Re: Як не варто писати код. Поганий VS Хороший код.
Знайшов свій бидло-код річної давності.
// MYSQL Connect
function db_connect()
include_once($_SERVER['DOCUMENT_ROOT']."/engine/config/db.php");
@$link = mysql_connect(DBHOST,DBUSER,DBPASS);
if($link==false)
{  echo '<script>
document.location.href="/error.php?id=1";
</script>';exit; }
@$sd = mysql_select_db(DBNAME);
if($sd==false)
{  echo '<script>
document.location.href="/error.php?id=2";
</script>';exit; }
@mysql_query("SET NAMES cp1251");
//View static page
function view_page($page)
db_connect();
if(!eregi("^['a-zA-Z0-9']+['a-zA-Z0-9']+$",$page))
{  echo '<script>
document.location.href="/error.php?id=3";
</script>';exit; }
$sdp = mysql_query("SELECT title,keywords,description,text FROM page WHERE name='$page'");
if(mysql_num_rows($sdp)==0)
{ echo '<script>
</script>'; exit;}
$datapage = mysql_fetch_array($sdp);
include_once($_SERVER['DOCUMENT_ROOT']."/tpl/static.html");
//Registration user
function reg_user()
$login = $_POST['login'];
$pass = $_POST['password'];
$email = $_POST['email'];
if(!empty($login) and !empty($pass) and !empty($email))
if(!eregi("^[a-zA-Z0-9]+[a-zA-Z0-9]+$",$login))
{  echo '<script>document.location.href="/error.php?id=4";</script>'; exit;
if(!eregi("^[a-zA-Z0-9]+[a-zA-Z0-9]+$",$pass))
{  echo '<script>document.location.href="/error.php?id=5";</script>'; exit;
if(!eregi("^[a-zA-Z0-9_\-\.]+@[a-zA-Z0-9\-]+\.[a-zA-Z0-9\-\.]+$",$email))
{ echo '<script>document.location.href="/error.php?id=6";</script>'; exit;
//вставка в бд
$login = htmlspecialchars($login);
$pass = md5($pass);
db_connect();
$insertnewuser = mysql_query("INSERT INTO user(banned,reason,login,password,email) VALUE ('false','Порушення правил!','$login','$pass','$email')");
if($insertnewuser==FALSE)
{   echo '<script>
document.location.href="/error.php?id=7";
</script>'; exit;
{ echo '<script>
document.location.href="/auth.php";
</script>'; exit;
include($_SERVER['DOCUMENT_ROOT']."/tpl/register.html");
//Auth user
function auth_user()
if(!empty($login) and !empty($pass))
{  echo '<script>document.location.href="/error.php?id=4";</script>'; exit; }
{  echo '<script>document.location.href="/error.php?id=5";</script>'; exit; }
db_connect();
$pass = md5($pass);
$selectdatauser = mysql_query("SELECT id FROM user WHERE login='$login' and
password='$pass'");
if(mysql_num_rows($selectdatauser)==0)
{ echo '<script>document.location.href="/error.php?id=8";</script>'; exit; }
$_SESSION['valid_user'] = $login;
echo '<script>document.location.href="/account.php";</script>'; exit;
include($_SERVER['DOCUMENT_ROOT']."/tpl/auth.html");
function check_auth_user()
if(isset($_SESSION['valid_user']))
function data_user()
$login = $_SESSION['valid_user'];
db_connect();
$Selectdatauser = mysql_query("SELECT id,banned,reason,email FROM user WHERE login='$login'");
if(mysql_num_rows($Selectdatauser)==0)
{ echo '<script>document.location.href="/auth.php";</script>'; exit; }
$DataUser = mysql_fetch_array($Selectdatauser);
include($_SERVER['DOCUMENT_ROOT']."/tpl/account.html");
//List foto
function list_foto()
db_connect();
if(isset($_GET['page']) and !empty($_GET['page']) and eregi("^[0-9]+$",$_GET['page']))
$page = $_GET['page']*10;
$selectfoto = mysql_query("SELECT `id`,`name`,`link`,`desc`,`view` FROM foto WHERE p=1 ORDER BY `id` DESC LIMIT $page,10 ");
if(mysql_num_rows($selectfoto) == 0)
{ echo '<script>
document.location.href="/foto.php";
</script>';exit;
$df = mysql_fetch_array($selectfoto);
do
printf('
 <p> <br /><center><a href="/view_foto.php?id=%s" class="capsule">%s</a>
            <img src="/uploads/foto/%s" width="" height="" border="0"><br />
             %s<br />
             Переглядів: %s</center>
             </p>
',$df['id'],$df['name'],$df['link'],$df['desc'],$df['view']);
while($df = mysql_fetch_array($selectfoto));
$selectfoto = mysql_query("SELECT `id`,`name`,`link`,`desc`,`view` FROM foto WHERE p=1 ORDER BY `id` DESC LIMIT 0,10 ");
{ echo "Фотографій нема!"; return; }
do
printf('
             %s<br />
             </p>
$selectfoto = mysql_query("SELECT `id` FROM foto WHERE p=1 ");
$numrows = mysql_num_rows($selectfoto);
$numpage = $numrows / 10;
$numpage = $numpage + 1;
@$ex = explode(".",$numpage);
$p = $ex['0'];
if(!isset($ex['1']))
{ $p = $p-1; }
$b = 1;
echo " <h3>Перейти на сторінку: ";
for($i=0;$i<$p;$i++)
printf('<a href="/foto.php?page=%s"> %s </a>',$i,$b);
$b++;
} echo "</h3>"; }
//View foto
function view_foto()
if(isset($_GET['id']) and !empty($_GET['id']) and eregi("^[0-9]+$",$_GET['id']))
$id = $_GET['id'];
db_connect();
$selectfoto = mysql_query("SELECT `name`,`link`,`desc`,`view` FROM foto WHERE id='$id'");
if(mysql_num_rows($selectfoto)==0)
{ echo '<script>
</script>';exit; }
printf('<br />%s<br />
<img src="/uploads/foto/%s" width="250" height="250"><br />
%s<br />%s
',$df['name'],$df['link'],$df['desc'],$df['view']);
echo '<script>
</script>';exit;
//List news
function list_post()
db_connect();
$selectpost = mysql_query("SELECT `id`,`title`,`short_news`,`author` FROM post WHERE p=1 ORDER BY `id` DESC LIMIT $page,10 ");
if(mysql_num_rows($selectpost) == 0)
{ echo '<script>
document.location.href="/post.php";
</script>';exit;
$dp = mysql_fetch_array($selecpost);
do
printf('
<p> <br /><center><a href="/view_post.php?id=%s" class="capsule">%s</a>
            %s
              Автор: %s
             </center>
             </p>
',$dp['id'],$dp['title'],$dp['short_news'],$dp['author']);
while($dp = mysql_fetch_array($selecpost));
$selecpost = mysql_query("SELECT id,title,short_news,author FROM post WHERE p=1 ORDER BY id DESC  LIMIT 0,10");
if(mysql_num_rows($selecpost) == 0)
{ echo "Матеріалів нема!"; return; }
do
printf('
            %s<br /><br />
              Автор: %s
             </center>
             </p>
$selecpost = mysql_query("SELECT `id` FROM post WHERE p=1 ");
$numrows = mysql_num_rows($selecpost);
$p = $ex['0'];
{ $p = $p-1; }
$b = 1;
echo " <br /><h3>Перейти на сторінку: ";
printf('<a href="/post.php?page=%s">%s</a>',$i,$b);
$b++;
} echo "</h3>"; }
//View post
function view_post()
$id = $_GET['id'];
db_connect();
$selectpost = mysql_query("SELECT `title`,`full_news`,`author`,`tags` FROM post WHERE id='$id'");
if(mysql_num_rows($selectpost)==0)
{ echo '<script>
</script>';exit; }
$dp = mysql_fetch_array($selectpost);
printf('
%s<br />%s<br />%s<br />%s<br />
',$dp['title'],$dp['full_news'],$dp['author'],$dp['tags']);
echo '<script>
</script>';exit;
//List comments
function list_comments()
$id = $_GET['id'];
db_connect();
$selectcom = mysql_query("SELECT name,text FROM comments WHERE newsid='$id'");
if(mysql_num_rows($selectcom)==0)
{ echo "<br /><br />Коментарів немає!"; return; }
$dc = mysql_fetch_array($selectcom);
do
printf('
<br />Додав: %s<br />
%s<br />
',$dc['name'],$dc['text']);
while($dc = mysql_fetch_array($selectcom));
//Add comments
//function add_comments()
//if(isset($_POST['name']) and isset($_POST['text']) and !empty($_POST['name']) and !empty($_POST['text']))
//if(!eregi("^[a-zA-zа-яА-Я0-9]+$",$_POST['name']))
22
алгоритм редіректу - шикарний :D
pew pew :D
Блоґ
miroslav.chandler написав:
Я його й досі юзаю, коли header location не канає.
24
а коли header не канає?
pew pew :D
Блоґ
25
Переважно коли уже перед викликом Header уже були виведені дані. Таке рідко буває у нормальних сайтах і часто у поганих ))
Тому дехто і юзає script
26
ну всі хедери, треба відправляти до контенту, на то вони і хедери, тому шось в логіці не так)
pew pew :D
Блоґ
funivan написав:
Хреновий з мене кодер...
28
Це не зовсім php, але я вирішив виставити це тут. Найшов на одному російському форумі.
#include "stdlib.h"
#include "stdio.h"
#define odnazdy int ar[10][10] = {0};
#define v  int max = 0;
#define studenuyu int sum = 0;
#define zimnyuyu int str = 0;
#define poru for(int i = 0; i<10; i++)
#define ya {sum = 0;
#define iz for(int j = 0; j<10;j++)
#define lesu {ar[i][j] = rand()%10+1; sum += ar[i][j];}
#define vyshel if(sum > max)
#define byl  {max = sum;str = i;}
#define silnyi }printf("max sum: %d",str);
#define moroz return 0;
int main(int argc, char* argv[])
    odnazdy v studenuyu zimnyuyu poru
    ya iz lesu vyshel byl silnyi moroz
я думаю це дійсно приклад того як треба програмувати, тільки так, з душею!
29
Оригінально, але не шедевр. Шедевр - це програмка яка наприклад малює сама себе:
_                                      =   (
                                        255,
                                      lambda
                               V       ,B,c
                             :c   and Y(V*V+B,B,  c
                               -1)if(abs(V)<6)else
               (              2+c-4*abs(V)**-0.4)/i
                 )  ;v,      x=1500,1000;C=range(v*x
                  );import  struct;P=struct.pack;M,\
            j  ='<QIIHHHH',open('M.bmp','wb').write
for X in j('BM'+P(M,v*x*3+26,26,12,v,x,1,24))or C:
            i  ,Y=_;j(P('BBB',*(lambda T:(T*80+T**9
                  *i-950*T  **99,T*70-880*T**18+701*
                 T  **9     ,T*i**(1-T**45*2)))(sum(
               [              Y(0,(A%3/3.+X%v+(X/v+
                               A/3/3.-x/2)/1j)*2.5
                             /x   -2.7,i)**2 for  \
                               A       in C
                                      [:9]])
                                        /9)
