Тема: UDP сервер
Є сервер
using System;
using System.Linq;
using System.Text;
using System.Net.Sockets;
using System.Net;
namespace Server
    class Program
        public static string[] ip = null;
        public static int i = 0;
            StartListener();
        private const int listenPort = 11000;
        private static void StartListener()
            bool done = false;
            UdpClient listener = new UdpClient(listenPort);
            IPEndPoint groupEP = new IPEndPoint(IPAddress.Any, listenPort);
            try
                while (!done)
                    byte[] bytes = listener.Receive(ref groupEP);
                    if (Encoding.ASCII.GetString(bytes, 0, bytes.Length) == "Connect")
                        ip[i] = groupEP.ToString();
                        i++;
            catch (Exception e)
                Console.WriteLine(e.ToString());
            finally
                listener.Close();
}Клієнт
using System;
using System.Linq;
using System.Text;
using System.Net;
namespace Client
    class Program
            Socket s = new Socket(AddressFamily.InterNetwork, SocketType.Dgram,
            ProtocolType.Udp);
            IPAddress broadcast = IPAddress.Parse("127.0.0.1");
            byte[] sendbuf = Encoding.ASCII.GetBytes("Connect");
            IPEndPoint ep = new IPEndPoint(broadcast, 11000);
            s.SendTo(sendbuf, ep);
            Console.WriteLine("Message sent to the broadcast address");
}Чому якщо запускаю клиент сервер закриваєтся?
Ошибок нет.
Якщо видалити
ip[i] = groupEP.ToString();  i++;то не закриваєтся
