Тема: Tcp підключення.
От є сервер :
using System;
using System.Linq;
using System.Text;
using System.Net.Sockets;
using System.Net;
namespace win
class Program
TcpListener server=null;
try
// Set the TcpListener on port 13000.
Int32 port = 13000;
IPAddress localAddr = IPAddress.Parse("127.0.0.1");
// TcpListener server = new TcpListener(port);
server = new TcpListener(localAddr, port);
// Start listening for client requests.
server.Start();
// Buffer for reading data
Byte[] bytes = new Byte[256];
String data = null;
// Enter the listening loop.
while(true)
String[] ids = new String[100];
// Perform a blocking call to accept requests.
// You could also user server.AcceptSocket() here.
TcpClient client = server.AcceptTcpClient();
data = null;
// Get a stream object for reading and writing
NetworkStream stream = client.GetStream();
int i;
// Loop to receive all the data sent by the client.
while((i = stream.Read(bytes, 0, bytes.Length))!=0)
// Translate data bytes to a ASCII string.
data = System.Text.Encoding.ASCII.GetString(bytes, 0, i);
// Process the data sent by the client.
data = data.ToUpper();
byte[] msg = System.Text.Encoding.ASCII.GetBytes(data);
// Send back a response.
stream.Write(msg, 0, msg.Length);
Console.WriteLine("Sent: {0}", data);
// Shutdown and end connection
client.Close();
catch(SocketException e)
Console.WriteLine("SocketException: {0}", e);
finally
// Stop listening for new clients.
server.Stop();
Console.WriteLine("\nHit enter to continue...");
Console.Read();
}і клієнт:
public static string ip;
ip = Console.ReadLine();
while(true){
string pars = Console.ReadLine();
Connect(ip, pars);
static void Connect(String server, String message)
try
// Create a TcpClient.
// Note, for this client to work you need to have a TcpServer
// connected to the same address as specified by the server, port
// combination.
Int32 port = 13000;
TcpClient client = new TcpClient(server, port);
// Translate the passed message into ASCII and store it as a Byte array.
Byte[] data = System.Text.Encoding.ASCII.GetBytes(message);
// Get a client stream for reading and writing.
// Stream stream = client.GetStream();
// Send the message to the connected TcpServer.
stream.Write(data, 0, data.Length);
// Receive the TcpServer.response.
// Buffer to store the response bytes.
data = new Byte[256];
// String to store the response ASCII representation.
String responseData = String.Empty;
// Read the first batch of the TcpServer response bytes.
Int32 bytes = stream.Read(data, 0, data.Length);
responseData = System.Text.Encoding.ASCII.GetString(data, 0, bytes);
// Close everything.
stream.Close();
client.Close();
catch (ArgumentNullException e)
Console.WriteLine("ArgumentNullException: {0}", e);
catch (SocketException e)
}Клієнт посилає серверу переменую.
Як послати відповідь всім клієнтам ?
