PROGRAM TETRIS;
USES
CRT, GRAPH;
TYPE
MAS = ARRAY[1 .. 20, 1 .. 10] OF BOOLEAN;
VAR
x,y,h,gd,gm : integer;
MovingF : MAS;
a : char;
ExitProgram : Boolean;
PROCEDURE MoveLeft(var MovingF : mas);
VAR
i,j: integer;
BEGIN
FOR i := 1 TO 20 DO BEGIN
FOR j := 1 TO 9 DO
MovingF[i,j] := MovingF[i,j+1];
MovingF[i,10] := FALSE;
END;
END;
PROCEDURE MoveRight(MovingF : MAS);
VAR
i,j : integer;
BEGIN
FOR i := 1 To 20 DO BEGIN
FOR j := 9 DOWNTO 1 DO
END;
END;
PROCEDURE MoweDown;
BEGIN
END;
PROCEDURE RotateF;
BEGIN
END;
PROCEDURE CreateF;
BEGIN
END;
PROCEDURE DrawFrame(x,y,h : INTEGER);
BEGIN
SetColor(15);
Rectangle(x,y,x + 10 * h,y + 20 * h);
END;
PROCEDURE DrawRectangle(var x,y,h,i,j : integer; ClearF : boolean);
BEGIN
IF ClearF = TRUE THEN
SetColor(0)
ELSE
SetColor(2);
Rectangle(x + (j - 1) * h,y + (i - 1) * h,x + j * h,y + i * h);
END;
PROCEDURE DrawMovingF(x,y,h: integer; ClearF: boolean);
var
i,j: integer;
BEGIN
FOR i := 1 TO 20 DO
FOR j := 1 TO 10 DO
IF MovingF[i,j] = TRUE THEN
DrawRectangle(x,y,h,i,j,ClearF);
END;
PROCEDURE ProcessPressedKey(a: CHAR; x,y,h: Integer);
BEGIN
CASE a OF
#80:
BEGIN
END;
#75:
BEGIN
DrawMovingF(x,y,h,TRUE);
MoveLeft(MovingF);
DrawMovingF(x,y,h,FALSE);
END;
#77:
BEGIN
MoveRight(MovingF);
END;
#72:
BEGIN
END;
END;
END;
BEGIN
x := 200;
y := 0;
h := 24;
Gd := Detect;
InitGraph(Gd,Gm,'c:\bp\bgi');
DrawFrame(x,y,h);
MovingF[2,6] := true;
MovingF[2,5] := true;
DrawFrame(x,y,h);
WHILE NOT ExitProgram = TRUE DO BEGIN
a := ReadKey;
IF a = #27 THEN
ExitProgram := TRUE
ELSE
ProcessPressedKey(a,x,y,h);
END;
END.
