1 Востаннє редагувалося fatalerror2011 (24.04.2015 16:52:39)
Тема: C# допоможіть скомпілювати код
Має вийти граф.
http://s019.домен агресора/i617/1504/ … 813692.png
using System;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.Windows.Forms;
namespace WindowsFormsApplication1 {
    public class Form1 : Form {
        [STAThread]
        static void Main() {
            Application.EnableVisualStyles();
            Application.SetCompatibleTextRenderingDefault(false);
            Application.Run(new Form1());
        private const int NodeRadius = 5;
        private static readonly Pen ArrowPen = new Pen(Color.Black, 2) {
            StartCap = LineCap.Round,
            EndCap = LineCap.ArrowAnchor,
            CustomEndCap = new AdjustableArrowCap(7, 7)
        private readonly List<Node> _nodes = new List<Node>();
        private Node _currentNode;
        protected override void OnPaint(PaintEventArgs e) {
            e.Graphics.SmoothingMode = SmoothingMode.HighQuality;
            foreach (var node in _nodes) {
                e.Graphics.FillEllipse(node == _currentNode ? Brushes.Red : Brushes.Black, new Rectangle(node.Position.X - NodeRadius, node.Position.Y - NodeRadius, NodeRadius * 2, NodeRadius * 2));
                foreach (var next in node.Dependencies) {
                    e.Graphics.DrawLine(ArrowPen, node.Position, next.Position);
            base.OnPaint(e);
        public Node GetNode(Point point) {
                if (Math.Abs(node.Position.X - point.X) < NodeRadius && Math.Abs(node.Position.Y - point.Y) < NodeRadius)
                    return node;
            return null;
        protected override void OnMouseClick(MouseEventArgs e) {
            if (e.Button == MouseButtons.Left && _currentNode == null) {
                _nodes.Add(new Node() { Position = e.Location });
                Invalidate();
            base.OnMouseClick(e);
        protected override void OnMouseDown(MouseEventArgs e) {
            var currentNode = GetNode(e.Location);
            if (e.Button == MouseButtons.Right && _currentNode != null && currentNode != null && !_currentNode.Dependencies.Contains(currentNode)) {
                _currentNode.Dependencies.Add(currentNode);
                Invalidate();
            } else if (e.Button == MouseButtons.Left) {
                _currentNode = currentNode;
                Invalidate();
            base.OnMouseDown(e);
        protected override void OnMouseMove(MouseEventArgs e) {
            if (e.Button == MouseButtons.Left && _currentNode != null) {
                _currentNode.Position = e.Location;
                Invalidate();
            base.OnMouseMove(e);
    public class Node {
        private readonly List<Node> _dependencies = new List<Node>();
        public List<Node> Dependencies { get { return _dependencies; } }
        public Point Position { get; set; }
Помилка 1
Ошибка    1    Для программы "C:\Users\jeka\AppData\Local\Temporary Projects\WindowsFormsApplication1\obj\x86\Debug\WindowsFormsApplication1.exe" определено несколько точек входа: "WindowsFormsApplication1.Form1.Main()". Компиляция с /main позволит указать тип, содержащий точку входа.    C:\Users\jeka\AppData\Local\Temporary Projects\WindowsFormsApplication1\Form1.cs    12    21    WindowsFormsApplication1
Помилка 2
Ошибка    2    Для программы "C:\Users\jeka\AppData\Local\Temporary Projects\WindowsFormsApplication1\obj\x86\Debug\WindowsFormsApplication1.exe" определено несколько точек входа: "WindowsFormsApplication1.Program.Main()". Компиляция с /main позволит указать тип, содержащий точку входа.    C:\Users\jeka\AppData\Local\Temporary Projects\WindowsFormsApplication1\Program.cs    14    21    WindowsFormsApplication1
Re: C# допоможіть скомпілювати код
А хто вам сказав, що у формі має бути метод Main?
3 Востаннє редагувалося fatalerror2011 (21.04.2015 20:24:53)
Ну а як без нього. Виправте мене, тому що боюсь до завтра не встигну
Ви створили, як не помиляюся, проект з формою. А в ньому метод Main вже є деінде, якщо хочете щось зробити при створенні форми - дописуйте в OnCreate.
Знову помилка(
Ошибка    1    Нет перегруженного метода для "OnPaint", который соответствует делегату "System.Windows.Forms.PaintEventHandler"    C:\Users\jeka\AppData\Local\Temporary Projects\WindowsFormsApplication1\Form1.Designer.cs    40    27    WindowsFormsApplication1
Теж саме з "OnMouseDown", "OnMouseMove", "OnMouseClick"
Панове, хтось все ж наважиться допомогти ?
залий цілий проект кудись, я гляну.
truesupport написав:
Завантажив
У PaintEventHandler два параметри, а у вашого OnPaint - один.
Файл називається Form1.Designer.cs там треба видалити або закоментити рядки 40 - 43 включно і воно запуститься. Як воно працює і чи працює взагалі я не перевіряв.
Подякували: koala, leofun012
Дякую, все запрацювало !!!
fatalerror2011 написав:
        [STAThread]
Program.cs - це не файл для того, щоб скопіювати кудись метод main
