналу тактування, тому частота тактування вказувала на частоту її реакції, але з часом ми перейшли на пам'ять яка спрацьовувала по обох фронтах сигналу, тобто вдвічі частіше ніж частота тактування тому маркетологи вирішили цим скористатися бо так циферки більші.
drakulawz написав:
Якщо ви питає чи напише 3200 в CPU-Z то ні.
HetmanNet написав:
Дякую! Тепер все зрозуміло, а то вже злякався, що щось не так.
