Тема: Помилка в налаштуваннях CMake
При спробі запуску проєкту Qt на Windows 11 видає таку помилку щодо CMake:
Configuring incomplete, errors occurred!
    Qt6Config.cmake
    qt6-config.cmake
    Qt5Config.cmake
    qt5-config.cmake
  Add the installation prefix of "QT" to CMAKE_PREFIX_PATH or set "QT_DIR" to
  a directory containing one of the above files.  If "QT" provides a separate
  development package or SDK, be sure it has been installed.На Manjaro все працювало добре. Як це виправити?
CMake файл:
cmake_minimum_required(VERSION 3.5)
project(Movar_cpp VERSION 1.0.2 LANGUAGES CXX)
set(CMAKE_AUTOUIC ON)
set(CMAKE_AUTOMOC ON)
set(CMAKE_AUTORCC ON)
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
find_package(QT NAMES Qt6 Qt5 REQUIRED COMPONENTS Widgets)
find_package(Qt${QT_VERSION_MAJOR}
    REQUIRED COMPONENTS Widgets LinguistTools WebEngineWidgets TextToSpeech)
set(TS_FILES
    i18n/Movar_cpp_uk_UA.ts
    i18n/Movar_cpp_en_US.ts
    i18n/Movar_cpp_ja_JP.ts
set(PROJECT_SOURCES
        main.cpp
        mainwindow.cpp
        mainwindow.h
        mainwindow.ui
        ${TS_FILES}
if(${QT_VERSION_MAJOR} GREATER_EQUAL 6)
    qt_add_executable(Movar_cpp
        MANUAL_FINALIZATION
        ${PROJECT_SOURCES}
# Define target properties for Android with Qt 6 as:
#    set_property(TARGET Movar_cpp APPEND PROPERTY QT_ANDROID_PACKAGE_SOURCE_DIR
#                 ${CMAKE_CURRENT_SOURCE_DIR}/android)
# For more information, see https://doc.qt.io/qt-6/qt-add-executable.html#target-creation
    #qt_create_translation(QM_FILES ${CMAKE_SOURCE_DIR} ${TS_FILES})
    qt_add_translations(QM_FILES ${CMAKE_SOURCE_DIR} ${TS_FILES})
else()
    if(ANDROID)
        add_library(Movar_cpp SHARED
            ${PROJECT_SOURCES}
# Define properties for Android with Qt 5 after find_package() calls as:
#    set(ANDROID_PACKAGE_SOURCE_DIR "${CMAKE_CURRENT_SOURCE_DIR}/android")
    else()
            ${PROJECT_SOURCES}
            dictionarysettings.h dictionarysettings.cpp dictionarysettings.ui
            fileloader.h fileloader.cpp
            app_resources.qrc
            adaptedcompleter.h adaptedcompleter.cpp
            adaptedstringlistmodel.h adaptedstringlistmodel.cpp
    endif()
    qt5_create_translation(QM_FILES ${CMAKE_SOURCE_DIR} ${TS_FILES})
endif()
add_custom_target(translations DEPENDS ${QM_FILES})
add_dependencies(${CMAKE_PROJECT_NAME} translations)
target_link_libraries(Movar_cpp PRIVATE
    Qt${QT_VERSION_MAJOR}::Widgets
    Qt${QT_VERSION_MAJOR}::WebEngineWidgets
    Qt${QT_VERSION_MAJOR}::TextToSpeech
# Qt for iOS sets MACOSX_BUNDLE_GUI_IDENTIFIER automatically since Qt 6.1.
# If you are developing for iOS or macOS you should consider setting an
# explicit, fixed bundle identifier manually though.
if(${QT_VERSION} VERSION_LESS 6.1.0)
  set(BUNDLE_ID_OPTION MACOSX_BUNDLE_GUI_IDENTIFIER com.example.Movar_cpp)
endif()
set_target_properties(Movar_cpp PROPERTIES
    ${BUNDLE_ID_OPTION}
    MACOSX_BUNDLE_BUNDLE_VERSION ${PROJECT_VERSION}
    MACOSX_BUNDLE_SHORT_VERSION_STRING ${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}
    MACOSX_BUNDLE TRUE
    WIN32_EXECUTABLE TRUE
include(GNUInstallDirs)
install(TARGETS Movar_cpp
    BUNDLE DESTINATION .
    LIBRARY DESTINATION ${CMAKE_INSTALL_LIBDIR}
    RUNTIME DESTINATION ${CMAKE_INSTALL_BINDIR}
if(QT_VERSION_MAJOR EQUAL 6)
    qt_finalize_executable(Movar_cpp)
endif()
