jQuery(function(b) {
    var l = null,
        p = null,
        q = null,
        f = null,
        r = null,
        k = null,
        F = null,
        s = null,
        G = null,
        e = null,
        H = null,
        h = null,
        j = null,
        I = null,
        J = "",
        K = null,
        A = !1,
        u = !1,
        B = !1,
        n = !0,
        o = !0,
        v = !1,
        w = null,
        L = null,
        M = null,
        V = document.title,
        m = 0,
        x = 0,
        W = function() {
            var a = f.val();
            a.replace(/[\r\n]+/g, "");
            if (a.replace(/^[ \n]+$/, "") == "") return a.replace(/^\n+$/, "") == "" && f.val(""), !1;
            if (A) return !1;
            var b = q.serialize();
            if (a == J && confirm(t("Will you stop sending the same message? If you click 'Cancel' you can send it again."))) return f.val(""), !1;
            f.val("");
            A = !0;
            s.val(t("Sending..."));
            J = a;
            a.length - 1 > messageMaxLength && (a = a.substring(0, messageMaxLength) + "...");
            var d = y(L),
                a = y(a),
                i = '<dl class="talk" id="' + w + '">';
            i += '<dt class="' + M + '">' + d + "</dt>";
            i += '<dd><div class="bubble">';
            i += '<p class="body ' + userColor + '">' + a + "</p>";
            i += "</div></dd></dl>";
            r.prepend(i);
            N();
            O();
            P(b);
            return !1
        P = function(a) {
            m > 10 ? location.href = location.href : b.ajax({
                type: "POST",
                url: l,
                data: a,
                success: function() {
                    m = 0;
                    A = !1;
                    s.val(t("POST!"))
                error: function() {
                    m += 1;
                    b("<div />").delay(500).queue(function() {
                        P(a)
                dataType: "text"
        Q = function() {
                type: "POST",
                url: p + "?fast=1",
                data: {},
                success: function(a) {
                    m = 0;
                    B = !1;
                    C(a)
                error: function() {
                    m += 1;
                    b("<div />").delay(1500).queue(function() {
                        Q()
                dataType: "xml"
        X = function() {
            b.post(p + "?fast=1", {}, function(a) {
                R();
                C(a)
            }, "xml")
        R = function() {
            b.post(p, {}, function(a) {
                R();
                C(a)
            }, "xml")
        C = function(a) {
            var c = b(a).find("room > update").text() * 1;
            if (K == c || h.is(":visible")) x = 0;
            else {
                var d = Y(a);
                if (d != 0) {
                    if (x += 1, x > 3) u = !0, alert(d), location.href =
                        duraUrl
                } else x = 0, K = c, c = b(a).find("room > name").text(), document.title = c + " | " + V, H.text(c), roomLimitElement.text(b(a).find("room > limit").text()), roomTotalElement.text(b(a).find("users").length), b.each(b(a).find("talks"), Z), $(a), b(a).find("host").text() == w ? e.find("li.setting").show() : e.find("li.setting").hide()
        Z = function() {
            var a = b(this).find("id").text();
            if (!(b("#" + a).length > 0)) {
                var c = g(b(this).find("uid").text()),
                    d = g(b(this).find("name").text()),
                    i = g(b(this).find("message").text()),
                    f = g(b(this).find("icon").text()),
                    e = g(b(this).find("color").text());
                g(b(this).find("time").text());
                d = y(d);
                i = y(i);
                c == 0 || c == "0" ? r.prepend('<div class="talk system" id="' + a + '">' + i + "</div>") : c != w && (a = '<dl class="talk" id="' + a + '">', a += '<dt class="' + f + '">' + d + "</dt>", a += '<dd><div class="bubble">', a += '<p class="body ' + e + '">' + i + "</p>", a += "</div></dd></dl>", r.prepend(a), N());
                O()
        $ = function(a) {
            k.find("li").remove();
            j.find("li").remove();
            var c = b(a).find("users").length;
            k.append("<li>(" + c + ")</li>");
            var d = b(a).find("host").text();
            b.each(b(a).find("users"),
                function() {
                    var a = b(this).find("name").text(),
                        c = b(this).find("id").text(),
                        f = b(this).find("icon").text(),
                        e = "";
                    d == c && (e = " " + t("(host)"));
                    k.append("<li>" + a + e + "</li>");
                    d != c && (j.append("<li>" + a + "</li>"), j.find("li:last").css({
                        background: 'transparent url("' + duraUrl + "/css/icon/" + f + '.png") center top no-repeat'
                    }).attr("name", c).click(function() {
                        b(this).hasClass("select") ? (j.find("li").removeClass("select"), settingPannelButtons.attr("disabled", "disabled")) : (j.find("li").removeClass("select"), b(this).addClass("select"),
                            settingPannelButtons.removeAttr("disabled"))
            S()
        Y = function(a) {
            a = b(a).find("error").text() * 1;
            if (!(a == 0 || u))
                if (a == 1) return t("Session time out.");
                else if (a == 2) return t("Room was deleted.");
            else if (a == 3) return t("Login error.");
            return 0
        N = function() {
            var a = b(".bubble .body:first"),
                c = a.parent(),
                d = a.width() + "px",
                e = a.height() + "px",
                f = 5 + a.width() + "px",
                g = 5 + a.height() + "px";
            if (o) try {
                messageSound.play()
            } catch (h) {}
            n ? (b("dl.talk:first dt").click(T), b.each(c, D), c.css({
                    opacity: "0",
                    width: "0px",
                    height: "0px"
                c.animate({
                    opacity: 1,
                    width: "22px",
                    height: "16px"
                }, 200, "easeInQuart"), a.css({
                    "border-width": "0px",
                    "font-size": "0px",
                    "text-indent": "-100000px",
                    opacity: "0",
                    width: "0px",
                    height: "0px"
                }), a.animate({
                    fontSize: "1em",
                    borderWidth: "4px",
                    width: f,
                    height: g,
                    opacity: 1,
                    textIndent: 0
                }, 200, "easeInQuart", function() {
                    b.each(a, E);
                    a.animate({
                        width: d,
                        height: e
                    }, 100)
                })) : (b.each(c, D), b.each(a, E))
        y = function(a) {
            a = a.replace(/&/g, "&");
            a = a.replace(/"/g, """);
            a = a.replace(/'/g, "'");
            a = a.replace(/</g, "<");
            return a = a.replace(/>/g,
        aa = function() {
            var a = f.val();
            if (a != a.replace(/[\r\n]+/g, "")) return q.submit(), !1
        ba = function() {
            u = !0;
            b("*").hide();
            b.post(l, {
                logout: "logout"
            }, function() {
                location.href = duraUrl
        O = function() {
            if (b(".talk").length > 50)
                for (; b(".talk").length > 50;) b(".talk:last").remove()
        S = function() {
            k.find("li:not(:last)").each(function() {
                b(this).append(", ")
        T = function() {
            var a = b(this).text(),
                c = f.val();
            f.focus();
            c.length > 0 ? f.val(c + " @" + a) : f.val(c + "@" + a + " ")
        g = function(a) {
            return a = a.replace(/^\s+|\s+$/g, "")
        E = function() {},
        D = function() {
            var a = b(this).find(".body").height() + 30 + 8,
                a = (Math.round((180 - a) / 2) + 23) * -1,
                c = b(this).find(".body").css("background-image"),
                d = "0px";
            Math.floor(Math.random() * 2) == 1 && (d = "-17px");
            a += 1;
            b(this).find(".body").css({
                margin: "0 0 0 15px"
            b(this).prepend("<div><div></div></div>").css({
                margin: "-16px 0 0 0"
            b(this).children("div").css({
                position: "relative",
                "float": "left",
                margin: "0 0 0 0",
                top: "39px",
                left: "-3px",
                width: "22px",
                height: "16px",
                background: "transparent " + c + " left " + a + "px repeat-x"
            b(this).children("div").children("div").css({
                width: "100%",
                height: "100%",
                background: "transparent url('" + duraUrl + "/css/tail.png') left " + d + " no-repeat"
        ca = function() {
            e.find("li:hidden:not(.setting)").show();
            var a = o ? "sound_on" : "sound_off",
                b = v ? "member_on" : "member_off",
                d = n ? "animation_on" : "animation_off";
            e.find("li.sound").addClass(a);
            e.find("li.member").addClass(b);
            e.find("li.animation").addClass(d)
        da = function() {
            o ? (b(this).removeClass("sound_on"), b(this).addClass("sound_off"), o = !1) : (b(this).removeClass("sound_off"),
                b(this).addClass("sound_on"), o = !0)
        ea = function() {
            v ? (b(this).removeClass("member_on"), b(this).addClass("member_off"), k.slideUp("slow"), v = !1) : (b(this).removeClass("member_off"), b(this).addClass("member_on"), k.slideDown("slow"), v = !0)
        fa = function() {
            n ? (b(this).removeClass("animation_on"), b(this).addClass("animation_off"), n = !1) : (b(this).removeClass("animation_off"), b(this).addClass("animation_on"), n = !0)
        z = function() {
            settingPannelButtons.attr("disabled", "disabled");
            s.slideToggle();
            I.slideToggle();
            h.slideToggle()
        ga = function() {
            var a = h.find("input[name=room_name]").val(),
                c = h.find("select[name=limit]").val();
            b.post(l, {
                room_name: a,
                limit: c
            }, function(a) {
                alert(a);
                z()
        ha = function() {
            var a = j.find("li.select").attr("name");
            confirm(t("Are you sure to handover host rights?")) && b.post(l, {
                new_host: a
            }, function(a) {
                alert(a);
                z()
        ia = function() {
            U(!1, t("Are you sure to kick this user?"))
        ja = function() {
            U(!0, t("Are you sure to ban this user?"))
        U = function(a, c) {
            var d;
            d = j.find("li.select").attr("name");
            confirm(c) && (d = a == !0 ? {
                ban_user: d,
                block: 1
                ban_user: d
            }, b.post(l, d, function(a) {
                alert(a);
                z()
    (function() {
        var a = location.href.replace(/#/, "");
        l = a.replace(/\?/, "") != a ? a + "&ajax=1" : a + "?ajax=1";
        p = duraUrl + "/ajax.php";
        q = b("#message");
        f = b("#message textarea");
        r = b("#talks");
        k = b("#members");
        F = b("input[name=logout]");
        s = b("input[name=post]");
        G = b("dl.talk dt");
        e = b("ul.menu");
        H = b("#room_name");
        roomLimitElement = b("#room_limit");
        roomTotalElement = b("#room_total");
        h = b("#setting_pannel");
        j = b("#user_list");
        settingPannelButtons = b("input[name=handover], input[name=ban], input[name=block]");
        I = b(".messageInput");
        w = g(b("#user_id").text());
        L = g(b("#user_name").text());
        M = g(b("#user_icon").text());
        userColor = g(b("#user_color").text());
        messageMaxLength = 140;
        typeof GlobalMessageMaxLength != "undefined" && (messageMaxLength = GlobalMessageMaxLength);
        q.submit(W);
        f.keyup(aa);
        F.click(ba);
        G.click(T);
        e.find("li.sound").click(da);
        e.find("li.member").click(ea);
        e.find("li.animation").click(fa);
        e.find("li.setting").click(z);
        h.find("input[name=save]").click(ga);
        h.find("input[name=handover]").click(ha);
        h.find("input[name=ban]").click(ia);
        h.find("input[name=block]").click(ja);
        S();
        b("#talks dl.talk dd div.bubble p.body").each(E);
        ca();
        useComet ? X() : setInterval(function() {
            !B && !u && (B = !0, Q())
        }, 1500);
        b.each(b(".bubble"), D)
