Тема: Не можу скомпілювати гру на андроід.
Добрий день.
Я написав просту гру на юніті та не можу скомпілювати.
на комп*ютері стоїть віндовс 7 і юніті 19го року.
видає 4ри помилки:
Перша:
Task :launcher:preBuild UP-TO-DATE
> Task :unityLibrary:preBuild UP-TO-DATE
> Task :launcher:prepareLintJar UP-TO-DATE
> Task :unityLibrary:preReleaseBuild UP-TO-DATE
> Task :unityLibrary:checkReleaseManifest UP-TO-DATE
> Task :unityLibrary:processReleaseManifest
> Task :unityLibrary:compileReleaseAidl NO-SOURCE
> Task :unityLibrary:packageReleaseRenderscript NO-SOURCE
> Task :unityLibrary:compileReleaseRenderscript NO-SOURCE
> Task :unityLibrary:generateReleaseBuildConfig UP-TO-DATE
> Task :unityLibrary:generateReleaseResValues UP-TO-DATE
> Task :unityLibrary:generateReleaseResources UP-TO-DATE
> Task :launcher:preReleaseBuild
> Task :launcher:compileReleaseAidl NO-SOURCE
> Task :unityLibrary:packageReleaseResources UP-TO-DATE
> Task :launcher:compileReleaseRenderscript NO-SOURCE
> Task :launcher:checkReleaseManifest UP-TO-DATE
> Task :launcher:generateReleaseBuildConfig UP-TO-DATE
> Task :launcher:generateReleaseSources UP-TO-DATE
> Task :launcher:mainApkListPersistenceRelease UP-TO-DATE
> Task :unityLibrary:generateReleaseRFile UP-TO-DATE
> Task :unityLibrary:prepareLintJar UP-TO-DATE
> Task :unityLibrary:generateReleaseSources UP-TO-DATE
> Task :unityLibrary:javaPreCompileRelease UP-TO-DATE
> Task :launcher:generateReleaseResValues UP-TO-DATE
> Task :launcher:generateReleaseResources UP-TO-DATE
> Task :unityLibrary:compileReleaseJavaWithJavac UP-TO-DATE
> Task :unityLibrary:bundleLibCompileRelease UP-TO-DATE
> Task :unityLibrary:prepareLintJarForPublish UP-TO-DATE
> Task :unityLibrary:mergeReleaseShaders UP-TO-DATE
> Task :unityLibrary:compileReleaseShaders UP-TO-DATE
> Task :unityLibrary:generateReleaseAssets UP-TO-DATE
> Task :launcher:mergeReleaseResources UP-TO-DATE
> Task :launcher:javaPreCompileRelease UP-TO-DATE
> Task :launcher:createReleaseCompatibleScreenManifests UP-TO-DATE
> Task :unityLibrary:packageReleaseAssets
> Task :unityLibrary:bundleLibRuntimeRelease UP-TO-DATE
> Task :launcher:processReleaseManifest
> Task :unityLibrary:processReleaseJavaRes NO-SOURCE
> Task :unityLibrary:bundleLibResRelease UP-TO-DATE
> Task :unityLibrary:mergeReleaseJniLibFolders UP-TO-DATE
> Task :unityLibrary:transformNativeLibsWithMergeJniLibsForRelease UP-TO-DATE
> Task :unityLibrary:transformNativeLibsWithIntermediateJniLibsForRelease UP-TO-DATE
> Task :launcher:processReleaseResources
> Task :launcher:compileReleaseJavaWithJavac UP-TO-DATE
> Task :launcher:compileReleaseSources UP-TO-DATE
> Task :launcher:lintVitalRelease
> Task :launcher:mergeReleaseShaders UP-TO-DATE
> Task :launcher:compileReleaseShaders UP-TO-DATE
> Task :launcher:generateReleaseAssets UP-TO-DATE
> Task :launcher:mergeReleaseAssets
> Task :launcher:validateSigningRelease UP-TO-DATE
> Task :launcher:signingConfigWriterRelease UP-TO-DATE
> Task :launcher:checkReleaseDuplicateClasses UP-TO-DATE
> Task :launcher:transformClassesWithDexBuilderForRelease UP-TO-DATE
> Task :launcher:transformDexArchiveWithExternalLibsDexMergerForRelease UP-TO-DATE
> Task :launcher:transformDexArchiveWithDexMergerForRelease UP-TO-DATE
> Task :launcher:mergeReleaseJniLibFolders UP-TO-DATE
> Task :launcher:transformNativeLibsWithMergeJniLibsForRelease UP-TO-DATE
> Task :launcher:processReleaseJavaRes NO-SOURCE
> Task :launcher:transformResourcesWithMergeJavaResForRelease UP-TO-DATE
> Task :launcher:packageRelease FAILED
Deprecated Gradle features were used in this build, making it incompatible with Gradle 6.0.
Use '--warning-mode all' to show the individual deprecation warnings.
See https://docs.gradle.org/5.1.1/userguide/command_line_interface.html#sec:command_line_warnings
45 actionable tasks: 8 executed, 37 up-to-date
UnityEngine.GUIUtility:ProcessEvent (int,intptr)Друга:
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':launcher:packageRelease'.
> 1 exception was raised by workers:
java.lang.RuntimeException: java.lang.RuntimeException: com.android.ide.common.signing.KeytoolException: Failed to read key AndroidDebugKey from store "C:\Users\Laptop\.android\debug.keystore": Invalid keystore format
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output. Run with --scan to get full insights.
* Get more help at https://help.gradle.org
BUILD FAILED in 3s
Picked up JAVA_TOOL_OPTIONS: -Dfile.encoding=UTF-8
UnityEngine.GUIUtility:ProcessEvent (int,intptr)Третя:
CommandInvokationFailure: Gradle build failed.
C:/Program Files/Unity/Hub/Editor/2019.4.40f1/Editor/Data/PlaybackEngines/AndroidPlayer\OpenJDK\bin\java.exe -classpath "C:\Program Files\Unity\Hub\Editor\2019.4.40f1\Editor\Data\PlaybackEngines\AndroidPlayer\Tools\gradle\lib\gradle-launcher-5.1.1.jar" org.gradle.launcher.GradleMain "-Dorg.gradle.jvmargs=-Xmx4096m" "assembleRelease"
stderr[
* What went wrong:
* Try:
BUILD FAILED in 3s
stdout[
exit code: 1
UnityEditor.Android.Command.WaitForProgramToRun (UnityEditor.Utils.Program p, UnityEditor.Android.Command+WaitingForProcessToExit waitingForProcessToExit, System.String errorMsg) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.Android.Command.Run (System.Diagnostics.ProcessStartInfo psi, UnityEditor.Android.Command+WaitingForProcessToExit waitingForProcessToExit, System.String errorMsg) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.Android.Command.Run (System.String command, System.String args, System.String workingdir, UnityEditor.Android.Command+WaitingForProcessToExit waitingForProcessToExit, System.String errorMsg) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.Android.AndroidJavaTools.RunJava (System.String args, System.String workingdir, System.Action`1[T] progress, System.String error) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.Android.GradleWrapper.Run (UnityEditor.Android.AndroidJavaTools javaTools, System.String workingdir, System.String task, System.Action`1[T] progress) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
Rethrow as GradleInvokationException: Gradle build failed
UnityEditor.Android.PostProcessor.Tasks.BuildGradleProject.Execute (UnityEditor.Android.PostProcessor.PostProcessorContext context) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.Android.PostProcessor.PostProcessRunner.RunAllTasks (UnityEditor.Android.PostProcessor.PostProcessorContext context) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
Rethrow as BuildFailedException: Exception of type 'UnityEditor.Build.BuildFailedException' was thrown.
UnityEditor.Android.PostProcessor.CancelPostProcess.AbortBuild (System.String title, System.String message, System.Exception ex) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.Android.PostProcessAndroidPlayer.PostProcess (UnityEditor.BuildTarget target, System.String stagingAreaData, System.String stagingArea, System.String playerPackage, System.String installPath, System.String companyName, System.String productName, UnityEditor.BuildOptions options, UnityEditor.RuntimeClassRegistry usedClassRegistry, UnityEditor.Build.Reporting.BuildReport report) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.Android.AndroidBuildPostprocessor.PostProcess (UnityEditor.Modules.BuildPostProcessArgs args, UnityEditor.BuildProperties& outProperties) (at <dd2e71f8d45046b88d6d3169a8084aec>:0)
UnityEditor.PostprocessBuildPlayer.Postprocess (UnityEditor.BuildTargetGroup targetGroup, UnityEditor.BuildTarget target, System.String installPath, System.String companyName, System.String productName, System.Int32 width, System.Int32 height, UnityEditor.BuildOptions options, UnityEditor.RuntimeClassRegistry usedClassRegistry, UnityEditor.Build.Reporting.BuildReport report) (at <7105be432fb64891b07085914e6cd5c1>:0)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)Четверта:
Build completed with a result of 'Failed' in 27 seconds (26852 ms)
UnityEngine.GUIUtility:ProcessEvent (int,intptr)І останнє вікно:
UnityEditor.BuildPlayerWindow+BuildMethodException: 4 errors
at UnityEditor.BuildPlayerWindow+DefaultBuildMethods.BuildPlayer (UnityEditor.BuildPlayerOptions options) [0x002bf] in <7105be432fb64891b07085914e6cd5c1>:0
at UnityEditor.BuildPlayerWindow.CallBuildMethods (System.Boolean askForBuildLocation, UnityEditor.BuildOptions defaultBuildOptions) [0x00080] in <7105be432fb64891b07085914e6cd5c1>:0
UnityEngine.GUIUtility:ProcessEvent (int,intptr)Вже намагався:
Змінити змінну середи користувача на шлях до jdk.
Та не викорристовувати у шляху до проекту кирилицю.
Я так розумію що це щось з інструментами андроід, але не розумію що робити.
