Тема: [KERBEROS] Cannot allocate memory
Доброго вечора Вирішив SAMBA апнути до рівня SAMBA AC DC + KERBEROS + BIND9.. ну незважаючи на проблеми з SAMBA на FEDORA 24 знайшов на corp реп з пакунками з наявною підтримкою DC і поставив, bind9 налаштував, та ось на етапі kerberos при спробі systemctl start krb5kdc отримую: krb5kdc: Cannot allocate memory - while initializing database for realm MM.LOCAL.. при тому що є 6 ГБ вільної оперативи.. -_-
[root@wserver HetmanNet]# cat /etc/samba/smb.conf
# Global parameters
[global]
netbios name = WSERVER
realm = MM.LOCAL
server services = s3fs, rpc, nbt, wrepl, ldap, cldap, kdc, drepl, winbindd, ntp_signd, kcc, dnsupdate
workgroup = MM
server role = active directory domain controller
idmap_ldb:use rfc2307 = yes
[netlogon]
path = /var/lib/samba/sysvol/mastermilk.local/scripts
read only = No
[sysvol]
read only = No
cat /etc/krb5.conf
[libdefaults]
default_realm = MM.LOCAL
dns_lookup_realm = false
dns_lookup_kdc = true
/etc/krb5.conf -> /var/lib/samba/private/krb5.conf
[root@wserver HetmanNet]# cat /etc/named.conf //
// named.conf
// Provided by Red Hat bind package to configure the ISC BIND named( DNS
// server as a caching only nameserver (as a localhost DNS resolver only).
// See /usr/share/doc/bind*/sample/ for example named configuration files.
options {
listen-on port 53 { 127.0.0.1; 192.168.1.100; };
listen-on-v6 port 53 { ::1; };
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
memstatistics-file "/var/named/data/named_mem_stats.txt";
forwarders { 8.8.8.8; 8.8.4.4; };
allow-query { localhost; any; };
- If you are building an AUTHORITATIVE DNS server, do NOT enable recursion.
- If you are building a RECURSIVE (caching) DNS server, you need to enable
recursion.
- If your recursive DNS server has a public IP address, you MUST enable access
control to limit queries to your legitimate users. Failing to do so will
cause your server to become part of large scale DNS amplification
attacks. Implementing BCP38 within your network would greatly
reduce such attack surface
recursion yes;
dnssec-enable yes;
dnssec-validation yes;
/* Path to ISC DLV key */
/* In case you want to use ISC DLV, please uncomment the following line. */
//bindkeys-file "/etc/named.iscdlv.key";
managed-keys-directory "/var/named/dynamic";
pid-file "/run/named/named.pid";
session-keyfile "/run/named/session.key";
/* https://fedoraproject.org/wiki/Changes/CryptoPolicy */
include "/etc/crypto-policies/back-ends/bind.config";
tkey-gssapi-keytab "/var/lib/samba/private/dns.keytab";
logging {
channel default_debug {
file "data/named.run";
severity dynamic;
zone "." IN {
type hint;
file "named.ca";
include "/etc/named.rfc1912.zones";
include "/etc/named.root.key";
include "/etc/named.samba.conf";
/etc/named.samba.conf -> /var/lib/samba/private/named.conf
