Може коди UNKNOWN-ATTRIBUTE? https://tools.ietf.org/html/rfc3489
The UNKNOWN-ATTRIBUTES attribute is present only in a Binding Error
Response or Shared Secret Error Response when the response code in
the ERROR-CODE attribute is 420.
The attribute contains a list of 16 bit values, each of which
represents an attribute type that was not understood by the server.
If the number of unknown attributes is an odd number, one of the
attributes MUST be repeated in the list, so that the total length of
the list is a multiple of 4 bytes.
Правда не розумію тоді чому там 5 байт, а не чотири.
Допишете статтю коли розберетесь? А то я сам не розумію що це і як працює.
