#if defined(UNICODE) && !defined(_UNICODE)
#define _UNICODE
#elif defined(_UNICODE) && !defined(UNICODE)
#define UNICODE
#endif
#define WIN32_LEAN_AND_MEAN
#include <tchar.h>
#include <windows.h>
#include <commdlg.h>
#include <wincrypt.h>
#define MAX_BUFF_LEN 500
#define COLS_COUNT 20
#define TIMER_1 1
/* Declare Windows procedure 1 */
LRESULT CALLBACK WindowProcedure (HWND, UINT, WPARAM, LPARAM);
int GetRNG();
/* Make the class name into a global variable */
wchar_t filename[MAX_PATH];
unsigned char buffer[MAX_BUFF_LEN] = {0};
unsigned char buffer2[10] = {0,1,2,3,5,9,11,12,13,14};
TCHAR szClassName[ ] = _T("view random number<255 timer=2,5 sec v=0,1,2,3,5,9,11,12,13,14.test only.");
static HCRYPTPROV hCryptProv;
int indexOf(unsigned char *array, int array_size, unsigned char number);
int WINAPI WinMain (HINSTANCE hThisInstance,
HINSTANCE hPrevInstance,
LPSTR lpszArgument,
int nCmdShow)
HWND hwnd; /* This is the handle for our window */
MSG messages; /* Here messages to the application are saved */
WNDCLASSEX wincl; /* Data structure for the windowclass */
/* The Window structure */
wincl.hInstance = hThisInstance;
wincl.lpszClassName = szClassName;
wincl.lpfnWndProc = WindowProcedure; /* This function is called by windows */
wincl.style = CS_DBLCLKS; /* Catch double-clicks */
wincl.cbSize = sizeof (WNDCLASSEX);
/* Use default icon and mouse-pointer */
wincl.hIcon = LoadIcon (NULL, IDI_APPLICATION);
wincl.hIconSm = LoadIcon (NULL, IDI_APPLICATION);
wincl.hCursor = LoadCursor (NULL, IDC_ARROW);
wincl.lpszMenuName = NULL; /* No menu */
wincl.cbClsExtra = 0; /* No extra bytes after the window class */
wincl.cbWndExtra = 0; /* structure or the window instance */
/* Use Windows's default colour as the background of the window */
wincl.hbrBackground = (HBRUSH)(COLOR_WINDOWTEXT + 1);
/* Register the window class, and if it fails quit the program */
if (!RegisterClassEx (&wincl))
/* The class is registered, let's create the program*/
hwnd = CreateWindowEx (
0, /* Extended possibilites for variation */
szClassName, /* Classname */
szClassName, /* Title Text */
WS_OVERLAPPEDWINDOW, /* default window */
CW_USEDEFAULT, /* Windows decides the position */
CW_USEDEFAULT, /* where the window ends up on the screen */
544, /* The programs width */
375, /* and height in pixels */
HWND_DESKTOP, /* The window is a child-window to desktop */
NULL, /* No menu */
hThisInstance, /* Program Instance handler */
NULL /* No Window Creation data */
/* Make the window visible on the screen */
ShowWindow (hwnd, nCmdShow);
/* Run the message loop. It will run until GetMessage() returns 0 */
while (GetMessage (&messages, NULL, 0, 0))
/* Translate virtual-key messages into character messages */
TranslateMessage(&messages);
/* Send message to WindowProcedure */
DispatchMessage(&messages);
/* The program return-value is 0 - The value that PostQuitMessage() gave */
return messages.wParam;
/* This function is called by the Windows function DispatchMessage() */
LRESULT CALLBACK WindowProcedure (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
static int cxChar, cxCaps, cyChar, x, y;
PAINTSTRUCT ps;
HDC hdc;
TEXTMETRIC tm;
char strbuff[4] = {'\0'};
//int x,y;
switch (message) /* handle the messages */
case WM_CREATE:
//OpenFileDialog(hwnd);
hdc = GetDC(hwnd);
GetTextMetrics(hdc,&tm);
cxChar = tm.tmAveCharWidth ;
cxCaps = (tm.tmPitchAndFamily & 1 ? 3 : 2) * cxChar / 2 ;
cyChar = tm.tmHeight + tm.tmExternalLeading ;
ReleaseDC (hwnd, hdc);
SetTimer(hwnd,TIMER_1,2000,NULL);
case WM_PAINT:
//sprintf(strbuff,"%3u",221);
BeginPaint(hwnd,&ps);
SetBkColor(ps.hdc, RGB(0, 0, 0));
SetTextColor(ps.hdc, RGB(5, 78, 188));
SetTextAlign(ps.hdc,TA_RIGHT);
x = 3*cxCaps;
y = cyChar;
for (int i =0; i < MAX_BUFF_LEN; ++i)
if (indexOf(buffer2,10,buffer[i]) != -1)
SetTextColor(ps.hdc, RGB(255, 108, 18));
sprintf(strbuff,"%3u",buffer[i]);
if (i % COLS_COUNT == 0)
x = 3*cxCaps;
y += cyChar;
x += 3*cxCaps;
TextOutA(ps.hdc, x , y, strbuff, 3);
x = 6*cxCaps;
y = 0;
//SetBkColor(ps.hdc, RGB(125, 120, 120));
SetTextColor(ps.hdc, RGB(255, 178, 188));
for(int i = 0; i < COLS_COUNT; ++i)
sprintf(strbuff,"%3u",i);
//x += 3*cxCaps;
TextOutA(ps.hdc,x ,0, strbuff, 3);
x += 3*cxCaps;
//= 3*cxCaps;
//SetBkColor(ps.hdc, RGB(0, 0, 0));
SetTextColor(ps.hdc, RGB(155, 178, 188));
SetTextAlign(ps.hdc,TA_LEFT);
y = cyChar;
for(int i = 0; i < MAX_BUFF_LEN/ COLS_COUNT; ++i)
y += cyChar;
TextOutA(ps.hdc, 0,y, strbuff, 3);\
//x += 3*cxCaps;
//TextOutA(ps.hdc, 1, 15, strbuff, 3);
EndPaint(hwnd, &ps);
case WM_TIMER:
GetRNG();
InvalidateRect(hwnd, NULL, TRUE);
case WM_DESTROY:
KillTimer(hwnd,TIMER_1);
PostQuitMessage (0); /* send a WM_QUIT to the message queue */
default: /* for messages that we don't deal with */
return DefWindowProc (hwnd, message, wParam, lParam);
int GetRNG()
//BYTE pbData[MAXLEN];
if (!CryptAcquireContextW(&hCryptProv, 0, 0, PROV_RSA_FULL, CRYPT_VERIFYCONTEXT | CRYPT_SILENT))
return 1;
if (!CryptGenRandom(hCryptProv, MAX_BUFF_LEN, buffer))
return 1;
for (int i = 0; i < array_size; ++i)
if (array[i] == number)
return i;
return -1;
