Тема: потрібно посортувати елементи масиву двовимірного бульбашковм методом!
▼Код
program DlyaVani;
uses
  crt, graph;
const
  m = 3;
  n = 5;
TYPE
  MAS = ARRAY[1 .. m, 1 .. n] OF integer;
var
  i,j,x: integer;
  A1 : MAS;
  max,min, row, col : integer;
  ca1 : mas;
BEGIN
  {Filling in array}
  randomize;
  FOR I := 1 TO M DO
    FOR J := 1 TO N DO
      A1[i,j] := random(138);
  {Displaying array}
  FOR I := 1 TO M DO BeGIN
    FOR J := 1 TO N DO
      write(A1[I,J], ' ') ;
    writeln;
  {Calculation the SUM}
  FOR i := 1 to m do
    FOR j := 1 to n do
      x := x + a1[i,j];
  writeln('§ Ј «м  бг¬  :', x);
  {Calculating the SUM of each row}
  FOR i := 1 to m do begin
    x := 0;
    for j := 1 to n do
      x := x + A1[i,j];
    writeln('бг¬  ', i, '-Ј® ап¤Є : ', x);
  {Calculating the sUM of each column}
  FOR j := 1 to n do begin
    x := 0;
    for i := 1 to m do
      x := x + A1[i,j];
    writeln('бг¬  ', j, '-Ј® бв®ўЇзЁЄ : ', x);
  {Filling in array}
  FOR i := 1 TO m DO
    FOR j := 1 TO n DO BEGIN
     IF (i = 1) AND (j = 1) THEN BEGIN
       max := a1[i,j];
       col := j;
       row := i;
     END ELSE
       IF a1[i,j] > max THEN BEGIN
         max := a1[i,j];
         col := j;
         row := i;
       END;
  END;
  FOR i := 1 TO m DO
        min := a1[i,j];
        col := j;
        row := i;
    END ELSE
      IF a1[i,j] < min THEN BEGIN
        min := a1[i,j];
        col := j;
        row := i;
      END;
    END;
  writeln('¬ ЄбЁ¬ «мҐ § зҐп :', max,  ' ' , 'а冷Є ' , row , ' бв®ўЇзЁЄ   ', col  );
  writeln('¬ii¬ «мҐ § зҐп :', min, ' а冷Є  ', row, ' бв®ЇзЁЄ ', col  );
  readln;
END.ЯК?????
