Тема: [php] Клас для роботи з ICQ
Доброго дня шановні юзери
Написав клас для роботи з ICQ, в прикладі він представлений як спамер або флудер не лайте за це, це тільки ПРИКЛАД
і переробити під свої потреби не важко.
// ICQ (ПРИКЛАД!!!)
// coder: Russell S.
// version: 1.0
//---------------------------------[php]CLASS-----------------------------------
set_time_limit(0);
class CicqFlood {
function connect($_uin, $_pass)
$this->sock = fsockopen("login.icq.com",5190);
if($this->sock){ echo("O_O"); }
$this->PackBody = $this->ReadPack();
$this->Sequence = rand(1, 30000);
$hash_pass = "";
$arr_roast = array(0xF3,0x26,0x81,0xC4,0x39,0x86,0xDB,0x92,0x71,0xA3,0xB9,0xE6,0x53,0x7A,0x95,0x7C);
for($i=0; $i < strlen($_pass); $hash_pass .= chr($arr_roast[$i]^ord($_pass[$i++])));
$this->PackBody .= pack("nna*",1,strlen($_uin),$_uin);
$this->PackBody .= pack("nna*",2,strlen($hash_pass),$hash_pass);
$this->PackBody .= pack("nna*",3,strlen("Ukraine"),"UAC0D3");
$this->PackBody .= pack("nnn",22,2,266);
$this->PackBody .= pack("nnn",23,2,20);
$this->PackBody .= pack("nnn",24,2,34);
$this->PackBody .= pack("nnn",25,2,0);
$this->PackBody .= pack("nnn",26,2,2321);
$this->PackBody .= pack("nnN",20,4,1085);
$this->PackBody .= pack("nna*",15,strlen('ru'),'ru');
$this->PackBody .= pack("nna*",14,strlen('ru'),'ru');
$this->Flap['chanel2'] = 1;
fwrite($this->sock,$this->GetFlap()); // Send packet to server
$this->info = array();
echo("<br />Cookie:".$this->PackBody."<br />");
while($this->PackBody != '')
$pars = unpack('n2',substr($this->PackBody, 0, 4));
$this->TLV_id = $pars[1];
$this->Size = $pars[2];
$this->info['Data'] = substr($this->PackBody, 4, $this->Size);
switch($this->TLV_id)
case 6: $this->info['cookie'] = $this->info['Data'];
case 5: $this->info['adres'] = $this->info['Data'];
$this->PackBody = substr($this->PackBody,($this->Size+4));
$this->icqBye();
if(isset($this->info['adres']))
$addr = explode(':',$this->info['adres']);
$this->sock = fsockopen($addr[0],$addr[1]);
$this->PackBody .= pack('nna*',6, strlen($this->info['cookie']), $this->info['cookie']); // Pack: Hello + Cookie
fwrite($this->sock, $this->GetFlap());
$this->Request_id++;
$this->PackBody = pack('nnnN',1,2,0,$this->Request_id);
$this->PackBody .= pack('n*',1,3,272,650);
$this->PackBody .= pack('n*',2,1,272,650);
$this->PackBody .= pack('n*',3,1,272,650);
$this->PackBody .= pack('n*',21,1,272,650);
$this->PackBody .= pack('n*',4,1,272,650);
$this->PackBody .= pack('n*',6,1,272,650);
$this->PackBody .= pack('n*',9,1,272,650);
$this->PackBody .= pack('n*',10,1,272,650);
return true;
function SendMsg($uin, $message)
$cookie = microtime();
$this->Flap['chanel2'] = 2;
$DeForCapa = pack('H*','094613494C7F11D18222444553540000');
$TLV_Data = pack('nd',0,$cookie).$DeForCapa;
$TLV_Data .=pack('nnn',10,2,1);
$TLV_Data .=pack('nn', 15, 0);
$TLV_Data .=pack('nnvvddnVn',10001,strlen($message)+62,27,8,0,0,0,3,$this->Request_id);
$TLV_Data .=pack('nndnn',14,$this->Request_id,0,0,0);
$TLV_Data .=pack('ncvnva*',1,0,0,1,(strlen($message)+1),$message);
$TLV_Data .=pack('H*', '0000000000FFFFFF00');
$this->PackBody = pack('nnnNdnca*',4,6,0,$this->Request_id,$cookie,2,strlen($uin),$uin);
$this->PackBody .= pack('nna*',5,strlen($TLV_Data), $TLV_Data);
$this->PackBody .= pack('nna*',3,0,'');
function SendSSI($uin, $reason)
$this->PackBody = pack('nnnN',19,20,0,$this->Request_id);
$this->PackBody .= pack('ca*',strlen($uin),$uin);
$this->PackBody .= pack('n*',0,0,0);
$this->PackBody = pack('nnnN',19,24,0,$this->Request_id);
$this->PackBody .= pack('na*',strlen($reason),$reason);
$this->PackBody .= pack('n',0);
function SendSSIxReply($uin, $reason, $flag = false)
$this->PackBody = pack('nnnN',19,26,0,$this->Request_id);
$this->PackBody .= pack('cna*',$flag,strlen($reason),$reason);
function icqPing()
$this->Flap['chanel2'] = 5;
function icqBye()
$this->PackBody = 0x0000;
$this->Flap['chanel2'] = 4;
fwrite($this->sock,$this->getFlap());
fclose($this->sock);
$this->sock = 0;
private function ReadPack()
$this->Flap = fread($this->sock, 6);
if ($this->Flap) {
$this->Flap = unpack('c2chanel/n2size',$this->Flap);
$this->Flap['header'] = fread($this->sock,$this->Flap['size2']);
return $this->Flap['header'];
private function GetFlap()
$this->Sequence++;
$req = pack('ccnn', 0x2A, $this->Flap['chanel2'],$this->Sequence, strlen($this->PackBody)).$this->PackBody;
return $req;
function isConnected()
if($this->sock){ return true; } else { return false; }
function icqLoop($uin,$_msg)
for($i=0;$i<=30;$i++)
$this->SendMsg($uin,$_msg);
sleep(1);
$this->SendSSIxReply($uin,"SSSSSSSSSSS",0);
sleep(1);
$this->SendSSI($uin,"SendSSI; vas dobavili");
sleep(1);
$this->SendSSIxReply($uin,"aaaaaaaaaa",1);
sleep(1);
$this->icqPing();
$this->icqBye();
$cicq = new CicqFlood();
if($cicq->connect("362555877","GUPLTWCC"))
$cicq->icqLoop("458172","hi");
?>Як ним користуватися:
Ця функція конектиться до ICQ сервера - connect(UIN, PASSWORD)
Ця функція надсилає повідомлення до UIN - SendMsg(UIN, MESSAGE)
Ця функція надсилає запит на авторизацію - SendSSIxReply(UIN, MESSAGE)
Потрібно обов'язково протягом усього циклу життя класу пінгувати сервер щоб він не від'єднав нас - icqPing()
Завершення сеансу - icqBye()
