import numpy as np
import random
from IPython.display import clear_output
from collections import deque
import progressbar
import time
import gym
from tensorflow.keras import Model, Sequential
from tensorflow.keras.layers import Dense, Embedding, Reshape
from tensorflow.keras.optimizers import Adam
enviroment = gym.make("Taxi-v3").env
enviroment.reset()
enviroment.render()
print('Number of states: {}'.format(enviroment.observation_space.n))
print('Number of actions: {}'.format(enviroment.action_space.n))
class Agent:
def __init__(self, enviroment, optimizer):
# Initialize atributes
self._state_size = enviroment.observation_space.n
self._action_size = enviroment.action_space.n
self._optimizer = optimizer
self.expirience_replay = deque(maxlen=2000)
# Initialize discount and exploration rate
self.gamma = 0.6
self.epsilon = 0.1
# Build networks
self.q_network = self._build_compile_model()
self.target_network = self._build_compile_model()
self.alighn_target_model()
def store(self, state, action, reward, next_state, terminated):
self.expirience_replay.append((state, action, reward, next_state, terminated))
def _build_compile_model(self):
model = Sequential()
model.add(Embedding(self._state_size, 10, input_length=1))
model.add(Reshape((10,)))
model.add(Dense(50, activation='relu'))
model.add(Dense(self._action_size, activation='linear'))
model.compile(loss='mse', optimizer=self._optimizer)
return model
def alighn_target_model(self):
self.target_network.set_weights(self.q_network.get_weights())
def act(self, state):
if np.random.rand() <= self.epsilon:
return enviroment.action_space.sample()
q_values = self.q_network.predict(state)
return np.argmax(q_values[0])
def retrain(self, batch_size):
minibatch = random.sample(self.expirience_replay, batch_size)
for state, action, reward, next_state, terminated in minibatch:
target = self.q_network.predict(state)
if terminated:
target[0][action] = reward
else:
t = self.target_network.predict(next_state)
target[0][action] = reward + self.gamma * np.amax(t)
self.q_network.fit(state, target, epochs=1, verbose=0)
self.gamma = 0.6
self.epsilon = 0.1
# Build networks
return model
if terminated:
else:
optimizer = Adam(learning_rate=0.01)
agent = Agent(enviroment, optimizer)
batch_size = 32
num_of_episodes = 100
timesteps_per_episode = 1000
agent.q_network.summary()
for e in range(0, num_of_episodes):
# Reset the enviroment
state = enviroment.reset()
state = np.reshape(state, [1, 1])
# Initialize variables
reward = 0
terminated = False
bar = progressbar.ProgressBar(maxval=timesteps_per_episode/10, widgets=\
[progressbar.Bar('=', '[', ']'), ' ', progressbar.Percentage()])
bar.start()
for timestep in range(timesteps_per_episode):
# Run Action
action = agent.act(state)
# Take action
next_state, reward, terminated, info = enviroment.step(action)
next_state = np.reshape(next_state, [1, 1])
agent.store(state, action, reward, next_state, terminated)
state = next_state
if terminated:
agent.alighn_target_model()
break
if len(agent.expirience_replay) > batch_size:
agent.retrain(batch_size)
if timestep%10 == 0:
bar.update(timestep/10 + 1)
bar.finish()
if (e + 1) % 10 == 0:
print("**********************************")
print("Episode: {}".format(e + 1))
enviroment.render()
agent.q_network.save("/content/drive/MyDrive/Colab Notebooks/Files/Save1/2")
