Документація до плагіну OllyScript, але я б радив використовувати якусь "людську" мову - Python чи Lua.
OllyScript plugin v0.92 by SHaG
1. About OllyScript
2. Status
2.1 What's new in v0.92?
3. Documentation
3.1 Language
3.1.1 Reserved variables
3.1.2 Commands
3.2 Labels
3.3 Comments
3.4 Menus
4. Integration with other plugins
5. Contact me
6. License and source code
7. Thanks!
1. About OllyScript
OllyScript is a plugin for OllyDbg, which is, in my opinion,
the best application-mode debugger out there. One of the best
features of this debugger is the plugin architecture which allows
users to extend its functionality. OllyScript is a plugin
meant to let you automate OllyDbg by writing scripts in an
assembly-like language. Many tasks involve a lot of repetitive
work just to get to some point in the debugged application. By
using my plugin you can write a script once and for all.
2. Status (10 July 2004)
v0.92
A big bug in script synchronization fixed (thanks loveboom!).
GN behaviour updated.
MOV can now write strings to memory.
v0.91
A bug related to pausing the application fixed, the GN command added, ASM returns $RESULT.
v0.9
OllyScript has now been downloaded more then 10000 times! That means more then 2Gb of raw
scripting power flowing down the optic cable veins of the Internet. Not bad if you ask me!
The development of the plugin has been a bit slow, I've got a job programming xray systems
which has taken a lot of time. Sorry about that.
2.1 What's new?
+ New commands: ASK, BPL, BPLCND, COB, COE, EVAL, EXEC/ENDE, GN, TICND, TOCND
+ Execution of code in the target process context
+ String concateration with ADD or EVAL
+ Input box
+ Logging breakpoints
+ Removal of EOB and EOE
+ Tracing with condition
+ Get name of address
# ASM now returns assembled length in $RESULT
# Fixed pause crash bug
# Fixed bug with JBE, hopefully it was the last of the Jxx bugs
# OllyScript now REQUIRES OllyDbg v1.10. No other versions are officially supported.
3. Documentation
Two example scripts (tElock098.osc and UPX.osc) are available with this release.
The scripts will when run immediately find the OEP packed executable.
3.1 Language
The scripting language of OllyScript is an assembly-like language.
In the document below, src and dest can be (unless stated otherwise):
 - Constant in the form of a hex number withot prefixes and suffixes (i.e. 00FF, not 0x00FF or 00FFh)
 - Variable previously declared by VAR
 - A 32-bit register (one of EAX, EBX, ECX, EDX, ESI, EDI, EBP, ESP, EIP). Non 32-bit registers are not supported at
   the moment, but you can use SHL/SHR and AND to get their values.
 - A memory reference in square brackets (i.e. [401000] points to the memory at address 401000,
    [ecx] points to the memory at address ecx).
 - A flag with an exclamation mark in front (one of !CF, !PF, !AF, !ZF, !SF, !DF, !OF)
 - Sometimes byte strings are required. those are scripted as #6A0000# (values between two #) and
    must have an even number of characters.
 - Some byte strings can contain the wildcard '?', for exampla #6A??00# or #6?0000#
$RESULT
Return value for some functions like FIND etc.
$RESULT_1 and $RESULT_2 are available for some commands.
$VERSION
Contains current version of OllyScript
Example
    cmp $VERSION, "0.8"
    ja version_above_08
3.1.2 Commands
#INC file
Includes a script file in another script file
Example:
    #inc "anotherscript.txt"
#LOG
Enables logging of executed commands.
The commands will appear in OllyDbg log window, and will be prefixed with -->
Example:
    #log
ADD dest, src
Adds src to dest and stores result in dest
Example:
    add x, 0F
    add eax, x
    add [401000], 5
    add y, " times" // If y was 1000 before this command then y is "1000 times" after it
AI
Executes "Animate into" in OllyDbg
Example:
    ai
AN addr
Analyze module which contains the address addr.
Example:
    an eip // Same as pressing CTRL-A
AND dest, src
ANDs src and dest and stores result in dest
Example:
    and x, 0F
    and eax, x
    and [401000], 5
ASK question
Displays an input box with the specified question and lets user enter a response.
Sets the reserved $RESULT variable (0 if cancel button was pressed).
Example:
    ask "Enter new EIP"
    cmp $RESULT, 0
    je cancel_pressed
    mov eip, $RESULT
ASM addr, command
Assemble a command at some address.
Returns bytes assembled in the reserved $RESULT variable
Example:
    asm eip, "mov eax, ecx"
AO
Executes "Animate over" in OllyDbg
Example:
    ao
BC addr
Clear unconditional breakpoint at addr.
Example:
    bc 401000
    bc x
    bc eip
BP addr
Set unconditional breakpoint at addr.
Example:
    bp 401000
    bp x
    bp eip
BPCND addr, cond
Set breakpoint on address addr with condition cond.
Example:
    bpcnd 401000, "ECX==1"
BPL addr, expr
Sets logging breakpoint at address addr that logs expression expr
Example:
    bpl 401000, "eax" // logs the value of eax everytime this line is passed
BPLCND addr, expr, cond
Sets logging breakpoint at address addr that logs expression expr if condition cond is true
Example:
    bplcnd 401000, "eax", "eax > 1" // logs the value of eax everytime this line is passed and eax > 1
BPMC
Clear memory breakpoint.
Example:
    bpmc
BPHWC addr
Delete hardware breakpoint at a specified address
Example:
    bphwc 401000
BPHWS addr, mode
Set hardware breakpoint. Mode can be "r" - read, "w" - write or "x" - execute.
Example:
    bphws 401000, "x"
BPRM addr, size
Set memory breakpoint on read. Size is size of memory in bytes.
Example:
    bprm 401000, FF
BPWM addr, size
Set memory breakpoint on write. Size is size of memory in bytes.
Example:
    bpwm 401000, FF
CMP dest, src
Compares dest to src. Works like it's ASM counterpart.
Example:
    cmp y, x
    cmp eip, 401000
CMT addr, text
Inserts a comment at the specified address
Example:
    cmt eip, "This is the entry point"
COB
Makes script continue execution after a breakpoint has occured (removes EOB)
Example:
    COB
COE
Makes script continue execution after an exception has occured (removes EOE)
Example:
    COE
DBH
Hides debugger
Example:
    dbh
DBS
Unhides debugger
Example:
    dbs
DEC var
Substracts 1 from variable
Example:
    dec v
DM addr, size, file
Dumps memory of specified size from specified address to specified file
Example:
    dm 401000, 1F, "c:\dump.bin"
DMA addr, size, file
Dumps memory of specified size from specified address to specified file appending to that file if it exists
Example:
    dma 401000, 1F, "c:\dump.bin"
DPE filename, ep
Dumps the executable to file with specified name.
Entry point is set to ep.
Example:
    dpe "c:\test.exe", eip
EOB label
Transfer execution to some label on next breakpoint.
Example:
    eob SOME_LABEL
EOE label
Transfer execution to some label on next exception.
Example:
    eob SOME_LABEL
ESTI
Executes SHIFT-F7 in OllyDbg.
Example:
    esti
ESTO
Executes SHIFT-F9 in OllyDbg.
Example:
    esto
EVAL
Evaluates a string expression that contains variables.
The variables that are declared in the current script can be enclosed in curly braces {} to be inserted.
Example:
    var x
    mov x, 1000
    eval "The value of x is {x}" // after this $RESULT is "The value of x is 00001000"
EXEC/ENDE
Executes instructions between EXEC and ENDE in the context of the target process.
Values in curly braces {} are replaced by their values.
Example:
// This does some movs
var x
var y
mov x, "eax"
mov y, "0DEADBEEF"
exec
mov {x}, {y} // mov eax, 0DEADBEEF will be executed
mov ecx, {x} // mov ecx, eax will be executed
ende
// This calls ExitProcess in the debugged application
exec
push 0
call ExitProcess
ende
ret
FILL addr, len, value
Fills len bytes of memory at addr with value
Example:
    fill 401000, 10, 90 // NOP 10h bytes
FIND addr, what
Searches memory starting at addr for the specified value.
When found sets the reserved $RESULT variable. $RESULT == 0 if nothing found.
The search string can also use the wildcard "??" (see below).
Example:
    find eip, #6A00E8# // find a PUSH 0 followed by some kind of call
    find eip, #6A??E8# // find a PUSH 0 followed by some kind of call
FINDOP addr, what
Searches code starting at addr for an instruction that begins with the specified bytes.
Example:
    findop 401000, #61# // find next POPAD
    findop 401000, #6A??# // find next PUSH of something
GN addr
Gets the symbolic name of specified address (ex the API it poits to)
Sets the reserved $RESULT variable to the name. If that name is an API
$RESULT_1 is set to the library (ex kernel32) and $RESULT_2 to the name of the API (ex ExitProcess).
Example:
    gn 401000
GPA proc, lib
Gets the address of the specified procedure in the specified library.
Useful for setting breakpoints on APIs.
Example:
    gpa "MessageBoxA", "user32.dll" // After this $RESULT is the address of MessageBoxA and you can do "bp $RESULT".
GO addr
Executes to specified address (like G in SoftIce)
Example:
    go 401005
GMI addr, info
Gets information about a module to which the specified address belongs.
"info" can be MODULEBASE, MODULESIZE, CODEBASE or CODESIZE (if you want other info in the future versions plz tell me).
Sets the reserved $RESULT variable (0 if data not found).
Example:
    GMI eip, CODEBASE // After this $RESULT is the address to the codebase of the module to which eip belongs
INC var
Adds 1 to variable
Example:
    inc v
JA label
Use this after cmp. Works like it's asm counterpart.
Example:
    ja SOME_LABEL
JAE label
Example:
    jae SOME_LABEL
JB label
Example:
    jb SOME_LABEL
JBE label
Example:
    jbe SOME_LABEL
JE label
Example:
    je SOME_LABEL
JMP label
Unconditionally jump to a label.
Example:
    jmp SOME_LABEL
JNE label
Example:
    jne SOME_LABEL
LBL addr, text
Inserts a label at the specified address
Example:
    lbl eip, "NiceJump"
LOG src
Logs src to OllyDbg log window.
If src is a constant string the string is logged as it is.
If src is a variable or register its logged with its name.
Example:
    log "Hello world" // The string "Hello world" is logged
    var x
    mov x, 10
    log x // The string "x = 00000010" is logged.
MOV dest, src
Move src to dest.
Src can be a long hex string in the format #<some hex numbers>#, for example #1234#.
Remember that the number of digits in the hex string must be even, i.e. 2, 4, 6, 8 etc.
Example:
    mov x, 0F
    mov y, "Hello world"
    mov eax, ecx
    mov [ecx], #00DEAD00BEEF00#
    mov !CF, 1
    mov !DF, !PF
    mov [403000], "Hello world"
MSG message
Display a message box with specified message
Example:
    MSG "Script paused"
MSGYN message
Display a message box with specified message and YES and NO buttons.
Sets the reserved $RESULT variable to 1 if YES is selected and 0 otherwise.
Example:
    MSGYN "Continue?"
OR dest, src
ORs src and dest and stores result in dest
Example:
    or x, 0F
    or eax, x
    or [401000], 5
PAUSE
Pauses script execution. Script can be resumed from plugin menu.
Example:
    pause
REPL addr, find, repl, len
Replace find with repl starting att addr for len bytes.
Wildcards are allowed
Example:
    repl eip, #6a00#, #6b00#, 10
    repl eip, #??00#, #??01#, 10
    repl 401000, #41#, #90#, 1F
RET
Exits script.
Example:
    ret
RTR
Executes "Run to return" in OllyDbg
Example:
    rtr
RTU
Executes "Run to user code" in OllyDbg
Example:
    rtu
RUN
Executes F9 in OllyDbg
Example:
    run
SHL dest, src
Shifts dest to the left src times and stores the result in dest.
Example:
    mov x, 00000010
    shl x, 8 // x is now 00001000
SHR dest, src
Shifts dest to the right src times and stores the result in dest.
Example:
    mov x, 00001000
    shr x, 8 // x is now 00000010
STI
Execute F7 in OllyDbg.
Example:
    sti
STO
Execute F8 in OllyDbg.
Example:
    sto
SUB dest, src
Substracts src from dest and stores result in dest
Example:
    sub x, 0F
    sub eax, x
    sub [401000], 5
TI
Executes "Trace into" in OllyDbg
Example:
    ti
TICND cond
Traces into calls until cond is true
Example:
    ticnd "eip > 40100A" // will stop when eip > 40100A
TO
Executes "Trace over" in OllyDbg
Example:
    to
TOCND cond
Traces over calls until cond is true
Example:
    tocnd "eip > 40100A" // will stop when eip > 40100A
VAR
Declare a variable to be used in the script.
Must be done before the variable is used.
Example:
    var x
XOR dest, src
XORs src and dest and stores result in dest
Example:
    xor x, 0F
    xor eax, x
    xor [401000], 5
3.2 Labels
Labels are defined bu using the label name followed by a colon.
Example:
    SOME_LABEL:
3.3 Comments
Comments can be put anywhere and have to start with "//". Block
comments must start with "/*" on a new line and and with "*/"
also on a new line.
3.4 Menus
The main OllyScript menu consists of the following items:
- Run script...: lets the user select a script file and starts it
- Abort: aborts a running script
- Pause: pauses a running script
- Resume: resumes a paused script
- About: shows information about this plugin
You can call OllyScript from your plugin and make it execute a script.
Use something like the source code below:
HMODULE hMod = GetModuleHandle("OllyScript.dll");
if(hMod) // Check that the other plugin is present and loaded
    // Get address of exported function
    int (*pFunc)(char*) = (int (*)(char*)) GetProcAddress(hMod, "ExecuteScript");
    if(pFunc) // Check that the other plugin exports the correct function
        pFunc("myscript.txt"); // Execute exported function
5. Contact me
To contact me you can post your question in the forum or go on IRC
and message SHaG on EFnet. You can also mail me to shag-at-apsvans-dot-com.
Soon I'm going to armadildo this plugin and charge an awful lot of money
for it! :P Seriously, you are free to use this plugin and the source code however
you see fit. However please name me in your documentation/about box and if
the project you need my code for is on a larger scale please also notify
me - I am curious.
Source code for this plugin is available on request only. Please send me
a mail if you need it!
7. Thanks!
I'd like to thank all the wonderful people who reported bugs, wrote scripts, came
with improvement ideas etc.
R@dier for the great dumping engine.
And of course Olly for developing this great debugger!
