Тема: Допоможіть розібратись!
Що я тільки не робила, а воно все викидає помилки. Підкажіть, що не так
unit Unit2;
interface
uses
  System.SysUtils, System.Types, System.UITypes, System.Classes, System.Variants,
  FMX.Types, FMX.Controls, FMX.Forms, FMX.Graphics, FMX.Dialogs, FMX.StdCtrls,
  FMX.Controls.Presentation, FMX.Objects, FMX.Colors, FMX.Gestures, FMX.Platform.Android;
type
  TForm2 = class(TForm)
    ToolBar1: TToolBar;
    Label1: TLabel;
    Label2: TLabel;
    RadioButton1: TRadioButton;
    RadioButton2: TRadioButton;
    RadioButton3: TRadioButton;
    Label3: TLabel;
    ColorPicker1: TColorPicker;
    Button1: TButton;
    GestureManager1: TGestureManager;
    Rectangle1: TRectangle;
    PaintBox1: TPaintBox;
    Switch1: TSwitch;
    procedure FormGesture(Sender: TObject; const EventInfo: TGestureEventInfo;
      var Handled: Boolean);
    procedure PaintBox1Paint(Sender: TObject; Canvas: TCanvas);
    procedure FormKeyDown(Sender: TObject; var Key: Word; var KeyChar: Char;
      Shift: TShiftState);
    procedure FormKeyUp(Sender: TObject; var Key: Word; var KeyChar: Char;
    procedure Button1Click(Sender: TObject);
    procedure Switch1Switch(Sender: TObject);
    procedure FormCreate(Sender: TObject);
  private
    { Private declarations }
  public
    { Public declarations }
var
  Form2: TForm2;
  thickness: integer;
  Itsel: integer;
implementation
{$R *.fmx}
{$R *.XLgXhdpiTb.fmx ANDROID}
procedure ExitConfirm;
begin
 MessageDlg ( 'Хочете вийти!', System.UITypes.TMsgDlgType.mtInformation,
 System.UITypes.TMsgDlgBtn.mbYes,
 System.UITypes.TMsgDlgBtn.mbNo
 ], 0,
 procedure (const AResult: TModalResult)
 begin
 case AResult
 of
 mrYES:
 begin
 MainActivity.Finish;
 mrNo:
 begin
 end
procedure ThicknessInc (var l: Tlabel);
begin
thickness:= thickness + 1;
if thickness> 10 then thickness:= 10;
l.Text:= 'Товщина лінії:' + inttostr (thickness);
procedure ThicknessDec (var l: Tlabel);
begin
 thickness:= thickness-1;
 if thickness <1 then thickness:= 1;
procedure TForm2.Button1Click(Sender: TObject);
begin
 if Radiobutton1.IsChecked then Itsel:= 1;
 if radiobutton2.IsChecked then Itsel:= 2;
 if radiobutton3.IsChecked then Itsel:= 3;
 Rectangle1.Visible:= false;
procedure TForm2.FormCreate(Sender: TObject);
begin
 thickness:= 1;
 itsel:= 1;
procedure TForm2.FormGesture(Sender: TObject;
  const EventInfo: TGestureEventInfo; var Handled: Boolean);
begin
case EventInfo.GestureID of
sgiLeft:
begin
  ThicknessInc (Label2);
  PaintBox1.Repaint;
sgiRight:
 begin
 thicknessDec (Label2);
 PaintBox1.Repaint;
  sgiCircle:
 begin
  Rectangle1.Visible:= true;
  PaintBox1.Repaint;
Begin
if Key = vkVolumeUp then
begin
 Key:= 0;
if Key = vkVolumeDown then
begin
 Key:= 0;
if Key = vkHardwareBack then
begin
 Key:= 0;
procedure TForm2.PaintBox1Paint(Sender: TObject; Canvas: TCanvas);
 var p1, p2: tpoint;
 x0, y0: integer;
begin
 PaintBox1.Canvas.Stroke.Color:= ColorPicker1.Color;
 case Itsel of
 1: PaintBox1.Canvas.Stroke.Dash:= TStrokeDash.Solid;
 2: PaintBox1.Canvas.Stroke.Dash:= TStrokeDash.Dot;
 3: PaintBox1.Canvas.Stroke.Dash:= TStrokeDash.Dash;
PaintBox1.Canvas.Stroke.Thickness:= thickness;
PaintBox1.Canvas.BeginScene;
x0:= Round (632 / 2);
y0:= Round (416 / 2);
p1.X:= x0 + size;
p1.Y:= y0 + size;
p2.X:= x0 + size;
p2.Y:= y0-size;
PaintBox1.Canvas.DrawLine (p1, p2,1.0);
p1.X:= x0 + size;
p1.Y:= y0 + size;
p2.X:= x0-size;
p2.Y:= y0 + size;
p1.X:= x0-size;
p1.Y:= y0 + size;
p2.X:= x0-size;
p2.Y:= y0-size;
PaintBox1.Canvas.DrawLine (p1, p2 , 1.0);
p1.X:= x0-size;
p1.Y:= y0-size;
p2.X:= x0 + size;
p2.Y:= y0-size;
p1.X:= x0-size;
p1.Y:= y0-size;
p2.X:= x0 + size;
p2.Y:= y0 + size;
p1.X:= x0-size;
p1.Y:= y0 + size;
p2.X:= x0 + size;
p2.Y:= y0-size;
PaintBox1.Canvas.EndScene;
begin
begin
 Key:= 0;
 if size < 5 then
 PaintBox1.Repaint;
begin
 Key:= 0;
 size:= size + 5;
if size>150 then size:= 150;
 PaintBox1.Repaint;
begin
 Key:= 0;
 ExitConfirm;
procedure TForm2.Switch1Switch(Sender: TObject);
begin
if Switch1.IsChecked then
 begin
 ExitConfirm;
 Switch1.IsChecked:= false;
end.
Re: Допоможіть розібратись!
Які саме помилки?
Дякую за відповідь, з кодом розібралась
Тепер інша проблема: не можу підключити телефон до Delphi
Після того, як ви натиснули кнопку Run і воно не змогло відправити аплікацію на смартфон, в надрах папки проекту буде apk-файл, який можна встановити на смартфон вручну.
