Тема: [HDD] [SMART] Оцінка стану жорстких дисків.
Є два майже мертвих жорстких дисків. Розмірковую над тим чи можливо якийсь з них використати для зберігання різного непотребу, ну втрата якого не є страшною. Що скажете? Чи обидва в смітник та не страждати фігнею?
P.S. Обидва диска до того як все знищив на них через shred не проходили smart short.
P.P.S. Той що на 640 ГБ до shred читався і писався більш менш, а той що на 500 ГБ більш впертий.
smartctl 6.4 2015-06-04 r4109 [x86_64-linux-4.4.9-300.fc23.x86_64] (local build)
Copyright (C) 2002-15, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 2 minutes for test to complete.
Test will complete after Fri May 20 09:01:43 2016
Use smartctl -X to abort test.
[root@localhost HetmanNet]# smartctl -a /dev/sda
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Scorpio Blue Serial ATA (AF)
Device Model:     WDC WD6400BPVT-55HXZT2
Serial Number:    WD-WXG1A31F7794
LU WWN Device Id: 5 0014ee 6abdbb299
Firmware Version: 01.01A01
User Capacity:    640 135 028 736 bytes [640 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    5400 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Fri May 20 09:06:50 2016 EEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (16080) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 158) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x7035) SCT Status supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   175   174   051    Pre-fail  Always       -       36164
  3 Spin_Up_Time            0x0027   205   198   021    Pre-fail  Always       -       725
  4 Start_Stop_Count        0x0032   098   098   000    Old_age   Always       -       2837
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   085   085   000    Old_age   Always       -       11387
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   098   098   000    Old_age   Always       -       2827
191 G-Sense_Error_Rate      0x0032   001   001   000    Old_age   Always       -       5719
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       92
193 Load_Cycle_Count        0x0032   001   001   000    Old_age   Always       -       1614214
194 Temperature_Celsius     0x0022   120   103   000    Old_age   Always       -       27 (Min/Max 23/45)
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     11387         -
# 2  Short offline       Completed: read failure       90%     11363         207901192
# 3  Short offline       Completed: read failure       90%     11363         207901192
# 4  Short offline       Completed: read failure       90%     11363         207901192
# 5  Conveyance offline  Completed without error       00%      9570         -
# 6  Conveyance offline  Completed without error       00%      9570         -
# 7  Conveyance offline  Completed: read failure       90%      9566         214779409
# 8  Extended offline    Completed: read failure       90%      9522         38675504
# 9  Short offline       Completed: read failure       90%      9521         38675504
#10  Conveyance offline  Completed: read failure       90%      9521         38675504
#11  Extended offline    Completed: read failure       90%      9521         38675508
#12  Extended offline    Completed: read failure       90%      9521         38675504
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Testing has begun.
Test will complete after Fri May 20 09:02:03 2016
[root@localhost HetmanNet]# smartctl -a /dev/sdb
Device Model:     WDC WD5000BEVT-00A0RT0
Serial Number:    WD-WX61A70W2986
LU WWN Device Id: 5 0014ee 2af88c276
User Capacity:    500 107 862 016 bytes [500 GB]
Local Time is:    Fri May 20 09:07:13 2016 EEST
                                        was never started.
                                        been run.
data collection:                (13200) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 154) minutes.
SCT capabilities:              (0x7037) SCT Status supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       295
  3 Spin_Up_Time            0x0027   151   149   021    Pre-fail  Always       -       3408
  4 Start_Stop_Count        0x0032   095   095   000    Old_age   Always       -       5664
  9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       17671
 10 Spin_Retry_Count        0x0032   100   100   051    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       286
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       271
193 Load_Cycle_Count        0x0032   165   165   000    Old_age   Always       -       107897
194 Temperature_Celsius     0x0022   121   104   000    Old_age   Always       -       26
200 Multi_Zone_Error_Rate   0x0008   100   253   051    Old_age   Offline      -       0
No Errors Logged
# 1  Short offline       Completed without error       00%     17671         -
# 2  Short offline       Completed: read failure       90%     17652         399671019
# 3  Extended offline    Completed: read failure       90%     17630         399671019
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
