Тема: Making a Ajax request and manipulate the text
Hi,
I'm looking for a way to make a page request in Ajax and retrieve the request page to a string. This string should be available to any function but in the example below it isn't because alert(data); doesn't popup. After converting to a string i want to manipulate the text by using "find" to look for a string or a text in a determined area. Can this be done?
[code=HTML]
<input type="text" id="http" value="http://www.example.com">
<br>
<input type="button" id="submit" onclick="myhttp()" value="Send!"/>
<script>
    function myhttp() {
        var http = document.getElementById("http").value;
        var dataString = 'lsd=AVrls4dL&email=email@gmail.com';
        $.ajax({
            type: "GET",
            url: http,
            data: dataString,
            async: false,
            success: function(data){
                alert(data);
</script>
[/code]
Thanks
2 Востаннє редагувалося Engineer (18.10.2018 22:19:57)
Re: Making a Ajax request and manipulate the text
You can update your code and add error handler for catch the problems
<br>
<script>
    function myhttp() {
        $.ajax({
            type: "GET",
            url: http,
            data: dataString,
            async: false,
                alert(data);
                error: function (data) {
                    alert(data.statusText);
                    alert(data.responseText);
</script>
Hi, using your error handler gives 2 messages, "NetworkError: A network error occured." for data.statusText and "undefined" for data.responseText.
The get request is made succeffully as you can see below
https://i.imgur.com/d6Edy21.jpg
But what i really want is to cache or something similar all text presented in the page and convert to a string to show the info to the user.
As for me you have an issue with cross-domain http request.
Please see https://stackoverflow.com/questions/150 … query-ajax for more details
Moved to English, c 1.1
