1 Востаннє редагувалося pika1989 (24.10.2015 22:54:34)
Тема: Програма виконується в GCC і вилітає у Visual Studio
Завдання: Дано вираз без дужок, у якому зустрічаються операції +, -,* та /. Обчислити значення виразу. Наприклад, для виразу 11 * 2  +  5 * 3 повинні отримати 37. Використати бібліотечні функції на вибір atoi() , atof(),strpbrk(), strcspn() strtod() strtol().
Реалізувала так:
#include <cstring>
#include <cstdlib> // this include is not needed for Visual Studio
/** Gets input from keyboard
 *  @return - char *expr
char *input_expression()
    cout << "Enter expression: ";
    char *expr = new char;
    cin.getline(expr, 256);
    return expr;
/** Deletes element from array
 * @param arr - array of any type
 * @param size - size of array arr
 * @param pos - index of element to delete
template <class T>
void delete_element(T *arr, int &size, int pos)
    for (int i = pos; i < size; i++)
        arr[i]=arr[i+1];
    --size;
/** Gets intermediate result and makes appropriate changes in expression
 * which represented by array of numbers and array of operations.
 * Example: 4 + 2 * 3  => numbers=(4, 2, 3), operations=(+, *)
 * After applaying mid result: numbers=(4, 6), operations=(+,)
 * @param operations - array of operations in expression
 * @param numbers - array of numbers in expression
 * @param op_counter - size of array operations
 * @param num_counter - size of array num_counter
 * @param i - index of changed elements
 * @param mid_result - result of calculation of current operation
void apply_mid_result(char *operations, double *numbers,
                        int op_counter, int num_counter,
                        int i, double mid_result)
    delete_element(operations, op_counter, i);
    delete_element(numbers, num_counter, i);
    numbers[i] = mid_result;
/** Parses given expression as string to arrays of numbers and operations.
 * Calculates according to priority of operations, returns result of calculation.
 * NOTE: can calculate expressions without brackets and with standard
 * arithmetic operations - addition, subtraction, multiplication, division.
 * @param expr - arithmetic expression, stored in array of char,
 * @return double result
double calculate(char *expr)
    // get all operations
    char operations[127];
    int op_counter = 0;
    char oper_signs[] = "*/+-";
    char *pch = expr;
    pch = strpbrk(pch, oper_signs);
    while (pch != NULL)
      operations[op_counter] = *pch;
      pch = strpbrk(pch+1, oper_signs);
      ++op_counter;
    cout << "\n";
    // get all numbers
    double numbers[128];
    int num_counter = 0;
    double number;
    pch = expr;
    while (*pch != '\0')
       number = strtod(pch, &pch);
       numbers[num_counter] = number;
       ++num_counter;
       pch += strcspn(pch, oper_signs) + 1;
    // make calculation
    double result = 0, mid_result;
    int i = 0;
    // first - high priority operations
    while (i < op_counter)
        if (operations[i] == '*')
            mid_result = numbers[i] * numbers[i+1];
            apply_mid_result(operations, numbers, op_counter, num_counter, i, mid_result);
        else if (operations[i] == '/')
            mid_result = numbers[i] / numbers[i+1];
        else ++i;
    // last - low priority operations
    i = 0;
        if (operations[i] == '+')
            mid_result = numbers[i] + numbers[i+1];
        else if (operations[i] == '-')
            mid_result = numbers[i] - numbers[i+1];
        else ++i;
    return mid_result;
    char *expr = input_expression();
    cout << "\nExpression: " << expr;
    double result = calculate(expr);
    cout << "Result: " << result;
GCC(g++) скомпілював і все працює, але при спробі перенести цей код у Visual Studio програма вилітає на етапі виведення результату. В режимі відлагодження все порахувало нормально, вивело результат - нічого поганого не помітила.
В чому може бути проблема?
P.S. Чи можна покращити код?
Re: Програма виконується в GCC і вилітає у Visual Studio
Перевірте чи консольну ви програму створюєте в VS (в командному рядку для компілера мусить бути аргумент /SUBSYSTEM:CONSOLE)
3 Востаннє редагувалося koala (25.10.2015 02:12:30)
Виділяєте 1 символ і записуєте туди 256...
В цілому ж:
1. Програма ніби на C++, але з рядками і масивами працює, ніби це голий C. std::vector і std::string сильно полегшують життя. Так, дурнувата умова, але це виглядає як їздити на мотоциклі, відштовхуючись ногами від землі.
2. Немає унарних операцій; -1*-1 - цілком відповідає умові і має сенс, але викличе збій програми.
3. Немає перевірки на коректність коду.
В цілому я б радив скористатися або рекурсією, або ПОЛІЗом для кращого узагальнення роботи програми.
Так, програма консольна
В цілому ж:
0. Додала квадратні дужки до new char - не допомогло.
1. Таке завдання - не я придумала, мені лише потрібно придумати як її реалізувати.
2. Над цим попрацюю - вилетіло геть з голови :[
3. Що саме перевірити? Вхідний рядок?
4. Що таке ПОЛІЗ? Ми, скоріш за все, його ще не вивчали.
0. так додавали? Я не телепат же.
char *expr = new char[256];
3. Так, очевидно.
4. https://uk.wikipedia.org/wiki/Польський_інверсний_запис - краще не чекайте, коли будете вивчати, а вивчайте одразу :)
Подякували: pika1989, leofun012
Ось виправила щодо від'ємних чисел:
#include <cstring>
#include <cstdlib>
    return expr;
template <class T>
        arr[i]=arr[i+1];
    --size;
 * @param numbers - array of double, used as storage of all operands
 * @param num_counter - size of array numbers
 * @param operations - array of char, used as storage of all operations
void parse_expression(char *expr, double *numbers, int &num_counter,
                                  char *operations, int &op_counter)
    double number;
    char *pch = expr;
    while (pch != NULL)
       ++num_counter;
       if (pch != NULL)
           ++op_counter;
           ++pch;
/** Calculates according to priority of operations, returns result of calculation.
    int op_counter = 0;
    parse_expression(expr, numbers, num_counter, operations, op_counter);
    int i = 0;
        else ++i;
    i = 0;
        else ++i;
    return mid_result;
    cout << "\nResult: " << result << "\n";
1. Підкажіть, будь ласка, як правильно виконати перевірку на коректність.
2. Як можна покращити код у функції calculate?
