Тема: error: undefined reference to `vtable for ...
Зробив DLL за допомогою QT + MinGW
pro file
# Project created by QtCreator 2018-04-01T04:51:46
QT       -= gui
TARGET = kuins_method
TEMPLATE = lib
DEFINES += KUAINRULE_EXPORTS
# The following define makes your compiler emit warnings if you use
# any feature of Qt which has been marked as deprecated (the exact warnings
# depend on your compiler). Please consult the documentation of the
# deprecated API in order to know how to port your code away from it.
DEFINES += QT_DEPRECATED_WARNINGS
# You can also make your code fail to compile if you use deprecated APIs.
# In order to do so, uncomment the following line.
# You can also select to disable deprecated APIs only up to a certain version of Qt.
#DEFINES += QT_DISABLE_DEPRECATED_BEFORE=0x060000    # disables all the APIs deprecated before Qt 6.0.0
SOURCES += \
    ../kuins_method_file/abstractnormalform.cpp \
    ../kuins_method_file/abstractobject.cpp \
    ../kuins_method_file/constituent.cpp \
    ../kuins_method_file/expression.cpp \
    ../kuins_method_file/initkuainrule.cpp \
    ../kuins_method_file/kuainrule.cpp \
    ../kuins_method_file/normalform.cpp \
    ../kuins_method_file/perfectnormalform.cpp \
    ../kuins_method_file/shortnormalform.cpp
HEADERS += \
    ../kuins_method_file/abstractnormalform.h \
    ../kuins_method_file/abstractobject.h \
    ../kuins_method_file/constituent.h \
    ../kuins_method_file/defines.h \
    ../kuins_method_file/expression.h \
    ../kuins_method_file/global.h \
    ../kuins_method_file/initkuainrule.h \
    ../kuins_method_file/kuainrule.h \
    ../kuins_method_file/normalform.h \
    ../kuins_method_file/perfectnormalform.h \
    ../kuins_method_file/shortnormalform.h
unix {
    target.path = /usr/lib
    INSTALLS += target
}global file
#ifndef GLOBAL_H
#define GLOBAL_H
#ifdef _MSC_VER
    #ifdef KUAINRULE_EXPORTS
    #define KUAINRULE_API __declspec(dllexport)
    #else
    #define KUAINRULE_API __declspec(dllimport)
    #endif
#elif __MINGW32__
    #include <QtCore/qglobal.h>
    #  define KUAINRULE_API Q_DECL_EXPORT
    #else
    #  define KUAINRULE_API Q_DECL_IMPORT
    #endif
#else
    #error MSVC or Qt + MinGW compiler required.
#endif
#endif // GLOBAL_HБіля кожної імпортованої функції добавив макрос
Ось приклад:
namespace nsKuainRule {
    class NormalForm : public AbstractNormalForm, public AbstractObject
        std::vector <Expression> _expressionNFs;
    public:
        /**** CONSTRUCTOR & DESTRUCTOR ****/
        KUAINRULE_API NormalForm();
        KUAINRULE_API ~NormalForm();
        /**** OVERRIDE FUNCTIONS ****/
         * \brief Get all expressions from the NF class
         * \return Vector of \a Expression objects
        KUAINRULE_API std::vector<Expression> &getAllExpr() override;
        KUAINRULE_API std::string print() const override;
}скомпілював як дебаг так і резі, без помилок
Підключаю
pro file
TEMPLATE = app
CONFIG += console c++14
CONFIG -= app_bundle
CONFIG += qt
TEMPLATE = lib
QT += core
QT -= gui
SOURCES += main.cpp
HEADERS += \
    abstractobject.h \
    constituent.h \
    defines.h \
    expression.h \
    global.h \
    initkuainrule.h \
    kuainrule.h \
    normalform.h \
    shortnormalform.h
win32:CONFIG(release, debug|release): LIBS += -L$$PWD/./ -lkuins_metho
else:win32:CONFIG(debug, debug|release): LIBS += -L$$PWD/./ -lkuins_method
INCLUDEPATH += $$PWD/.
DEPENDPATH += $$PWD/.при компіляції помилка error: undefined reference to `vtable for ...
*.а, *.dll, *.h - скопіював до кореневої директорії
Що зробити для того щоб позбутися помилки ?
